I have 2 adjustable tensioners, but no matter which way i adjusted them, i couldn't get them right. The first hole i drilled went straight into the water gallery so i drilled and tapped another further from the centre of the block. In hindsight, the first probably would have been ok with some locktite, but i didn't want to risk a water leak at the time.
I have an R33 head and the VCT gear is adjustable from behind, and i bought an adjustable exh gear. Hopefully problem solved. Well i spent a weekend dialling in the cams, so it better be solved!
Sky30, it's a 5 speed manual.
RB25 n/a head, GT35/40 turbo, 19-20psi
Youve got to be kidding me right ????
What specs are you running ? 270k km and 20psi with gt3540 ???
I got my rb30det which has done about 30,000km so far with a smallish turbo now I too am going the GT3540 .82 with tial 38mm gate with a top mount manifold and 740cc injectors (still off the road)
Got some questions for ya...
When does boost come on ? is it laggy ???
How does it sound ? :P
got any pics??? be very keen to find out more
Do you have .82 rear ? when do you get full boost by ???
whats you fuel economy like??
tell us abit about it..
thanks
How does it sound ?  :)
thanks
Why would i have to be kidding???
Its .82 rear housing, makes 20psi at about 3400rpm.
Can anyone help me find a set of forged pistons for RB30 that can give me a CR of 8.3:1 or more?
was looking at ARIAS but not even rocketindustries have them in stock atm, they only have the flat top piston that give 8:1 CR, any idea how this would drive?
Anyone selling these or CP, or Wiseco?
Im thinking of adapting the rb25 oil squirters to the rb30 block. Im just asking if anyone had any pics, of a rb25 block with the oil squirters removed showing the whole location. (I have looked at Cubes guide).
Or do u think I’m wasting my time trying to make them fit or is it just impossible.
It'll be in an R31, heh.
Anyway, I have an R32 RB25DE loom and RB20DET ecu on the way.
Should be able to get the RB25DE loom if necessary.
so the rb20det computer will be able to be tuned to suit the rb30 with no problems whatsoever?
i suppose the rb25de runs top feed injectors also? will this also be fine if you upgrade to gtr injectors? and i then presume a z32 afm is necessary (if not a q45)
the rb25de injectors are them same style as rb20 and rb26 injectors!
Rb25de injectors are rb20det injectors. :P
Same part number, same flow.
I ran my RB30DET in on the stock RB20DET ecu, it couldn't handle any more than approx 6-7psi as it would fuel cut.
What did you do loom wise with the conversion? I thought the extra capacity of the head may confuse the power fc
Cars are very simple.. The measure how much air enters the motor then puts in say 1 part fuel for every 15parts air.
As a result.. the car runs fine on the stock ecu. Obviously limited as the RB25 head flows so much more air, as a result I was hitting fuel cut.
The PowerFC handled it quit well. AFRs were pretty much spot on, light load didn't need touching. WOT required a small tweak of afr's around 3500rpm - 5000rpm. Ignition timing had to be pulled out a little due to the back pressure the stock turbo caused on the 3ltr.
After putting the VG30DET BB turbo on its taken another 6-7degree's ign. timing at wot.
With regards to the higher RB30 block, how much of this affects the piping around the engine. For example, intercooler piping, exhaust manifold and dump pipe, radiator coolant piping. How much of these needs to be modified due to the higher RB30 block?
My std IC piping actually fitted much better; like it was meant to be. :P
Radiator hoses are not affected.
Exhaust manifold is not affected, how can it be?! :P
Dump pipe obviously needs modification as the motor sits slightly higher. I paid $60 or something and had them cut and weld in a little spacer so to speak.
It all drops in and bolts up much easier than you would expect.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
