  StockyMcStock said:
p.s. where do you get new studs for them from? they have two different threads on each end :confused: which is weird, i imagine they'd have to come from nissan..... i shudder to think of the price
I bought 2xRB30 studs from Nissan, it's only $5.
I'm not using the smaller studs where the spring sits up against.
Just wondering, has anyone pushed an RB30DET hard with a standard exhaust manifold from an RB20? I *think* i can get a GT35/40 1.06 rear on the thing without hitting the strut tower (VL bogandore) but am a bit worried that it will be horribly restrictive.
Porting the heck out of it might help though, so has anyone done it and achieved good results? external gate will be going off the turbine housing.
p.s. looking for a maximum of 300rwkw at the absolute most.
i've seen them, they look similar to the standard ones :unsure: can't see them being a whole lot better in terms of performance? anything that just adds the cylinder outlets into a single log one by one is not really going to be that great IMHO, not compared to individual runners with a collector right at the turbo.
a spacer plate will definately be needed, yes.
They are better designed due to the fact where each runner meets, the internal diameter of the runners grow, not like a single log at all really, like the std manifold is.
more explained here: http://www.skylinesaustralia.com/forums/in...c=78681&hl=cast
do a search, cos they are better over std imho
Today I rang Nissan to get a price on an R33 RB25DET oil pump.
I was told that in the R33 series there is 17 different types of oil pumps (rb20-26). There are also more than 2 different oil pumps list for the 25det. I'm not sure which one to get and which one would fit.
I've read back through all the pages and know that the later R33 RB25DET requires the JUn adaptor, I'm after the direct fit pump.
I was asked for a chassis number so the right oil pump could be matched to the engine, I dont have a skyline so that would be rather difficult.
If anyone could pass their vin number or the part number onto me who has used their 25 oil pump on a 30det would be much appreciated. :P
i work at a nissan dealer and can get most of the parts at near cost so if yas need nethin just pm me and we will work it out.
we used a R33 N1 pump on a mates vl turbo and its mint compaired to the vl 1.
i think the pump was like 480 or sumfn
rrb25det 1ns are bout 435 i think,
Hi,
If one was to obtain the series 1 RB30 block without the holes already drilled and tapped for the turbo oil and water lines. How much work is required to do them? Is it a hard job basically?
Anyone done it before and had success?
Thanks for your time,
Scribble
Hey everybody, rather than create a new thread i thought i should just ask here seems rb30det's is the subject. Just curious how reliable these engines are, if built by a workshop. I know to an extent it relies on the ability of the workshop, but say a very well built rb30, how will they hold up compared to stock rb25s? Do the problems multiply a lot faster than in a stock rb25 if the boost is raised? Thanks for your help, it might sound stupid but i have been wondering about it for some time.
Scribble its quite easy to do. The water lines are there the tubo feed and return are not. With the high pressure you need to take the filter off and put a slot in the top of the thread where the filter bolts on you then get a really big flat head screw driver and remove this thread ( it is like a stud). Okay then go and buy a long drill bit froma specialty store, I used a 4.5mmx 250mm long drill bit and started from the turbo side of the engine and drilled through, you will find cast is quite soft but be very deligent using wd as a lube and not going down to hard or coming back out... you will need to come back out quite often to get rid of the built up metal...I used a cordless as its easier to go gentle on.... For the return you need to center punch the flat spot and drill it out and keep stepping up the drill. Tapping it is quite difficult as its damn big, I used 3/4 bsp tap its a 2 man job to get the thread started but after that you home and hose!!!!!
Cheers Formaly s13drifter.
Hopefully one of these years i can buy one of your sump adapter plates to make my dream come true!
I might be picking up an RB30 with a blown head gasket for rather cheap this weekend. I heard they come with the holes already tapped just with bolts in them? But it was only the VL's that didnt.
drill in from the turbo side until you see/feel the bit go into the high pressure gallery on the other side, direcly opposite the oil filter. this is the main high pressure gallery where all the bottom end bearing supply galleries are connected to. it's about 15cm worth of drilling IIRC.
p.s. if you're in brisbane i have a FREE series 2 block (all bores are fine) which you can come and grab - it will be easier than getting the holes drilled and tapped trust me, i had to do it!
Edited by StockyMcStock
I built one 5 years ago, it made 475 bhp on the engine dyno, it is still going and is up around 70,000 k's now. It has standard RB30E everything and a standard RB25DET cylinder head that was ported. The big advanatage with 3 litres compared to 2.5 litres is you don't have to use the same high rpm to get the power. Lower rpm = longer life. Keep the boost down, tune it right, service it regularly and a 475 bhp RB30 will live longer than a 475 bhp RB25.
:rolleyes: cheers :unsure:
Scribble: a "damaged" bore would normally be in the order of large, deep scratches in the wall of the cylinder. anything you can get your fingernail into is too big in my experience!
however, an out-of-round bore is almost as bad. the bore wears in an oval shape, as the rods "push" the piston to the lateral sides of the bore on each stroke. check the out-of-round specs with a dial guage of suitable accuracy, if it's greater than factory specs then you need to bore the cylinders out to a slightly larger size so that they are exactly round again. this obviously needs to be done in a machine shop!
SydneyKid: i'm planning on keeping the standard cams so my rev limit is going to be about 6200rpm where i hear they start to nose off. hopefully it will last as long as your engine has, that's quite a feat for an engine up around 500bhp. i don't think mine will be spending much time up around that rev limit either, it's a twincharge (GT40 turbo + Eaton M90 blower) so with bulk torque available everywhere i think it should be OK for a street car.
My bores as i can telll are about 85.6 to 86 each bore. Im thinking about getting them bored 20thou, would this be enough to make them circular again? and would this increase capacity?
No visable scratches but will see when i pull her down.
Sorry its my first engine ever.
Scribble
get an engine builder with a nice accurate dial guage to measure them properly for you, there's not much margin for error in bore sizes!
the idea with boring is to bore the cylinders evenly out by the same amount, which should be the smallest amount possible. 20thou will do it i would say, pretty easily. yes it will increase the capacity of the engine, by a bees' dick.
:) cheers  :D
Thanks heaps for the info, ill leave you guys to it. Cheers
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
