RE: Patrol RB30
As far as I'm aware they are the same RB30E SOHC.
What is it exactly that you want to know?
Let me try a few guesses...............
Was there an RB30 used in Patrols? Yes
Is it the same as RB30 used in Commondoors and and Skylines? Yes
Does it have oil squirters? No
Is it a 4wd block? No
Are they cheaper than Commondoor RB30? No
Are there more of them than Commodoor RB30? No
Are they rare? Yes
Would I bother searching out for one? No
Hopefully one of those answered your question.
:) Cheers :yes:
excellent ..wow..thanks both I knew if i couldnt find out here then NO ONE would know...once again SAU ....u never let me down.
The reason i ask SydneyKid (Gary?) is because im not in Australia...I'm in Jamaica...if i ask someone to source me RB30 from a GTS they're likely to want to jackup the price on me because of the even the phrase Sk-...if i tell em oh get an old nissan patrol 3.0 carbed engine....they might not be so greedy :) . If they have none here..am I likely to find the RB30e in Japan?
wow respect again for the info. You guys ever think about writing a skyline bible :P
*For R32/R33 with VCT blocked off:
Sydneykid says use a 2.0mm restrictor and block the other one off.
Cubes wants to use 2x 1.5mm holes
If the RB30 has 2x 1.8mm holes, I wonder if only 1x1.8mm hole was
used whether it would be enough???
*For R33 with VCT working:
Sydneykid uses 1x 1.5mm hole and the standard VCT port
MonstaS4 uses 2x 1.5mm holes and the standard VCT port
All that happens if you dont use them is more (too much?) oil gets pumped into the head than is needed when it is better off in the sump!
Edited by VHR32
thanks for all the info guys and good timing to as i am just finishing getting all the parts togewther for mine.
do we have a similar summary for oil pumps and which is the recommended one except for the rb26 n1's and aftermarkerts. eg rb30e, rb30et, rb20de, rb20det etc etc
I'll add to this my experiences.......
RB30 with R33 25 head. VCT enabled.
On the oil drain issue - head oil return is plumbed into the turbo oil return. Engine has been in and running for nearly 18 months without issue.
On the oil restrictors - I originally built the engine with 2 x 2.4mm restrictors plus the 1.2mm or whatever the VCT is. I had heaps of oil out the breathers if i maintained 4000rpm+ for 5 seconds or more.
About 4 months ago i purchased 2 x 1.5mm Tomei restrictors from Greenline. Punched the old ones down and put the 1.5's on top. So yes they fit the RB30. Oil blown out the breathers is now virtually nil. I did get a little (200ml) after a maintained high speed/rev run but otherwise i haven't checked the catch can since.
1 X 2 mm restrictor = same oil flow as 2 X 1.4 mm restrictors
2 X 1.5 mm restrictors = 12% more oil flow than 1 X 2 mm restrictor
The 12% extra flow is why you get oil in the catch can
Hence why we use 1 X 2 mm restrictor, as our cars see lots of continuous high rpm
Also why I don't recommend plumbing the cylinder head external oil feed into the turbo oil return. Driving around town it doesn't matter, but continuous high rpm and it does.
:O cheers :devil:
PS; (for others) the restrictors go in the block not the head.
1. sydneykid when would you consider it worthwhile to do this (oil restrictors). at what power level etc
can you also give me some advice on what size external wastegate would be required for 20/25psi boost. some people say a 38 is mine however others say 40/45 is needed.
would you reccomend cam gears to be done as part of the engine if im doing the forged pistons you reccomended. i presume you get hundreds of pms but we talked re a t66, any luck on pricing?
Suggestions follow;
1. Power level is irrelevant, it's all about how many rpm you use and for how long (continuously) you use that rpm.
2. Some time ago I published the formula that we use for sizing wastegates. I then compared the results from using that formula with over 40 wastegate sizes done by many turbo and other workshops around the country. The results confirmed the accuracy of the formula, with over 90% alignment.
