We went CP flat top pistons. But its upto you what pistons you want, to achieve whatever CR. Our tuner wanted us to go with a lower cr, while others tend to go for the higher cr.
The view is the lower cr makes the car less responsive off boost, while the higher cr makes it more responsive. However depending on tuning the lower cr helps with less knock and allows more ignition advance and boost without the knock, while the higher cr helps with more low/midrange power but in alot of cases ends up with more knock....but it all comes down to the tuner in the end or so everyone says. Prob abit in it with fuel economy and other bits and pieces, but .5 difference is like either choosing to run rb26 cr or running rb25 cr...in the end its upto you cause its your engine your building.
But then again it depends on what application your building this motor for.
Edited by r33_racer
howdy just about to order some pistons for 30det.
can get a good deal on acl rebuild kits and the new forged pistons they've produced.
does anyone have any experiance with these suckers? are they any good? or shall i pay a few hunj more and buy eg arais??? dont really wona spend teh extra dollars coz i will also be getting Hbeam rods.
also these acl forged pistons apparently produce a comp ratio of 8.5!
is this ok for a daily driver which will cop a bit of shit with about 420rwhp???
the car is a r33 is thats gona help.
except those pistons are suited for a rb30ET not DET. I think it will give a shithouse CR something like 7.1:1 its been said. You need the NA pistons to give a better CR around 8.2-8.5 or thereabouts.
No they are 8.5:1 in the RB30ET engine, so when used with the RB25 head they come in around 8 depending on combustion chamber size. I have used them in my RB30 with R34 Neo head ( it has a 58cc chamber ) and comp has worked out at 8.4:1
You are correct in what you said if you use the std oem turbo piston from the VL RB30ET. They were around 7.5:1 std I believe.
Best to use the CP pistons like I sell.
Edited by Spoolup
So what compression do you get with your pistons SPOOL
CP make two types
8.5:1 and 9.0:1.
One has a flat top with zero deck height and the other has an 11cc ( from memory ) dome.
Thanks for that spool, just wondering Is their any issues using oil restrictors with VVT.
Edited by JMCY
seeing as ive got this motor apart
should i use restrictors if im using an RB25DE head and RB30 oil pump?
the isnt going to be raced very much at all, just a weekend cruise and a dyno run here and there
yes on an RB26 head block off one and use a restrictor in hte other, size depends on oil pump
i picked up my sump adapter on thursday and i'm going to install it this week, so i'll document the whole process (with pics) and post them up here
rb25 head with n1 oil pump and one blocked off and 1.5mm in other and we have oil problems. Circuit racing is a bitch for exposing problems.
oh and we have vct as well.
Refer to the table from SK's oil control problems in rbs info.
Edited by r33_racer
Hey guys been reading this thread for a while now almost an hour lol
just a few qik questions...
i have picked up an rb30 complete do i need a n/a rb25de head or can i use an rb25det head as there is one that has been ported and polished? vct or non vct
also this rb30 has been rebuilt to std specs like 400kms ago is it worth just fitting the head and fix it if it breaks. I work in a performance workshop so rebuilding it is no problem i was just curious if anyone has pushed the std n/a 30 bottom end to breaking point?
cheers
I would just bolt them together with the restrictors and remote oil feed to the vct. Cc your chambers and pistons( you dont need to pull them out) and chech your deck heights to find out your comp and squish, i would go for high 8's:1 comp amd about 35 thou squish, so you may have to deck the head or block of fiddle with head gasket thickness, get a steel head gasket and your done. Dont try to get 1000hp, and it will hold together. You may wish to put a good set of big end bearings in it though. This should be good for a safe 550hp if tuned well, as above this the rods go
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
