Ill let u know on Wednesday - Im taking it easy until its tuned again due to the rooted cat that I had.
But its coming on boost around 3000.
Also I just found that 26 oil pick up - PM me your address again.
Brad, What Rpm does the T04z hit full boost, say in 4th gear? What rear housing you got?
Hi I have read a lot of the last 247 pages and searched as much as I can but still have a few unanswered questions I was hoping you guys could help me out with. Im putting the rb25/30 standard bottom end engine in a r32 and gonna use a TO4z turbo. The car will be used for track days, tarmac events, and the like.
So here goes…
1. If (can) I use a RB26DETT d-jetro power fc. Ive read its been done before but with what sensors? I’m hoping to use my rb20det sensors and loom.
2. If I use the d-jetro will it control the VVT solenoid in my RB25DET head? If not, can I remove the vvt pulley and cam and use a RB20DET cam with adjustable pulley.
3 If I can I would probably get it ground for longer duration and higher lift, I think SK recommends 264 – 270 duration – but what is the max lift I can use without having to machine anything.
4. Will the PFC run high and low impedance injectors?
5. If the vvt cam is removed can I supply the oil for the cam bearing via the vvt solenoid hole?
6. How do I get top feed injectors to fit an rb25det (side feed) plenum. Is there a seal or o-ring I can use?
Thanks heaps for the help.
Rob.
Do yourself a favour Rob, sell the RB25 top end and buy an RB26 top end. Far superior solution. much easier to work on, cheaper and eassier to get parts for (new and used), designed for circuit work and most of all IT IS CHEAPER when you add it up.
T04Z + standard bottom end = not a good idea
To keep the bottom end alive you are going to be running the T04Z way outside its efficiency.
For circuit work you need response and you are simply not going to get it with that combination.
:) cheers :)
okay lads, im in a bit of a pickle.
i've been looking into results other people have gotten, and i dont see any lowmounts making 700-750bhp. What i've been looking at, is the HKS T04z or HKS T51 KAI BB. Which one will give me the 700-750bhp that i need, on ~1.8bar. Also how much of a difference is there between the HKS ones and their Garrett variants.
What fuel are you going to run to get the 750 bhp?
We have achieved more than that with a pair of GTRS's on Elf Turbo Max.
:) cheers :)
:) cheers :)
at ~$8/ltr c16 or equivalent isnt an option for me.
So normal 98 optimax will have to be it. (it's still street driven)
ELF is what, 110ron? what boost did u need to smack into it to get those numbers?
Shell V Power Racing 100 ron would be better, can you get that where you live?
Boost is irrelevant, after all it is simply a measure of the restriction to airflow, when it is the airflow itself that makes the power. We run ~1.5 bar because we have removed the restrictions.
:) cheers :)
:) cheers :)
yes i'm able to get that shell stuff
interesting indeed, can u give details? i'll pop u a pm
Try a search
"restriction"
"Sydneykid"
"any date"
"Posts"
That should turn up almost everything you need, then you can fill in the gaps with a PM.
:) cheers :)
Try a search
"restriction"
"Sydneykid"
"any date"
"Posts"
:) cheers :)
sweet, give me an hour or two and i'll re pm you. Dont bother replying to that one i just sent u lol.
Forget about whether or not the RB26 head itself is "better", the fact is it will work out cheaper when you add it all up. Inlet manifold, multiple throttle bodies, plenum, top feed injectors, cams, solid followers, no VVT, adj camshaft pulleys, valves, valves springs etc etc. They are what makes an RB26 head the ONLY way to go.
:) cheers :)
Cheaper? The way i see it if you buy a low km import motor and use the RB25DE head then once you put springs in it there is no reason to rebuild the head. So head + valvesprings is less then $800. I happen to have cams to go into mine so thats $1400. Now if i ran an RB26 head then i would be looking at $1500 for a shitter of a head of a blown motor that i would have to rebuilt. So there is $2500 total. If i use std manifold then i have to go twin. So now i have to get an aftermarket manifold.
So...i will stick with the poor mans head...by my calcs its a much cheaper option and after doing some homework there is a bit of thinking that says the RB25 head and plenum will be better for what im doing...Also dont need new harness etc and sensors. And after playign around with an RB26 manifold on the weekend i dotn want to go anywhere near one. And sure as hell dont want to run twins...
As with everything, it depends on your power target. As soon as you are looking for more than 300 rwkw, with any sort of decent response, the RB26 head works out cheaper.
:) cheers :)
Yeh I was looking for a decent GTR head for about 4 months here in NZ and found nothing suitable... One was 2.4K!!!
Unfortunately im pretty committed to the 25 head as i have the intake and exhaust plenum/manifold well under way.
SK could you help out with some of my questions... ive numbvered them just the way u like it :wave:
Just to clarify
2. Can I use some reground rb20det cams to get rid of the vvt and allow adjustable pullies
6. I have top feed GTR injectors and a custom fuel rail, but the injectors dont sit in the rb25 (side feed) holes very well... is there a seal i can use - see pic.
Thanks for the help
rob.
Yes you can run the rb20 cams as long as you modify the water and oil gallery in the head to suit the rb30 block.
SK could you help out with some of my questions... ive numbvered them just the way u like it :laugh:
Just to clarify
Thanks for the help
rob.
god i hate the rb25 head....its so shit. Just a general comment.
I wanna go back intime about a year ago when we first built the 30det so i can do it with a 26 head instead. Curse my old man!
The pig is in the car.
There is always a price to pay so by completely assembling the engine prior to fitting I discovered just how little engine bay room there is. It looks so big when there is no motor in there.
There are always just little things popping up that need to be dealt with like bolts and hoses.
Bursons had a Dayco belt in for me in a couple of hours. Now to bolt up the bell housing and starter and finish the electrics. Might be on the dyno about lunchtime.
geoff you're a machine
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
