I'm really not sure what you mean.
The RB30 block has a predrilled and tapped hole for the new tensioner location as an RB30 only uses one tensioner and no idler on the drivers side or when looking at the block the left side of the block.
Found a pic of my block as it was being built up.
As you can see the flat surface around the place where the tensioner will go.
Mine was a Series II VL Wagon Exec NA Block.
Are the blocks you have Series 1 blocks? Do they have the oil and water lines already tapped? If not they are series 1 blocks.
Are you going to use stainless steel welsh plugs or brass ones as per pic 1?
EDIT: Also the fuel consumption I am getting is pretty damn good..
Slightly better than what the rb20t was getting. :D
The RB20t was getting around 11L/100km's.
heres the pics. i have 3 blocks like the first pic and the other is a genuine vl turbo block
I have a VL na S2 block and it looks like this.
Now I know that VLT and VL na S2 blocks are the same but if you look under the engine block number it will have a number.
6=na
8=turbo
mines a 6 :D
well its all tapped for turbo gear from the factory so its a bit wierd!
also i have another turbo block that doesnt have the machined surface for the tensioner.
so its 5 blocks in total all of which are tapped from the factory.
2 turbo blocks wearing an 8 under the engine number.only 1 has the machined surface!
3 na blocks all of which have no machined surface
dnb My block is the same as yours and it has all the oil and water lines tapped aswell. I have already had it Torqueplate bored, honed and o'ringed so I was thinking of making a washer the right shape and fill around it with devcon (steel putty) and file it back level with the other surfaces. I have bought a second tensioner instead of the idler. I also have to make an adopter plate to fit a 4wd sump as it will be going into a GTS4.
what about the na blocks that ARE tapped but have no machined surface?.
you deleted your post alf! now this looks silly
sorry, getting confused here.
Ok, i've had this convo about rb30 na blocks before with several knowledgable ppl.
Everyone says the s1 rb30 block doesnt have tapped holes for oil and doesn't have the machined surface.. but the same ppl have seen a few s1 blocks with tapped holes.
haha yeah ive had that block done aswell;( its cool though as im selling my old sohc set up to a guy who will buy this block off me as its ready to go. i was gonna do the devcon trick aswell but since i have the option to unload it and i have another block sitting there i will just get the other one machined up.
i think this had better be mentioned in the rb2530 conversion guide!
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
