RB30E (non turbo) with RB25DE head, everything internal standard, new rings, bearings gaskets and seals and all of the up & down and round & round stuff balanced. Made 475 bhp on the engine dyno, still going nearly 5 years later. Proves that if you keep the boost down (1.1 bar) ,service it regularly and tune it properly, it will last a long time.:cheers:
awesome. well i have a turbo head from my engine outa my other car. u think i shuld hunt down a turbo block or go for an n/a block ? sydney kid would you be able to pm me an avergae price and exact thigns you got done. im not after insane power. as i shall have that in my other car. (yes i know i shuld spend more money etc on it but *** it :cheers:)
Go for an na block as the comp will be more suitable for more low down torque. But if you do find a turbo block change the pistons to na ones to get a decent comp.
It's easier to find an na block with the oil n water lines tapped like in na s2's.
awesome. well i have a turbo head from my engine outa my other car. u think i shuld hunt down a turbo block or go for an n/a block ? sydney kid would you be able to pm me an avergae price and exact thigns you got done. im not after insane power. as i shall have that in my other car. (yes i know i shuld spend more money etc on it but *** it :rofl:)
I don't care how much money you spend, if you have read this thread you will find I mentioned a guy I know who buys used RB30 bottom ends, whacks new rings, bearings and seals in it for an all up cost of ~$1200. He then sticks his good top end and turbo on it and goes racing. He usually ends up with around 500 rwhp, and he just races it till it blows up. He has been doing it for around 5 years and is on his 3rd bottom end. Around the same time I built a forged bottom end RB31 that cost me $6K, so he is still 2 engines worth ($2400) ahead.
He buys standard VL Commondoor parts, rings, bearings, gaskets and seals. Hones the bores, decks the block and gets the up & down and round & round parts balanced. That's it, no secrets, just a standard rebuild of an RB30E, any machine shop can do it.
The real "secret" is tuning and knowing the limits. He doesn't "sneak a bit more boost in", "rev it a bit higher", try for "just another 20 hp". It gets service regularly, uses good oil and the tune is checked often. It isn't tuned on the limit for fuel or ignition, the tune is a bit conservative everywhere. I mentioned "tune" 4 times, not by accident.
Hope that is of some help:cheers:
okay 93 pages is a bit much for me, need a quick answer for this one:
i am looking at purchasing an R33 RB25DE head, supposedly with VCT.
1. did they come with VCT?
2. is the presence of different cams the ONLY difference between this head and an R33 RB25DET head?
All R33 RB25 Heads have VCT.
As far as I'm aware the R33 RB25's have the same cam specs. Lobe centers and all.
The only difference is the VCT is engaged at a higher rpm on the N/A heads, this is controlled via the ECU.
The N/A heads do run softer valve springs which may cause a valve float at 1bar+ boost.
brilliant, good answer. thanks dude! i won't be running more than 1bar to reach 450hp so that'll do me just fine.
odd, though, that the turbo and n/a cams would be the same...... nissan must have got lazy and started mass-producing them cheaper.
this head is still a direct bolt-on (after i re-route the VCT feed of course, and blank off the hole in the head for it) to an RB30 block isn't it?
If the cam specs (lobe centers) are different for the N/A's it really doesn't cause any problems. I got the cam specs from the Tomei website.
There are a few discrepancy's with the specs on the table, so the specs they list for the r33 rb25 may not be 100% accurate.
If anything the N/A will be setup with a little more overlap which is good for top end breathing, this will benifit the 3ltr.
The head is a direct bolt on after the VCT mods.
I would still get the heads valve seat pressure checked out if anything at all.
Some heads I have seen have lacked seat pressure.
You need seat pressure to cool the valve.
Without in spec seat pressure you 'may' drop a valve. :(
yeah i see what you're getting at with the cam, either way it doesn't worry me. cams are one of the last things i would change to reach my target power. just wondering now if i should bother getting my rods cryo treated and shotpeened or just leave em........ ah i dunno.
the head i am looking is dissassembled completely, has everything there though. been crack tested, pressure tested and cleaned, the valves need re-seating but are fine apart from that. also wondering how much a head specialist would charge to do this..... might throw in some isky springs while i'm there, or can you add a shim to increase the seat pressure?
You can add shims to increase the seat pressure but this won't affect the springs tension and will still valve float at the higher boost levels.
If you are thinking about cryotreating rods etc then obviously you want 280rwkw+.
Go with the isky valve springs.
While your there let me know what they are worth as I will eventually be needing a set. :(
The stock rods are quite strong and don't see the as much side load as the rb20/25/26's.
