Yeah i have read some... Its just that its so damn big, there's so many different conversations about what i wanna know its all just a little confusing... Basically, i've got a perfectly good RB30ET block with f**k all km's on it, im planning on puttin the R32 RB25DE head on it with all aftermarket bolt on's... I just wanna know whether the E and ET blocks are basically the same and whether i just need to use the RB30E spec pistons to get the appropriate compression ratio??? If not, what would be best???
If you are thinking about putting the head straight onto the rb30et block standard then it wont work. HOWEVER if you change the pistons to the NA spec then it will be ok.
The pistons in the rb30et are too low compression and the NA pistons should be used.
If you rebuild the rb30et block and put forged pistons in it to raise the compression up to the same for NA then it will be good.
Guys the RB30 vented coil pack covers are going to be cut soon any suggestions as to what is going to be on there would be great i have come up with at least a few say 2 or maybe 3.
"RB30 DET"
"RB30 DOHC"
"RB30 TWIN CAM TURBO"
"RB30 GODZILLA" for 4wd ones :wave:
"RB30 TORQUE MONSTA"
"RB30 DET"
"RB30 DOHC"
"RB30 GODZILLA" for 4wd ones :dry:
Maybe a "RB30 DOHC TURBO"
or " NISSAN 3000cc DOHC TURBO"
What did it say on the stock RB20/25 covers before?
r32 rb25de head stock with det valve springs big front facing plenum 80mm throttle body q45 afm. bottom end stockish rebuilt. shot peineed rods, and aftermarket rings, crank collar, either rb25 oil pump or n1
what would this turbo go like on it?
called a gt45
Inlet (Exducer/Hot Side) T-4 Flange 70.1mm x 82.55mm (2.76" x3.25").
*A/R 1.05 Exducer
*A/R 0.66 Compressor
*Cooling/Lubrication Oil
*Outlet (exducer/hot side) 4.25" V-Band
*Inlet (compressor/cold side) 109mm (4.25")
*Outlet (compressor/cold side) 86mm (3.38")
*Compressor major diameter 98 mm
my goal is 400-500rwhp. On a 20det modded manifold When would this size turbo start spooling and when would it hit full boost? 15psi. unsure of what exhaust manifold yet, either a 20det stock modded to fit the t4 flange or a whole custom mild steel one.
Can anyone help with some info on this? is this turbo 2 big?
Thanks
called a gt45
*A/R 1.05 Exducer
Thanks
Too big, by a long way.
:D cheers ;)
PS; Shot peening used RB30 rods achieves almost nothing, spend the money on a set of ARP rod bolts
"RB30 DET"
"RB30 DOHC"
"RB30 GODZILLA" for 4wd ones :)
how about "hey mr. policeman, i want a defect" :)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
