Shane, only way to know for sure is to call Kyle and ask him about it. Im pretty sure he would be able to do it. Hes a nice guy and easy to get along with, im sure he could do something for you.
0410730598 - Kyle 6BOOST Manifolds
Um Kyles manifolds arent stainless steel...they are just plain mild steel...unless he made a one off special for you or something. Hes totally against the use of s.s for manifolds. But they are of awesome quality, im very impressed with it so far.
yep steam pipe, thats why i wrote in my post "not thin stainless" sorry if i didnt make it clear meaning that i didnt have one in stainless... as u can see in the pic, perfect quality
ben...
Edited by 2BNVS
Ok can someone tell me what their version of steam pipe is? Cause in boilermaking terms steam pipe is chrome/molybdenum pipe used in power station boilers. Now the manifolds, in trady terms are sure as shit not made of chromemoly pipe. They are just mild steel pipe, where the term 'steam pipe' comes from is beyond me. Someone enlighten my humble metal fabricating brain please :)
Cause im getting confused here.
Cheers.
ok well once again, it wouldnt be a steam pipe...it would be a mandrel bend. So im lost. Yeh shane, that pipe aint heated up with steam and bent. In most circumstances the name of the pipe comes from its main application in its line of work. Unless there is something ive missed i think this is just a case of mismatched term and its stuck to it, or 'steam pipe' is the new 'modern' name for mild steel pipe.
Yep, that sounds right, the blokes next door to us have one, got a ball on a little arm that sits inside the bending radius and stops deformation of the pipe like what happens with plain press bending.
moral of the story is the manifolds are good, and im calling it mild steel pipe :ninja:
Steam pipe bends are mild steel cast bends(called black steel), not mandrells. They are called long or tight radius butt weld(you can buy them with a thread on them)steam pipe bends in the blackwoods catalogue. I think they are called that as they are used extensively in boilermaking, also handrails? They are available in two different thicknesses and manifolds are made of the thinner ones(approx 5mm wall thickness-grade 40)there is also a grade 80(10mm wall thickness!!)hope this clears it up
The stainless exhaust manifold we got on the race car is shithouse in terms of life span...they cant handle the heat and go brittle and then crack...just like our one, not even a year old and its falling to pieces. We got a nice 6boost m/s manifold ready to go on, which i think will do the trick, plus the design looks alot better for flow. Kyle seems to think we should see about a 2-300rpm decrease in lag just from his manifold. And best part, he gives a lifetime warranty on cracks! woot!
I hear about cracking exhaust manifolds a lot, but when I dig deaper I find 99% of the time the whole exhaust system is hanging off the turbo. A rubber hanger or 2 at the rear mufler, that's it. The turbo, the wastegate, the dump pipe, engine pipe, cat (if there is one) etc all hanging off a red hot glowing exhaust manifold. Is it any wonder they crack.
As I have posted many times, I use a vertically solid mount at the bellhousing to block joint and another mount at the gearbox subframe. That way all the exhaust manifold has ot do it hold itself up. I have never cracked an exhaust manifold of any type, thin stainless or not.
:ninja: cheers :)
lol Gary, we have a stainless flex pipe from dump pipe to the short exhaust system(about 2 mtrs worth) we have which goes out infront of the rear p.s wheel, and that short part is supported by three rubber hangers, one off the gearbox subframe, one off the tailshaft loop we made up and the one just near the sil where the exhaust exits. Everywhere upto the stainless flex is supported, only the dump pipe hangs off the turbo. Is that setup really so bad? Does it fall within your 99% category?? Not being rude either.
For the next manifold im gonna put another mount off the engine/gearbox bell housing whichever i can use the easiet to hold the dump pipe from the back of the turbo, and then a bracket from the manfiold to the head somewhere. I think that should be sufficient.
Just a note also, none of the cracks on the manifold were around the runners or in typical stress points.
There is always an exception to the rule, maybe you get to be it on this one.
Although, maybe the solid mount at the gearbox bellhousing to block joint is the trick. On mine, I can unbolt the exhaust manifold from the engine and the turbo, wastegate and exhaust manifold don't move up or down. So the only thing my exhaust manifold does is transport the gas, it doesn't even hold up its own weight.
Plus I have 2 stainless steel rods that go from the exhaust manifold (to head flange) to the turbine flange on the exhaust manifold. So the exhaust manifold gets zero side loading as well as zero up and down. The circuit race G forces are quite severe, so I made sure I avoided that problem as well.
:rofl: cheers :P
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
