just a couple of questions.. probably been covered before but spent the last 20 minutes searching and came up with a few hits but no solutions :P
first of all, the oil drain that is located behind the exhaust cam gear, are you guys just T'ing it back into the turbo oil drain? Is this something to do with the PCV system so it would need another hole tapped so it can drain back into the sump?
and last one, the two green water temp sensors (i think that's what they are..) that are present on the rb25 have no place on the rb30 block, and no place machined flat where they could be tapped in (from first impressions anyway), are they being T'd into where the radiater in and out pipes are attatched?
cheers guys,
mark :laugh:
cheers guys,
mark :laugh:
Best to put the front oil drain back into the sump to remove any chance of a back caused by the frothy oil from the turbo return, you can T it but you want the oil back down to the sump as fast as possible.
the green sensors are the knock sensors - i have attached a pic that i got from this thread that shows their locations
EDIT: Yes i'm retarded, there were spots for them there the whole time, thanks for the info though, much appreciated :miner: <begin flame now>
Edited by aphid
Hi Guys,
I'm now a proud owner of an RB25/30. Got my baby back about 2 weeks ago and am now running her in. I've just got the standard 25 turbo in atm but I'm very impressed with the torque. Dan from Elite Racing Developments did a great job. Here's some pics.
mind if i ask how much if cost you?
It's only legal in 31's.
but
You can only get it legal in later models if you convert it to lpg. -EPA bullshit.
or
But if its in a later model and the RB20/25/26 engine number happens to appear on the Rb30 block and the RB30 casting also happens to have been ground down then you wont need a mod plate. As far as the DOT is concerned it is still the original motor. :laugh:
Edited by Alf
Just a quick Question guys,
If I allready have a 3.5" Cat-back exhaust +3"High flow cat+ 3"Dump+front pipe (I think the neck/flange of the front pipe is 2.5")
would there be any benefit upgrading the cat, front and dump pipe to 3.5" as well?
this is on a RB30+HKS2535
(I know I know, its too small, say for future upgrades GT30R or GT35)
well if you upgrade to these other turbo's later (gt30r or GT35) then your front pipes/dump pipe will change anyway so i wouldnt use that argument.
i would say that the extra exhaust flow from the 3L will benefit from the larger dump pipe and Cat - but would wait til you upgrade to save costs
Cubes has busted me and it's time to come clean so enough lurking and enjoying the posts.
Last month I decided to go the RB30 route in the 25t track barge. The bottom end is an SII DE with still perfect 86mm bores. I then decided to buy a 26 head, use a spare complete intake and use my steel wheel turbos coming off my GTR. The GTR makes 260rwkw with these on 1 bar so should have a little more in them on the 26/30. Of course doing this it only makes sense to use decent rods and pistons so forged Spool rods and hi-comp ACL pistons are to be used. I'll go with the hi/low adjusters on the front, long pump drive on the crank, baffled sump, 1.25mm restrictor, Cometic head gasket, oil cooler, 044 with 1.5L swirl pot and GTR feed pump. I'll stay with the Hybrid monster cooler as that works well already. After I have gotten used to it I'll probably shove in bigger injectors and turbos and try to run up at the 350rwkw mark, but maintaining lots down low.
As always I'll build it myself but will try a new machinist to get it done fast as it has to drive to Brisbane on the 3rd of March.
All I can say is I'm looking forward to the fun.
Oh yeh...another one bites the dust. Slowly everyone will get converted to the rb30 side.
And realise that queensland is truly gods country...as Spoolup has already mentioned.
Edited by r33_racer
Just moving home Brad (if I have pistons to make the motor go - nudge nudge) and it's always been both home and gods country to me. No rain here in sh*tsville....err I mean Melbourne. Must be all up at Ingham.
Mike, this project can be partly blamed on you. Love the idea of a dedicated class racing 25t. Unfortunately I have another project awaiting involving a small convertible and a quad cam V8.........
hey mate, whats the part number of the acl pistons your using?>
v8 powered mx5....aww yeh. That was with a removable tube chassis front end if i remember correctly?
Hey with your expertise...could you effectively trick out a skyline with sweet james bond like gadgetry and weapons? Missiles, mini guns and the sort? Ive always wondered if anyone had done it or if it was technically possible/practical.
ACL pistons? Clicky the link in the sig above your post.
Mark, what's up? Bored with ACT. Hows that 26/30 coming along?
Brad, thanks.
Mike, does an RB25DETT count? Surely the 26/30 is near enough? I saw a LAV with a vulcan on top firing over the side. I thought it would roll over at one point. Anything is possible with money....the Bond Die another Day cars actually had the stuff in them, and had to run tiny motors to fit it so possibly not practical. Great ep of House tonight BTW.
Anyway, back on topic....which injector plugs should I source to make a loom for the 26 injectors? I know I should get off my ass and go into the EFI shop but it's easier to just ask and they are closed this time of night..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
