Guys, i know the R33 rb25det has vct so do i need to do anything about it if im adding a R32 rb25de head? I dont want to go rb30e bottom end as i like revs and my current set up(hks gt2535,gtr injectors etc) would suit a rb25det very well.
Opps i was logged on my sisters account LOL. Also im thinking of using the 25de cams, would they be better than the 20det ones?
IF you select a decent sized turbo to make 'decent' power, throw on a plenum and you will have the rev's.
The plenum appears to be the key for an rb30 to rev, or just use an rb26 head. :miner:
Its about the package.. Either way the gt2535 on an rb30 rb25 head with stock plenum will always go better than on the rb25 due to the higher average power.
Stuff it im going to do it :P just to be different. Hope to have it done this year. I have seen a dyno gragh of a gt2535 on a 30det, boost drops off as it's a small turbo for a 3L. .64 ext housing :P What cams you guys think?
Edited by R31 POWER
Stuff it im going to do it :( just to be different. Hope to have it done this year. I have seen a dyno gragh of a gt2535 on a 30det, boost drops off as it's a small turbo for a 3L. .64 ext housing :ninja: What cams you guys think?
yeh I got a 2535 on my RB30, spools pretty fast and drops off just as quickly and thats with HKS cams too
dont know what RPM the power started to drop off tho as my dyno sheet was in KM/h not RPM
but on my RB25 power peaked at 155-159km/h and on the RB30 it topped at 145Km/h
this is on an Auto R33, if someone could convert that to approx. RPM that would be good
ok guys i asked a question on the last page 239 about timing belt.
stockymcstock posted a pic on how to fix my problem BUT i had allready drilled the hole on inlet side for tensinor so when i went to put the second one above the water put i could not move it far enough to exhaust side to get the right tension on the belt (way to tight) so now my question is if i put a tensinor in the factory position (bottom left) and the put the second one above the water pump on exhaust side would this be ok??
As far as i understand aslong as the pitch and width of the belt is right there should not be a problem i have found in doing it they way i was thinking i would be able to use a 150 tooth belt and get the right tension
but would this work
i've been browsing through this thread over the past 2 or so weeks as i'm very close to doing this conversion myself (as in blown rb25 out and disassembled, waiting on 30 block) but there is one thing i can't seem to find a definent answer on, although i'm sure it must be somewhere in this thread..
the head i'm using is the r33 rb25det with vct, however i'm at a loss as to what to do with the vct.. i read some bore out the oil gallery going from just above the vct solinoid as a source of oil but this dangerously lowers oil pressure throughout the intake cam high pressure side, which is a no no.. others somehow route an external supply of oil to the vct solinoid but i've been unable to find where they tap this into?
if i'm just being a retard and have missed out a very obviouse post then could somebody please tell me so and refer me too it, or could just enlighten me on this subject i will love you long time, i really will :P
had my mechanic drill and tap the head, then put a grub screw inplace of the original vct feed, then drilled and tapped into the front of the gallery behind the inlet cam gear and put a fitting in there for me, all i need now is some braided line to go from the oil hole behind the oil filter to supply it with oil, as the rb25 oil cooler assembly houses the std oil pressure sender, where as the rb30 used the hole behind it.
dont have pics here though
Nemini90: that looks good, shouldn't be any issues. there are, as you have found, a number of different ways to go about it. you just need to make sure you don't drill and tap through into a bore or water jacket or something, it's pretty simple stuff.
so long as the cam timing appears to be spot on, it will run OK. obviously adjustable cam gears with proper dialling in will help to locate the camshafts exactly where you want them. remember with non-OEM belt setups like we all have, the cam timing could really be just about anywhere. while you can alter belt tension on the two swinging tensioners to move the cams, it is not ideal.
cheers
so basically, you're blocking off the original high pressure feed on the bottom of the head which feeds from the block with the grub screw, then you've drilled and tapped another one into that same gallery so as to feed it via an external line from the oil cooler? thanks heaps for your help, much appreciated :(
not from the oil cooler, behind it is a threaded hole to the pressure side, which the rb30e ran their oil pressure sender into
I have my engine appart at the moment. So i could take some pictures for you except the engine is at the engine shop. when i get it back (after chrissy) i will take some pics of where it is drilled and the oil line etc and the grub screw.
Also look through this thread more because there is lots of photos of the vct setups from various people.
Guys;
the RB26 hs two crank scraper/windage plates that bolt to the girdle. the RB30 doesn't. what are most people doing - adapting the plates to the RB30 girdle or not?
Cheers
Scooby if i had those crank scrapers to bolt onto the rb30 girdle i would drill and tap the m6 holes required to adapt them. Ive seen a few rb30det build ups by a few workshops who fab up ally crank scrapers and do that...drill and tap holes in girdle so they can bolt them straight on. Plus it was a recomendation by SK too, so its worth while if you have them.
why, what do they do?
Thanks Michael.
Shane they serve to reduce the amount of oil that adheres to/contacts the crank. They are also known as a windage tray.
I wondered if it might be a good idea to leave them out since there aren't any oil squirters, although my conrods have the oil notches in them.
Scooby,
All rods have the squirter's on them to squirt oil on the thrust side of the bore.
Towed (tow rope :S) a VN Dungadoor today as it broke down on me when getting my pedal box welded up yesterday.. Towed it unbelievably well. Never needed boost on the flats and up Flagstaff Hill which is a big arsed steep hill it only needed ~3-4psi in fourth gear at 60km/h ~1900rpm.
Was quite surprised at how much torque it really has when you go to tow something with it.
The old RB20DET wasn't able to cruise at 60km/h in fourth gear up flagstaff Hill when not towing anything. :)
Turbo's + Hills + towing = am I towing something?? :)
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
