I dont think theres many engines you could bore out a whole 500cc.
Heh yeah thought it was a fair bit, worth asking though. Just another quick question, does using the rb26 crank change the RB25 capacity?
lol how much are those turbo's gonna set you back? probs more cash then I have in the bank lol.
test bed so we can compare turbo's. I've been thinking about teeing up one of the garrett suppliers to help me test different turbo's and get some results. Same engine only thing that gets changed is turbo's.
I would ~love~ to be able to try both.. trouble is no wants to loan me turbos - go figure...
You go the 2530's matt and ill try out the GT-RS's :)
I'LLLL KICK YOUR A$$ !!!! oopss.. sorry.. just my naturally competitive nature plus a little Tourettes syndrome possibly.... :dry:
Actually its a pity we're not in the same town - you can only really tell when you 'drive' each other car. But hopefully the Dyno will probably give us an idea. Be good to compare for sure.
Mmmm... boost at 3000rpm... giddeup!
I'm happy to go 26/30 with 2530's, all I need is the RB30 + conversion parts, the rest is there. Actually all I need is an engine builder that can do the whole thing for me :D
I'm happy to go 26/30 with 2530's, all I need is the RB30 + conversion parts, the rest is there. Actually all I need is an engine builder that can do the whole thing for me :ermm:
have you spoken to Jamie about it Ben ??
im sure he would be willing to do this for you.
Yup he said he could do it (said he built Dan's 25/30) and also has a spare rb30 block but just not sure if I should go to an engine specialist with more experience due to the importance of getting it 100% right and all the custom work required.
Edited by benm
umm what custom work ???
most of the parts for these conversions are available pre made, such as crank collars, 4wd adapter plates etc
more than likely he would be using nepean engines on correen Av for the machining work (same guy did my block prep)
has done Dans engine, can confirm this
he will be doing some of the oil feed work for my rb25 head, as he did it a clever way for Dans engine.
just on an offnote. the crank collar adaptor is there so we can install a bigger/better oil pump correct?
if not can someone explain?
originally i was under the impression it was required/created for r32GTR cranks to be able to run the later model R33 GTR pumps which utilise the larger area
but now it seems normal for people to suggest fitting it..
personally
i'm going to be running the rb25 oil pump on the first motor, so im not going to install one on this engine.
std bottom end, cant really justify the cost of the unit and install, built motor with N1 will get it
All it does is provide a full length drive for the oil pump. Where as std (rb30, rb20, r33 rb25 series 1, & R32 rb26) all have a really small drive that doesn't cover the whole of the oil pumps drive.
I've attached a pic that I saved when some one popped an oil pump.
You can see how the standard oil pump drive is not the full width of the gear.
And attached the jun oil collar.
This is the difference of the two drives.
I think even for a standardish build, oil pump and collar are a must. Because it seems that alot of people seem to have the oil pump failing problem. Whether its the gear breaking, or screws coming loose from vibrations or just old age. Since its sort of an essential item to the overall life of an engine it should be considered with more importance.
Craved,
It doesn't really have anything to do with the later modem r33 gtr pumps as all the gtr, rb20 and rb25 pumps have a gear width greater than that of the drive, so they ALL benifit by running the full drive.
RB20's and rb25's have been known to suffer the same fate as the gtr's.
The RB30 oil pumps have an internal gear that is near the same size as of the standard drive.
Craved,
what do you mean by it covers the full length drive of the oil pump?
if im using an r32 rb25de oil pump on rb30 it will still work?
The oil pump has an internal gear that is wider than the lug on the crank that engages with the oil pump to drive it.
By fitting the crank collar this then places even pressure across the oil pumps internal gear.
RB25de oil pump from what I've seen looks the same as the rb20 pump, unsure if pressure is the same would need to look it up in the engine manual for that one. :D
hmmm might have to look at this
have the rb30e oil pump at home, and an RB25det one too
my first rb30 i am rebuiling for under $1500 as i cant afford the full build forged internal ones atm .. and i already have another long engine sitting there .. so i guess i will try and see ... if it goes boom it goes boom.
Edited by Craved
i must be taking ages to comprehend this so having a bigger drive and the pump engaging more means is spreading more oil/more oil more evenly etc?
doesnt affect how much oil is pumped
just is used to prevent oil pump failures due to uneven pressure on its internal gears, which can cause them to crack like in Cubes' post above .. see red circles
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
