would standard pistons and rods be good for 300rwkw?? i am looking to run a rb30 with stardard bottom end
rb25de head gasket
r32 rb25de head with rb26 valve springs, gtr cams and standard manifold.
what sort of turbo would be best for 260-300rwkw, i am thinking a holset hx35 or a garrett 3040.
does that sound like a good idea. i would like any feed back people have
thanks
it's been mentioned in this thread that the GTRvalve springs can't easily be adapted for the rb25de head.
it would be easier to use the 25det valve springs.
it also been said that with GOOD tuning and supporting mods, keeping boost low, with correct sized turbo, 300rwkw can be achieved using stock na pistons and rods and stock gaskets.
but constant high revs will destroy the stock rods.
not sure about GTR cams in teh 25de head either.
standard manifold is ok.
turbo selection..... I don't know.. not up to scratch with my turbo knowledge in terms of what power the turbo's you've said will produce and at what boost levels.
I think you'd need to be a bit more specific with things like exhaust wheel size and so forth.
When you are talking about "stock pistons" and "stock rods" are you guys talking about having the bottom end rebuilt and using NEW stock pistons/rods, or using old ones that have done 150-250,000 KM's?!
it seems the "search this thread" option is no longer available.
however, SYDNEYKID had stated that GTR valve springs are not a direct replacement for RB25de heads.
it was due to the lifter in 25 heads not being the same setup as the 26 head.
he mentioned that in his first RB30 build when he used the 25de head from an R32, he changed the valve springs and used 25det valve springs.
maybe he'll see this post and confirm or correct me.
Yes GTST, I understand that. As I been re-reading this thread alot of others, and I'm sure you'd understand I am trying to seperate people's primary observations from second hand information.
Id asked this question before.
How does the ECU tell what gear the manual gearbox is in?
I have a sensor on 1 front wheel which picks up 5 pulses/revolution. You then calculate how many pulses will occur in 1km and enter this value into the sofware. You work out what each gear ratio equates to in kmh/1000rpm and enter the results plus the required boost correction for each gear and plug this into the software.
The ecu now has a speed reference via the wheel sensor in km, and by using the kmh/1000rpm figures plus the engine rpm it can determine which gear you're in.
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
