I've used stock as I'm only after up to 300rwkw.
Sky30 is running a complete stock bottom end and has been running slightly over 300rwkw for some time now. :D
Also.. With regards to strut tower braces, I was looking at a cusco that very well may do the job.
Edited by Cubes
just wonderin where you guys got your oil pump gasket? Have tried all the usuals like repco, sprints, motormate and supercheap and in all their books it doesn't seem to list them, any help with this would be greatly appreciated.
Had my engine booked in for this friday to get the finishing touches but it looks like i might have to change the dates because i'm having a bit of trouble finding a secondhand series 1 Rb25DET oil pump, Getting the gasket for the oil pump and there's been a bit of a delay with getting my VRS gasket kit for Nissa (Japan) should hopefully be here this Thursday though!
ARGH! :D the drama's of building an engine, fingers crossed it'll all be worth it! :)
What spark plugs r u guys using in your 25/30det combo or what ones would you recommend?
also does anyone have the part number for a SERIES '1' rb25det oil pump or any differing numbers/markings to the series2?
Edited by mr_rbman
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
