Lets see what r33_racers failure was caused by before we go jumping the gun.
True, it may not even be that.
But while on the subject, does anyone run any 'engine kill' devices that detect low oil pressure and cut ignition to help save the motor? Is there a separate device like this available? A light on the dash doesn't give much time to react when at high revs, but perhaps a sensor to trigger ignition kill would be the go...
I've thought about a warning buzzer, not sure if killing ignition is the way to go, probably just better off with a buzzer so you can drop it in neutral asap. Providing you don't forget about the buzzer, it goes off and you think wtf is that, by the time you remember its too late anyway. :laugh:
Kill ignition and it may lock the rears mid corner or something silly.
I've thought about a warning buzzer, not sure if killing ignition is the way to go, probably just better off with a buzzer so you can drop it in neutral asap. Providing you don't forget about the buzzer, it goes off and you think wtf is that, by the time you remember its too late anyway. :P
mate runs an engine kill switch like the one suggested on his sprint car, with over $60K in the engine, as soon as the oil pressure drops, it cuts everything.
with our cars it might ne a little harder than the carbied V8.. as you have to bypass any chance of a turbo timer working etc, then power steering and where you are.
but i am DEFINATELY going to run a switch to a specific light (autometer pen light for example) that will be direct line of sight. might not save the rebuild, but you wont go seizing anything.
yeh i think motecs and autronics have that feature built in, if something goes over a preset warning value it shuts off the engine completely to save it from harm. I know alot of sprint car racers and even circuit racers have a kill switch hooked inline to the oil pressure switch which craved is talking about so it kills the engine if pressure drops to nothing. I think we wish we had that now haha >_<
Well my motor is nearly ready to go back in my car so hopefully thursday/friday the rb30det will be out and getting stripped down....we found a strip of steel/tin in the oil, looks like its from a bearing... :P
Oh also cubes...things we would do differently... Well our tuner wants us to run a flat 8:1CR. Id like to run 9:1, but they like it lower to help keep the knock down, so can run more timing and boost. Will definetely do all the oil control mods that SK listed properly, instead of letting my old man half arse them cause he thinks he knows better haha, umm defintealy run conrods with oil squirters and thats about it so far that i can think of. Will probably come up with more as we put it back together.
Edited by r33_racer
quickie -
what engine sealant did you guys use on the replacement whelsh plugs .. i have a black sensor safe engine sealer i used on my bike, would this suffice?
or something like a tri bond sealer be best?
Edited by Craved
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
