We went CP flat top pistons. But its upto you what pistons you want, to achieve whatever CR. Our tuner wanted us to go with a lower cr, while others tend to go for the higher cr.
The view is the lower cr makes the car less responsive off boost, while the higher cr makes it more responsive. However depending on tuning the lower cr helps with less knock and allows more ignition advance and boost without the knock, while the higher cr helps with more low/midrange power but in alot of cases ends up with more knock....but it all comes down to the tuner in the end or so everyone says. Prob abit in it with fuel economy and other bits and pieces, but .5 difference is like either choosing to run rb26 cr or running rb25 cr...in the end its upto you cause its your engine your building.
But then again it depends on what application your building this motor for.
Edited by r33_racer
howdy just about to order some pistons for 30det.
can get a good deal on acl rebuild kits and the new forged pistons they've produced.
does anyone have any experiance with these suckers? are they any good? or shall i pay a few hunj more and buy eg arais??? dont really wona spend teh extra dollars coz i will also be getting Hbeam rods.
also these acl forged pistons apparently produce a comp ratio of 8.5!
is this ok for a daily driver which will cop a bit of shit with about 420rwhp???
the car is a r33 is thats gona help.
No they are 8.5:1 in the RB30ET engine, so when used with the RB25 head they come in around 8 depending on combustion chamber size. I have used them in my RB30 with R34 Neo head ( it has a 58cc chamber ) and comp has worked out at 8.4:1
You are correct in what you said if you use the std oem turbo piston from the VL RB30ET. They were around 7.5:1 std I believe.
Best to use the CP pistons like I sell.
Edited by Spoolup
So what compression do you get with your pistons SPOOL
CP make two types
8.5:1 and 9.0:1.
One has a flat top with zero deck height and the other has an 11cc ( from memory ) dome.
Thanks for that spool, just wondering Is their any issues using oil restrictors with VVT.
Edited by JMCY
yes on an RB26 head block off one and use a restrictor in hte other, size depends on oil pump
i picked up my sump adapter on thursday and i'm going to install it this week, so i'll document the whole process (with pics) and post them up here
rb25 head with n1 oil pump and one blocked off and 1.5mm in other and we have oil problems. Circuit racing is a bitch for exposing problems.
oh and we have vct as well.
Refer to the table from SK's oil control problems in rbs info.
Edited by r33_racer
Hey guys been reading this thread for a while now almost an hour lol
just a few qik questions...
i have picked up an rb30 complete do i need a n/a rb25de head or can i use an rb25det head as there is one that has been ported and polished? vct or non vct
also this rb30 has been rebuilt to std specs like 400kms ago is it worth just fitting the head and fix it if it breaks. I work in a performance workshop so rebuilding it is no problem i was just curious if anyone has pushed the std n/a 30 bottom end to breaking point?
cheers
I would just bolt them together with the restrictors and remote oil feed to the vct. Cc your chambers and pistons( you dont need to pull them out) and chech your deck heights to find out your comp and squish, i would go for high 8's:1 comp amd about 35 thou squish, so you may have to deck the head or block of fiddle with head gasket thickness, get a steel head gasket and your done. Dont try to get 1000hp, and it will hold together. You may wish to put a good set of big end bearings in it though. This should be good for a safe 550hp if tuned well, as above this the rods go
    • Indeed. Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
    • It's also funny when an Australian company is boasting how their warehousing is USA/Europe...
    • Hi People, has anyone come up with a way of getting non-driven wheel speed on a R32 Gts/gtst? from what i've seen the RWD R32 didn't look to come with ABS, if they did i can't find a rwd ABS front knuckle anywhere. is it a case of putting a S14/R33 front knuckle on and then modifying the ASB ring to suit a ECU input frequency limit? or have people managed to get a hall sensor onto the back of the hub and pick up the wheel studs?   i've searched but there isn't anything that I could find.
    • I was thinking about a hoist, the ceiling is very high, but half the garage has a half-height loft for storage and I dont think I'll even be able to jack the X5 up under it as it almost hits me in my 6'5" elevated head when i walk in there. And, yeah nah, maybe if I can convince Bec to let me get another car she'd be open to having as many as we can fit (cough @Duncan) but until that time you better steer clear! 🤣
    • For the sake of cost comparison, I’m currently embarking on putting a new 5 speed into my R33. I imported a new RB25DET gearbox from Japan, which was about AU$3.3k delivered to my door. It was a very slow process (~2 months) and I got extremely lucky with the exchange rate. The twin plate clutch I bought was about AU$1.8k. I've also had to buy all the additional parts required to convert the gearbox from a pull type clutch to a push type clutch. Total cost is about AU$5.5k, so GTSBoy is pretty close to the money.
