taken from Pauls power FC FAQ ..
http://members.dodo.com.au/paul/docs/power...erfc-faq.htm#41
"Airtemp sensor on unsupported car?
Some PowerFC's have support for the AirTemp sensor under MONITOR but the car itself does not utilize a factory air temp inlet sensor. I attempted to hook up an airtemp sensor on my ECR33 PowerFC and fried the powerfc and damaged a sensor on my car. The concept was to look at which pin on the BNR33 PowerFC the air temp sensor was connected on and then try and replicate this on the ECR33 PowerFC. I tried this and it did not work, I tried an adjacent wire and it fried the PowerFC. It has since been fixed and all is working but I do not recommend you try to get this working. It may work out costly like it could have been in my case. "
Yes this mod works fine for BNR32 + HR32 PowerFC. Only ECR33 PowerFC it goes bang
haha yeah good idea
shoulda seen the look on my face when i had pacman characters running around on the hand controller screen and pshyco ticking noises coming from the powerfc
im sure that would have been followed by some VERY colourful words :lol:
hey guys. im new to sau, but i jst thort id thro my 2c worth in... im currently building a rb25/30 setup, using a complete factory rb30et bottom end, crank rods and pistons, rb25det head, my current hi flowed xtr turbo,850cc powerflow injectors,haltech ecu, rb26dett water pump, stock oil pump, thru a r33 gtst manusl box...iv been told it will be good for 3/320rwkw...duz this sound rite 2 u?
If it's a high flowed RB20DET turbo it will run out of airflow at around 260 rwkw
If it's a high flowed RB25DET turbo it will run out of airflow at around 270 rwkw
If it's a high flowed RB25DET Neo turbo it will run out of airflow at around 280 rwkw
That's not your main problem, the RB30ET pistons with an RB25 head will have very, very low compression ratio (in the 7's). That's why we use the RB30E.
:P cheers :(
Edited by Sydneykid
with the rb30e, are the stock rods and slugs strong enough to take the beating? or a $2500 aftermarket jobs the go? think cheap, thats wat im trying to do.... i know i know, cheap usualling ends up being "cheap", but i dnt av THAT ammount of money lying around atm...
I just want to build a torquey motor, turbo upgrade can wait. so 270kw? a the wheels im guessing? why did this guy tell me 320? is he just having a wank? or is he just trying to get work from me?
This pic illustrates the close curved lines a little better.
Sorry Geoff.. I don't follow the Cap'n... :rofl:
Do you mean repeated high load that attempts to and may very well slightly bend the teeth every time?
A little like breaking a coat hanger by bending it repeatedly.
So definitely rb30 related?
Sorry mate, I missed the question. Wasn't meaning to be rude.
Basically all steel things have a fatigue load limit. Below that load you can load infinitely (faults notwithstanding) and it won't fail, but increase the load, or in this case torque, and eventually it will start to crack slightly more and more each load cycle until the cross sectional area holding it is too small and just lets go, like the coathanger.
The rb30 vl type blocks dont have oil squirters. only the rb20,25,26 have them. a lot of ppl put the rb25det squirters in the rb30 conversions tho...
It's a bustard of a job (= costly), and only about 2 in 10 RB30 blocks are suitable. Ceramic coat the piston crowns and oil retention coat the skirts, just as effective.
:rofl: cheers :D
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