I would think 300rwkw is a fairly safe number for a street driven RB that doesn't need to run stupid amounts of boost (due to det head) or over 6500rpm.
sorry, yeah i didn't think about that too much before i typed it.
my target is 350-400 ponies at the wheels (300kw or so) and i simply don't need any more than that. from all my calcs, i am pretty sure i'll only need about 14-15 psi at the most to achieve this (not from a turbo) so i should be right with stock cams etc. the rods i have are 300,000km old though, i am just not certain if i should get them cryo-treated (for stress relieving) and shotpeened or if i should just leave them.
the isky springs are $300-$350 a set i believe.
oh and from people who have actually done it, give me your opinions on whether or not it's worth re-routing the VCT and getting it working. bear in mind that i will be running an aftermarket ECU, stock cams and a blower which will have no lag so off-boost driveability is not a problem at all. (off-boost doesn't exist with this motor)
I hope ur not using one of those toyota whipple blowers. :Bang:
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
    • Yes, but no. I wouldn't want an IC7, because I think they are ugly, cramped and most of the displays I've seen are garish (and granted the last bit can probably be avoided). I wouldn't want to pay for the UC10. Probably wouldn't want to pay for the IC7, for that matter. And, it's an R32. I have cable drive speedo. Although, thinking about it, that's not a big obstacle, because at least I can throw the electronic sender back into the R33 box and then find a way to emulate the original (R32 or R33) speedo head's conversion of the saw-tooth AC speed signal into the square wave that the ECU wants, without the 1990s approach of hiding a gutted speedo head behind the dash. (another Arduino project, no doubt). I like the technical aspects of the big digital dashes, but I aesthetically and just general originality and feel-wise, like the original dash enough. More? Yes, more. If I had a UC10 I'd want to make the dash look as close to the original one as possible most of the time, and only flash up "DANGER TO MANIFOLD" when it needed to. But the other aspect of the 3-DIN slot digi gauge that I'm contemplating is that I'm a tinkerer and can barely resist a project, even if I don't need to add another to the list of unfinished ones. And I think there's enough precedent of others out there that have proven which equipment works (ie, is not washed out, or slow, or prone to failure, or all the other problems that can afflict such a project). I'm not quite enough of a micro-controller tech head that I know the best way to approach all of these decisions, and so striking out on my own to achieve it years ago would have led to unhappiness. But now, it seems like a project that I can actually achieve on the first or second go, with only a few sleepless nights. And that's why I'm actively thinking about it now. I would much rather have a thing in my car that I made from more-or-less scratch that does what I want, rather than something that someone else made that does some of what I want, not other stuff I want, and/or annoys me in some fashion. If I'm going to be annoyed, I need it to be my fault, so I know who to blame, and who needs to fix it. As an example of that - I have surveillance cameras at home. No, I did not go buy a kit with a DVR and 4 or 8 or 16 off-the-shelf cameras in a kit. No, I did not want to use any sort of could service to record or access the feeds and recordings from outside the house. No, I bought my chosen cameras directly (from China, lol) and built the DVR myself using a couple of different (ie, this was attempt 1 and attempt 2 to get a system I liked) software packages, running on Linux, with the server being a virtual machine running Proxmox. I found a way to offload the image recognition part of the system to a dedicated AI processing board (a Coral TPU, for anyone who cares) with the hardware passed through to the server on the VM, motion detection offloaded to the GPU, all storage is local in the home network, accessible from outside via my own self-hosted VPN). All done so that I could seal off the Chinese cameras in their own network where they can't access the internet and dial home to the CCP and backdoor my network. All things that you can't have if you do what is commercially available. And even with all the f**king around it has still cost a fraction of what it would cost to buy commercially.
    • ..could be worse... but out here, renting private affords some luxuries ...we've even been told the Sept dateline isn't critical, and I'd rather move stuff in the cool of winter, than slogging it out in the heat. Recall we were talking about the million dollar view this place has?...that's what he got for it... (won't be so nice when the quarry happens at the back in the future...lol..)... ...cool, I'll stick the wiper motor in a wee box...umm.... the pinny is GLX trim ~ I think that's about as close as it gets to Silo spec when it comes to the S2 pinny...ie; electric mirrors etc etc...dunno about the trip computer/wiring...I do electronics repair, I'd be willing to take a look at it for you. As you saw, all the dash is there in that car..and thinking about it, it'd be easier to pull the whole center section out, rather than just the ashtray and rails, but your call...