Airflow in lbs per minute = diameter of wastegate in mm X boost correction factor
Let’s use the formula on my own RB31DET
The target is 450 rwkw at 2 bar
450 rwkw = 700 bhp
700 bhp = 70 lbs per minute of airflow = 70 mm (if I was using 19 psi)
I am using 30 psi, so we need to apply the boost correction
70 / 30 X 19 = 44.3 mm
GCG recommended a 44 mm Tial wastegate based on their experience.
This the original thread if you want more details;
http://www.skylinesaustralia.com/forums/in...showtopic=43638
3. PM me about the turbo, there are a few alternatives with the new releases of aerodynamics from the T04Z work.
:) Cheers ;)
Edited by Sydneykid
thanks for your information sydneykid. all your information regarding everything is absolutely invaluable. id hate to know how many engines have been successfully built with some of your information.
im glad i read this thread as my engine would have otherwise been assembled without the restrictors and i probably would have gone with the bigger is better idea rather than listening to any form of reasoning in respect to the wastegate.
where is a place (other than greenline) that you would know of that would stock these restrictors, or is it simply a case of someone being able to fabricate them?
at present my blocks in pieces as is the head waiting to be sent off for some boring. when i get that back ill assemble it all and get back to you regarding a few questions then we can talk turbo. i look forward to it.
As I mentioned earlier..
Hi Octane Racing Australia
www.hioctaneracing.com.au
$15 each inc. gst + postage.
thanks for that
i read in an earlier thread that you were looking at doing gtr valve springs. i was looking at doing the same then read they also werent all that great.
i then called kelford camtech(im in nz) who do most of the countries top head work. they mentioned there are 3 types of valve springs for the rb25 head which i found interesting. they are 10 dollars dearer than the gtr items from nissan.
they are made by an australian company called performance springs and the quality is meant to be very high.
anyone got any comments on how many kws on a 300 kw engine can be made by cam gears finely adjusting the cams?
anyo
Edited by SirRacer
I've been told to steer clear of aftermarket aussy valve springs by many.
Allen engineering, Chris Milton Engineering and Boostworx to name a few.
I was told to either go s/h gtr springs and have them tested or grab a set of aftermarkets from japan.
I went the s/h low km R33 gtr valve springs. Cost bugger all and are all perfect. :rolleyes:
can someone confrim the sentance below re head bolts
"Use a set of 10mm standard RB25DE head bolts. They fit the RB30 block and are the correct length for the GTR head."
i dont want to retap the block until i rebuild it
pete
Edited by fatz
i know the rb25det head bolts go into the rb30 block..i would assume the rb25de ones are identical. 10mm x 1.5P or 1.25P not sure its probably the later being its going into steel so a fine thread is probably ok. Without checking, my money is on 10mm X 1.25P.
I believe next metric size up is the 12mm bolts which are called half inch. So if your gonna retap it, are you gonna oversize to half inch?
I dont know if the rb25de/t head bolts will work with a gtr head. I would say you would just use the ones that came off that head as its the height of the head that matters..so long as the thread size and pitch is the same you should be laughing.
Question for your question, Doesnt rb26 use half inch head bolts/studs anyway? Isnt that why you have to drill and tap out the block to suit the 26's larger headbolts? A 10mm in a 12mm would leave alot of slop.
iI believe next metric size up is the 12mm bolts which are called half inch. So if your gonna retap it, are you gonna oversize to half inch?
RB20/25/30 = 11 mm
RB26 = 12 mm
There are 12.7 mm (1/2"), it's a common size for small block V8's = cheap
:D cheers :D
Edited by Sydneykid
ahh so half inch studs/bolts actually are close to half inch..not just closest metric equivalent full value.
I swear someone called the 12mm head bolts/studs half inch even though half inch is 12.7mm.
Isnt 11mm an odd size since most bolts and studs come in multiples of 2 unless you go relatively small.
Yep, that's why the 11 mm studs are expensive compared to 1/2". The 12mm ones are expensive because they have RB26 written on the box.
:D cheers :D
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
