why is everyone strung up on the damn strut brace.
Make new ends to offset the bar across the engine to clear the tb.
If your building the engine, you have to cut and weld the engine mounts, so whats hard about making new strut ends at the same time??
possible issue with making the strut brace higher is that i know my strut brace had rubbing marks on it from the std bonnet.. so i know i wouldn't be able to make the strut brace higher ..
saying that i am hoping i wont have an issue with the plazmaman front facing plenum.
yeah my rb30s now fitted. i didnt need to mod the engine mounts. just a slight hammer on one of the under bonnet supports. looks damn sexy.
should have it running on thursday :(
now only if it would stop raining so i could go outside and finishd changeing the fuel pump :)
yeh but how rigid is it going to be ?
I haven't seen any pics either.
See pic below, can't move it forward with the RB25DET head, have to go right back against the firewall.
Useless...
Edited by conan7772
Same as the bar was before, or make it better. :blink:
I havent posted pics, but whats so hard to picture about it??
Your simply offsetting a bar forward, not making great structural changes
This is what came out of the rb20det gearbox + lots and lots of large chunks of teeth, be buggered fishing them out of that stinky oil. :O
Drain Plug
The back of the tooth where it broke
The mesh side of the tooth, looks as if the engaging gear was really digging in and not meshing with the whole tooth. :S
The new box is very very quiet.. Feels quite strange, like a new car. :P
Thats a fatigue failure as you can see from the close curved lines across the broken face and the rough area to the other side of the break.
Starts somewhere about where I've marked as best as I can discern from the photos.
Just couldn't handle no more Cap'n
This pic illustrates the close curved lines a little better.
Sorry Geoff.. I don't follow the Cap'n... :O
Do you mean repeated high load that attempts to and may very well slightly bend the teeth every time?
A little like breaking a coat hanger by bending it repeatedly.
So definitely rb30 related?
Same as the bar was before, or make it better. :D
Can't go forward.
There's nothing between the induction pipe and the bonnet.
Running a bar behind the BOV is too bigger an offset.
It will flex under load i.e USELESS.
What head do you have ?
This is what came out of the rb20det gearbox + lots and lots of large chunks of teeth, be buggered fishing them out of that stinky oil. :D
Drain Plug
The new box is very very quiet.. Feels quite strange, like a new car. :D
Gees you got that in quick !
What did you pay for it ?
Can't go forward.
ive got the 25de head, and you can move it forward.
edit/ im not going to argue about it, but in a 32 it will fit
Edited by Bl4cK32
hey guys...my rb20 just blew up..and im considering doing this conversion as i have heard its a great upgrade....just one question though...i have a rb20det power fc...but if i do this conversion i want to run the rb26 head...will my power fc work with this head (i dont mind if i have to rewire a few things) i already have modded the wiring loom for stock gtr injectors. any help would be good
cheers
It will work fine providing you stick with a single afm.
The only sensor that 'may' not be used is the intake air temp sensor, I am not 100% sure what pin or if it indeed can be used with the rb20det pfc.
SK has said it has or can be done? Not completely sure.
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
