just thinking about the volumes of these return lines, if the volume gets too high it might cos a block
in the system and not allow the oil to return fast enough.. just a thought.
Well yer thats the idea behind it. BUT realistically have you seen the size of the turbo's oil return?
Have you seen the size of the heads internal oil return?
Its massive. >_<
I really don't think the T'ing in is the issue, I think its the overall setup. Oil pump used + oil restrictors used.
All the ppls I know of that are or have had issues is due to the oil restrictors.
My tuner has recently done a VL rb30/25 that had the same issue, he's in the process of ripping the head off and dropping smaller restrictors in it.
3/4" is about 19mm or 19.05 (if your a fitter'n'turner) which is a pretty bloudy big ID. So assuming that running nothing higher then a normal det oil pump and some form of head restriction or not?? T'ing into the return is prob gonna be ok. In the case of running a N1 oil pump or a/m equivalent with no head restriction and T'ing into the return will probably (no exact proof yet) cause some sort of return restriction. (based on Joels comment about the T'ing)
So in the case of that setup occuring then the most likely and easy fix is to give the head return its own bung and line into the sump somewhere. Otherwise it will be time to remove head and put restrictors in.
Everyone else agree that would be the obvious fix/mod to rectify or prevent that problem from occuring.
In my own engine Im going to run restrictors/the std head return into the sump/another return from back of head into sump and hopefully that will be enough to manage the oil control problem.(race car though) needs to be overkilled.
yeah, i have to braze (could be braise) a lug into the sump for the oil temp guage anyway, so i'll just pop another one in there for the head return, better off not risking it, if it COULD cause an issue.
once its in, i dont wanna take it back out lol :laugh:
Craved,
RE: Heater Fittings.
I'm not sure I know what you mean, any pics?
The RB30 block requires you to screw out (rear of the block drivers side) the rb30 item and screw in the rb20/25 item. You are also required to remove the pressed in water connection located on the thermostat housing as the rb30's item is once again different.
These parts can be had from nissan new, they are cheap. :laugh:
Thats the only heater hose block attachments I can think of.
Pic attached is of the rb30 block with the rb20 rear heater hose attachment (as can be seen to the left of the green knock sensor and the other water hose attachment poking out of the thermostat housing.
While on the topic of heater hoses etc... PLEASE AVOID GROMMET rubber hosing/fuel hosing at all costs.
Its total crap, my grommet efi fuel hose began to crack after 1year and another grommet heater hose I used became very very hard resulting in slight coolant leaks when the car was viewed first thing in the morning.
HAHAHA well arent i silly .. as i only have bare block, i think i was refering to the knock sensors .. the green things near 5-6 and 2-3 Cyls.
cant see on my car what they connect too, and they look like hose connections..
well the info on the hose connections on the thermostat i didn't know..
GROMMET - is that a brand or a type of hose?
and..... a few pics from tomei.
And where to get them from..... Greenline appear to sell them for 500Y.
Thats... 500 Japanese yen = 5.78345824 Australian dollars + postage. Sucks when postage is worth more than the item. :laugh:
Postage to aus via ems is $18.50 aud. :laugh:
lol.
yes Grommet is a brand of hose. Supercrap sell it. :laugh:
hahahah. yeah .
im using 600psi hydrolic hoses for everything .. from Enzed :laugh: think they are coated for use with fuels.
think i'll wanna replace every water hose in my engine bay, after the turbo install i had 3 lines bust.. hate trying to fix them.. always hard to get to!
oh dear hahaha... wonders if some one bought a large amount, the cost of shipping would be heaps cheaper..
and yes, hate it when shipping = more... could just use normal envelope for these though lol
just checking if the ones for RB26 will fit the rb25, as none listed for the rb25 on greenline.
Edited by Craved
I will grab a few things at once if thats the case.
I NEED. lol <looks around to see if the other half is looking, nope, ok quick type>
PFC 60cm extension cable $13.80
PFC Boost control kit $355.37
2 x tomei restrictors $11.56
+ ~$40 postage.
I've done quite a bit of searching. It looks as if the std tomei rb26 headgasket doesn't include a restrictor. Its ONLY the headgasket kit that does. The Headgasket kit also includes manifold gaskets. :laugh:
+ ~$40 postage.
Hahahaha yeah, i hope i dont need anything else thats the thing. and where are you taking the PFC controller to need 60cm more lol i find the std ones too long :laugh:
*runs to check greenline just incase :laugh:
I've done quite a bit of searching. It looks as if the std tomei rb26 headgasket doesn't include a restrictor. Its ONLY the headgasket kit that does. The Headgasket kit also includes manifold gaskets. :P
always under the inpression the tomei one came with it, i like how greenline shows the CR change with each of the different gaskets . good info to keep for working out what CR i'll run later.
The reason I want the extension is so that I can easily remove the h/c and plug in a datalogit. :laugh:
off topic but...
Here's a good thread regarding piston oil squirters. :laugh:
http://gtr.co.uk/forum/upload/showthread.php?t=36648
It doesn't really show anything we don't already know but there is a few interesting bits. :P
off topic but...
Here's a good thread regarding piston oil squirters. :P
It doesn't really show anything we don't already know but there is a few interesting bits. :)
Ahhh yes, datalogit would be awesome to get.. i still have to figure out how to turn the closed loop back on on the pfc.. things its in etc and the top one. but not sure what the jap symbol should look like..
only reason i think its not on, it because the AFR guage doesn't "bounce" when cruising like it used to..
hmm more reading, i should be working lol :laugh:
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
