Ok , so from reading this im guess a rb30(n/a) bottom end will not just bolt straight in....
i have a rb25det (automatic) in a R33 gtst i dont wanna change driveline .
Will my box fit? will the engine mounts match ? its a great thread but im just looking to bolt on the rb30 bottom end without changing pistons and grinding galleries? is this possible???
thanks in advance
Edited by Veilside-SaU
Im pretty sure all spigot bearings are the same. rb30, 25, 20 and 26 identical. Ask for an rb30 spigot bearing...chances of finding that are probably better as its from an australian car...some automotive stores dont know any better. Ask for a 26 and the list will only say rb30....and the pimple faced kid behind the counter will say 'sorry sir the computer only lists one for an rb30 out of a vl commondore, cant help you...'
Idiots...annoying sometimes.
RE: Belt sizes.
Just been looking on dayco.com.au, heaps of belt options.
94843: 153 teeth, STP8M pitch, 25mm wide (not that it needs to get any longer)
94407: 152 teeth, STP8M pitch, 25mm wide
94604: 151 teeth, STP8M pitch, 25mm wide
94777: 150 teeth, STP8M pitch, 23mm wide (this belt is equiv to gates t306,150 teeth)
94830: 149 teeth, STP8M pitch, 25mm wide (pretty much spot on for low low setup)
94109: 148 teeth, STP8M pitch, 25mm wide
94652: 147 teeth, STP8M pitch, 25mm wide (getting a bit short....)
Hope this helps a few people, Im gonna work out the best one for the low low tensioner setup for mine, will post up results.
Edited by Godzilla33
hi guys i have these pistons
AP340754 Arias - Arias Forged Pistons Rb30 Non-turbo 86.5mm Bore Supplied With Rings
how good are they for this conversion???
what comp ration would it give with 1.5mm head gasket and rb25 vvt head?? and the block has been faced if that makes a big diff (not sure how much tho)
the non-turbo pistons are better for this conversion yee? or is that just the standard non-turbo pistons which are better??
whats teh differance in strength between the turbo and non turbo pistons?
Hey Scooby,
yeah, pitch is the same as std RB30 belt, Im 99% gonna use the 149 tooth option with the low low 2 tensioner setup. Gives that bit more clearance between tensioners. My local Repco doesnt stock dayco, gonna try get one tomorrow elsewhere.
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
