Bl4ck32....why did you go with a custom 1 piece tailshaft?
Cubes et al....is there actually that much meat on the '32 engine mounts that you can slot them 13/15 mm? On the R33 the mounts are minimalist alloy items and that much would almost cut through. Since my entire front end is now on a pallet on the floor I may take some pictures and measurements of my setup...
Joel:
In your PDF its says that u changed the 25 idler pulley to a tensioner pulley.
Were these 30 or 25 items?.
My 25 pulleys are rooted, I can get 2 x 30 tensioners (I asked for VL RB30E ones) for cheaper than 25 ones, also how much did u get ur Gates 94407 timing belt for?
cheers. :rofl:
I've got a question, when you guys have relocated the tensioners, have you tapped the spike/bolt for the spring to push/spring on, to get the self tensioning effect, or have you just adjusted them by hand and tightened them, if you know what i mean....
I'd like to know too.
The RB30E tensioner pulley has a second stud to stop the spring from spinning around, I havent seen anyone use the second stud in a RB30/25/26
This is from memory.. (again) lol
The drivers side is basically a piece of sheet metal shaped in to an engine mount. That was redrilled with no issues, old holes then filled in and hit it with the grinder.
The passenger side engine mount had the flat plate bit that bolts on to the engine ground off then rewelded (much better I might add) lower.
How much did u get ur Gates 94407 timing belt for?
The tensioners are all the same, RB30/20/25/26.
I bought a new RB20DET item which used 2 internal bearings next to each other.
I then ordered a RB30 item as they had them in stock and found they only use one bearing. lol Typical holden. :P
I didn't bother with the spring as the tensioners are locking tensioners and require roughly 20kg's of tension on the belt.
The spring doesn't tension the belt correctly, it pulls up the slack to make life easier when fitting.
The belt.. $37.50.
r33 gearbox (with custom gearbox x member to bolt it into a r32), tailshaft, and modified speedo sender came out of another r32. Also had the r33 yoke etc. So it was a bolt in upgrade from that point.
It weighs heaps less too. I dont know how that would affect performance though :) ....or....lack of :rofl:
Ben,
Stupid me.. I didn't write it down anywhere.
It may be on my oldies computer as that is where I dropped the motor in.
Failing that I will give Shaun a buzz as he knows :(
Oh great! lol..
Well I am probably going to do it tomorrow.. so if your around.. please try and get the info! :D
I just like the idea of not having to worry about a worn belt letting go, or a tensioner bearing bolt snapping to blow my motor. I reckon around 80,000 is a good time...hell why not 50,000 kms when the two tensioners + belt comes to $220 for a major service.. :)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
