i've gone thru 207 pages i cant find anything.
i'm running an rb30dett
using
rb25de R32 head
rb26 plenum
rb26 turbo and manifolds
i cant seem to find any pistons to get my comression up so i have good responce.
any help would be good.
cheers
Machine the head and block to get the compression ratio you want. Mine is 9 to 1 with a slight dome piston and 0.8 mm head gasket. The combustion chambers are 62 cc’s (standard is 64-65 cc’s). I retained the standard squish.
:( cheers :(
what pistons are you running sydneykid?
JE Pistons in mine.
But it doesn't matter what brand.
You need a slight piston dome, so look at the spec sheets and pick one.
Then select a head gasket thickness and machine the head & block to achieve the target compression ratio.
:) cheers ;)
Edited by Sydneykid
JE Pistons in mine.
:P cheers :wub:
the ACLs i bought are are flat top. everything considered is dome top preferable with respect to creating the correct squish etc?
The ACL's run positive deck height, so same result as the JE's.
:) cheers :P
I'm thinking of making a 3L RB26. Most likely by taking the crank and so on from an RB30 and putting into an RB26.
What are peoples thoughts?
I've heard that RB30 bottom ends have different mounting points to the RB26 hence why I was considering going down this route.
Thats already been done mate...an engine builder posted about it on here a few months back now...used the rb30 crank in a 26 block im pretty sure it was and after alot of machining and customised work it became a rb29 or something. But i remember him saying there was alot of work in it.
Edited by r33_racer
Has anyone here used a JUN oil pump collar on an RB30 crank?
It came with 2 grub screws and instructions, in Japanese of coz :rofl: is anyone able to translate?
I'm aware machining is required but are only 2 grub screws going to be safe?
Pics attatched. :laugh:
Edited by Alf
whats there to translate mate?
It gives you the machining diameter needed to fit the collar on. Its very straightforward. We took ours to the machine shop down the road and they fitted it for us...we just loctited the grub screws in. Some people use a interference fit and heat the collar up, and freeze the crank and let them normalise onto eachother and then put the grubscrews in, ofcourse the crank will need to have recessed holes for the grub screws to lock in, making sure they go in just under flush.
I think it cost us like 90 bux to get done and its still working :)
I think it cost us like 90 bux to get done and its still working :P
That's the go;
1. machine to the dimensions
2. heat collar and cool crank
3. press collar onto crank
4. drill holes for grub screws and tap threads.
:happy: cheers :)
Ok the race car is going in for another tune and this is what it has..
1997 R33 S2 GTST RB25/30 Race Car.
RB25 Head with VVT
Mild Port n Polish
Tomei Type A valve springs - not fitted
Greddy Intake Manifold w/ Q45 Throttle Body
S/S Exhaust Manifold - 6Boost fitted
Tial 38mm Wastegate - 48mm Turbosmart Gate fitted
GT35/40 0.82 Rear AR
3" Straight through Exhaust, Dumped PS infront of rear wheel
Screamer to ATMO
Q45 AFM
850cc SARDS
POWERFC PRO w/Datalogit
AVCR
600X300X76 PWR I/C - Soon to be 110mm ARE I/C fitted
Turbosmart BOV
CP 25/30 Pistons w/CP Chromemoly Rings 8.3:1 CR
ACL Steel Headgasket
REV I Beam Rods
ATI Super Damper - fitted
044 Bosch Pump/ 40ltr Fuel Cell
ACL Bearings all throughout
ARP Main & Head Studs
Tomei 256 Poncams IN/EX
NI Oil Pump with JUN Crank Collar
4.5l Custom Catch Can
PWR 50mm Core Radiator
High Energy Circuit Sump
Exedy Twin Plate Clutch w/ Chromemoly Flywheel
So previous tune at Charlies saw us making on 18psi 240rwkw. Cranking the boost right up (25psi) and were hoping for about 300rwkw. The figures seem low in comparison to everyone elses for the mods done. What would you guys think it should see power wise? They dont tune or power run the car in shootout mode, they think its a wank for some reason.
Edited by r33_racer
hi guys
i read somewhere in this thread
i think it was earlier on in it
it mentioned something about R32 GTST gearboxes i think being too weak and not being able to take the power which some of these hybrid engines produce....
i am just curious to whether this is the same issue for the R32 GTS4 gearbox?
or would i need to change to another gearbox?
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
