The R32 RB25DE VRS kit is around $275.
It includes all top end gaskets consisting of inlet manifold gasket, plenum gasket, exhaust manifold gasket, rocker cover gaskets and valve stem seals. There may be more thats the most important one off the top of my head. :cheers:
If I was to buy JUST the valve stem seals from Nissan they wanted $330.. lol
  super26 said:
i have a question for you guys i have an rb30 block and a rb26 head i want to put them together is it possible if it is how do i go about doing it and where do i source the parts to do it thanks alot.
dude... you've got 99 pages here which pretty much give you the ins and outs of exactly how to do it. There is also a guide floating around (i think Cubes did it). Infact there is a link in his post above this!
Andrew
I thought I'd update ppls..
Loading up say 4th gear at 1500rpm starts to see boost quickly then it goes flat and the turbo sounds strange, if I hold my foot in to it the turbo starts to make a really strange noise (almost a popping noise) then the car begins to jerk around. nasty pasty. :)
I have never actually held my foot in to it when it has that flat feeling so I haven't heard the popping or felt the jerking before. Never again will I do it. Sounds really bad.
Not to worry, its never really in that zone anyhow. :cheers:
A good excuse to pull the little terd off. :D
Welcome to the world of compressor surge:cheers:
Andrew
thanks alot for your help, wha tkind of power have you seen this conversion produce, i am living in the united states and there is not alot of people that do these kind of conversions so i jus wanted to try something new, again thanks alot for your help guys.
What, you guys had enough of buying every sr20 on the market and driving the price up for the rest of us? Want to move onto something else to overvalue do ya?
(not that i won't sell you a rb30 short motor...)
guys...
if i through a rod in my 25det could i just bolt on a rb30 bottom end?
would like to keep compression same maybe a bit lower...
im running 18psi through standard motor and i know it will fly apart soon, hahahaha
any help would be great
thanx
This would have to be one of the longest threads I've ever seen and by far the most useful.
Cubes and Sydneykid have been saying for quite some time that cams should become before upgrading the plenom, in particular TOMEI 256 cams. I have a Rb25 head with VVT that is ported and polished (mirror finish).
Has anyone used these cams in a 25/30 and has dyno results to show?, I'm interested at looking at the mid range Hp and Torque.
http://www.modyourcar.com.au/product_info....roducts_id=3661
Or just email sales@modyourcar.com.au as from memory Arias do make forged RB30E pistons.
Being a former sponsor of SAU, Dan and the team will do you a decent price on these!
  Looney_Head said:
i am sorry if this has been asked but can you use SR20 pistons when building up a rb30det?
and does anyone know a good place to get rb30e pistons from.
thanks
I've read about using sr20 pistons in them before, Blue r33 with 26 head 30 bottom that was in nzpc a while ago was using them. I'm still not sure why anyone would do this in preference to using forged 30 ones, needing to buy two sets of sr pistons bumps the cost up a bit.
A bit of the topic, ive got a rb30det in my R32. Has a stock bottom end with a R32 RB25DE head. Ive got an old school t04 on it with a smaller exhaust housing. Its running out of puff around 300rwhp.
Just wanting to know what turbos u guys are running and the power your making, and how the driveability is with them? Im after something that will produce 450rwhp with a good power band?
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
