Every head should be CC'd if you dont knows it's history.
I know mine had the face machined prior to me buying it and again was faced after the front water gallery was tigged up.
My R33 RB25DET head's bowls averaged at 58.7 CCs . It's time consuming to get the bowls volume close to each other (0.2CC +/-). :)
no. 6 cyl had the largest bowl volume: 59.8CCs. Had to remove a bit of material to clean up the pitting left from detonation.
PS: I used a burette to measure the bowls.
Edited by Alf
Problem solved.
Looks like the cat or middle muffler has collapsed and blocked most of the exhaust.
Got it to 1 bar after I dropped the exhaust at the dump pipe flange and went for a blat up the street.
Whoo hoo, now to just replace the cat or muffler and back to the dyno.
Think Ill have a few beers tonight.
Hope those beers were good.
I should have thought of that. I had a cat collapse once and it was doing similar, but seems fairly uncommon. Well done.
the greddy copy manifolds have been discussed in the froced inuction forum, the casting quality seems to be poor, and you can get them off ebay for about $200, noone has got dyno proof yet if they work. I think the siemens injectors are all top feed, so unless you get an r34 fuel rail, which fits the greddy copy manifold, they wont fit. Even with the rail, im not sure if the siemens are the same dimensions as the r34 gtt injectors
Ohhh ok.
I just thought they had smaller housings than a GT35 or are they the same but with smaller wheels?
Do a search for the results of R31Nismoid...its his old turbo that you are talking about.
Also, another quetion... those of you running RB25 heads vs Rb26. IS there a measurable difference between the results are ppl getting with the same turbos...main variable being head and inlet plenum?
Not sure if i should bother with an RB26 head or not
Forget about whether or not the RB26 head itself is "better", the fact is it will work out cheaper when you add it all up. Inlet manifold, multiple throttle bodies, plenum, top feed injectors, cams, solid followers, no VVT, adj camshaft pulleys, valves, valves springs etc etc. They are what makes an RB26 head the ONLY way to go.
:P cheers ;)
I cut the cat out of my exhaust today - it is completely screwed and deformed internally. If you hold it up to the light you can not see any daylight.
In the end I couldnt even get the car to idle there was that much back pressure.
It is approx 2500 kms old - I am currently in discussions with regards to a warranty claim so dont want to mention any names as yet. It was not a cheap item though.
yeah - that gets a little expensive when you get defected and they decide to take a closer look - I did consider it though.
Custom Exhaust Specialists in Bris are doing me a 3.5 inch custom cat they have XR6 turbos making 700-750 flywheel horsepower with - its cheaper than the 10k fine :-)
time to put a "hi flow" one in then? :P
i need to scan it this weekend but i ran outta fuel so i need to do more work on the dyno after i change the pump.
How is a good way to get out of the fuel problem? i want to get over 400rwkw if i can with the stock head.
peek power was at around 160ks an hour in 4th gear.. i need to bring it down a bit but wont worry about that untill i get the fuel pump situation fixed up.
Full Boost comes on - 110ks an hour (20psi) in 4th gear all the way up to the end 20psi
It even has 5psi of boost at 92ks an hour in 4th.. comes on early i wreckon
    • Probably yes. I think I could make it work but I'd rather not chance it. I've been having to ask friends for help because the transmission is just that heavy and for the price of ~30 USD I can get the OS Giken one in soon which should guarantee that clutch alignment won't prevent the transmission from seating properly.
    • Coud be the brand. Have never had problems with the shafts I've used in Australia.  Even the cheap ones.
    • I'm pretty sure it's just this specific Dorman one. I checked it with the hub by itself and even then it was already shedding plastic. It's only once I ran into all these issues with assembling the clutch that I decided to be skeptical of the plastic alignment tool as well and found it to have a notable amount of slop as the clutch is heavy enough to allow the plastic to bend.
    • The "one cylinder is 160 while others is 180" part of the compression test sounds bad. That's 12% lower than the others. I would bet something has happened there.
    • Does it do it at light throttle as well as high throttle opening? Only large throttle opening? If the answer is "No, it doesn't do it at light throttle opening", then (part of) the answer is as it has always been. Don't stamp on the throttle at low revs. Open is with some discretion. Roll into it. Now, because it's not a turbo, it shouldn't demand the highest octane fuel....but even 91 MON (equivalent to ~95 RON in the metric world) is only so-so for NA Jap engines. The 10% ethanol won't make any difference forwards or backwards. 10% is just filler. OK, actually, it is a little bit bad. Ethanol adds some (effectively) free octane. It allows the blend to reach the 91 octane rating without the petrol it is mixed with being that high octane to start with. But ethanol needs less air to burn than petrol does. So when a blend has ethanol in it, the fuel-air mix will always be a bit lean (except when running in closed loop cruise where the O2 sensor will add fuel to bring the stoichiometry back to target). When yo stamp on the throttle, you are not in closed loop and so a lean condition may well exist. Lean can (and will) cause pinging. The low compression cylinder may be a concern. If the rings (and in particular the oil control ring) are poor, and it is ingesting oil into that cylinder, that can cause it to ping. Oil reduces the effective octane rating of the fuel that is squirted into that cylinder, and rattle rattle rattle is the result. It's unlikely to be a bad MAF. You should make sure that the harmonic balancer is not in the process of failing. The outer hub can slip around relative to the inner. This makes the timing marks on it wrong. If you set the timing to a target, as read with a timing light from those marks, then the timing can be very wrong. You need to take out #1 spark plug and use a screwdriver or similar rod as an indicator and turn the engine over (which will be easier with all the plugs out) by hand so that you can see the screwdriver rise up, dwell around TDC and start falling again. It is difficult for the uninitiated to accurately find TDC that way, but it will do in a pinch. When you are pretty sure you know where TDC is, you need to check the timing marks. If it is not real bloody close to TDC, then you have to question the health of the balancer. Another thing that can go wrong is carbon build up on piston crowns or on the combustion chamber face of the head. These can glow hot and cause pre-ignition, and will tend to do it on light throttle as well as heavy.
