urgent help needed pls guys!
my 30 blocks all finished and prepped and i should be recieving a call sometime tomorow when my vvt 33 heads ready to be picked up after welding the vvt feed and slight mod to water gallery to suit the 30block. however while my heads there i thought i may aswell get the head specialist to tap the vvt oil feed in the head.
MY PROBLEM, i dont know excatly where to tell him to do it. can someone PLEASE provide me with some detailed pics both close up and from a distance aswell as some measurments of location so i can get this done. also some info on the sizes adaptor and fitting etc.
ANOTHER issue i have is once oil is supplied to the vvt via the extrenal feed does it need to drain off anywhere?? if so where and how??
ideally i need this info tonight so i can pass the info on tomoro.
i have attached pics of the vvt oil feed i have but cant make it out i need more pics/info.
HELP ME PLS!
HELP ME PLS!
the rb25 vct head has a drain on the exhaust side that it uses for the extra oil fed in.
use a 1/8th fitting
pic of where it is normally put
remember to setup the additional oil drain ont he exhaust side in the sump for this head return.
all pics were taken from this thread btw
thanx for info/pics of feed into vvt, i think ill be able to sort that out now.
however i dont completely understand the vvt oil drain part. can you explain it in rb30det for dummies language/pics.
"remember to setup the additional oil drain ont he exhaust side in the sump for this head return"
so do i tap into the head again for teh drain (where do i do this) ?? and run this into the sump somewhere.
rb25det head already has an oil drain about 15-20mm forward from the exhaust port for cylinder 1.
you need to run the drain line off that flange down and into the sump, so you need a fitting on the sump to accept this line
as you can see in the picture below, it is the gold line infront (left) of the exhaust shield.
GOT HIM!
thanx a lot dude for your help i think youve answered all my questions.
would it be possible to use speedflow fittings and a brainded oil line on the intake side for the vvt feed instead of that one pictured in teh above pics??? what im tryna say is is there a reason for using that piece of tube for teh feed??
nope, can run either the solid tube or braided lines.
use speedflow if you have the cash, if not std gas type fittings that are used in the pics
that isnt my setup above, i think personally from what i have read, that a seperate return that is seperate from the turbo oil drain is a wise idea due to the amount of frothy oil that comes down out of the turbo, but its all up to you
hmm thats something to think about.. use same return as turbo or tap a new one into the sump?? has teh pros and cons to both set ups been covered over the thousand pages lol?? if not please inform me briefly.
also HEAD STUDS.
ill be using aftermarket head studs probably arp, however which ones do i buy??? rb30, rb25, ive heard that your meant to use 26 ones.
which stud is the correct one to use??
Only $360 for the ARP ones :happy:
30 block needs to be tapped n drilled, 25 head needs drilling to fit the thicker studs.
Not a cheap exercise.
http://www.modyourcar.com.au/product_info....roducts_id=3415
$449 bucks for rb26
http://www.tweakit.net/shop/index.php?cPath=57_51_657
$275 for rb25
hold on a minute, are you saying the arp head studs are not a direct fit into the rb30det which uses rb25 head??
no to use rb26 head studs on a 25 head u need to drill the block/head to suit
rb20/25/30 are all the same type 12mm and 26 are 13mm from memory
you just need to source 25 ones :wub:
think the rb25 and rb30 are 11mm - rb26 is 12mm and chev rods are 1/2 inch
Stock RB26 head studs are only $10 ea so $140 a set from Nissan.
Sorry to be going so fast. I NEED to drive this home to Brisbane Saturday, or mostly to get out of Victoria. :happy:
All slow now. Fabricating the stuff to make it fit like induction and throttle cable mount and injector loom. Still to mount oil cooler and need more silicone hose and clamps.
RB25 and 26 have the same TPS plug and Bosch injector plugs (RB30) are $7 at Bursons and a straight fit for 26 injectors. Wired 10ohm 15W resistors in line with the injector loom to match the impedance of the RB25 injectors.
Yes R33Racer I agree , RB25DET/inlet has limits . I wondered for a while if there's any value in using an R34 25DET head on a decent RB25 or 30DET because it gets you into a mechanical valve train though I'm not sure if RB26 cams (aftermarket) interchange . SK tells me that porting wise the 26 is different and impossible to emulate without fabrication . The big issue is that the marketing geniuses at Nissan made very sure they would piss EVERYONE off by not making the manifold patterns common on all DOHC RB heads . To get a mechanical train its R34 25 or RB26 . To get the gun inlet system its only RB26 and then its aftermarket for a single turbo exhaust manifold . You don't really have any choise , if the hydraulic lifters don't limit you the inlet system will . Its a hateful situation but the answer is to bite the bullet or get painted into a corner . Its not all bad though , someone out there should have a use for your RB25 top end .
Cheers A .
yeh id hope so...but we gotta get this new motor making some power first before we even think of doing anything else. Dyno tomorrow arvo for power run to see if we fixed the problem of no power!
But i should start looking around for a busted rb26 or atleast a complete 26 head.
RB26 cams are a direct fit into the R34 head ( after setting the shims etc ) - I am using HKS 272 / 9.35mm cams in mine.
Performance springs make spring and retainer kits for the NEO now also. Also the intake manifold stud pattern on the R33 and R34 are the same as Im using std R33 runners with the CPC plenum - just thought Id mention that.
Cheers A .
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
