nothing in the pdf talks about how to install the jun collar- just says its recommended.
nor does it answer my questions about oil restriction.
well read the damn thread, i know for a fact someone has posted up precise details of whats needed to install it, and gave an alternative, of one that proengines do, for about ~$130.
Is anyone using an ATI harmonic balancer ?
I just want to know what part number balancer they are using...
when i bougt mine 2 months ago
ATI917752 $1035 + GST/nil stock. (RB26, direct bolt on,-R32 for cars making 600-1000HP)
ATI917753 $1035 + GST/in stock. (RB26, direct bolt on,-R33-R34 for cars making 600-1000HP
form rocket industry's
Make sure the one your getting has serpentine belt drive unless it's a race car
But u can get them at perfomancewholesale.com.au for around 1000
cheers
Edited by kastin
i know this is an old post and ill get told to read the post for this question, but what engine harness and computer did people use for this conversioni was going to get a custom one made up but i dont know who would do that either. some help would be greatly welcome!!!
Page 5 of 8 in the PDF (which is in the 1st post of this thread) states the following:
ECU
Use the corresponding ECU to the head you are using. It simplifies wiring, injector and sensor compatibility.
The R32 ECU’s can be re-mapped; AP Engineering PowerFC’s are also available.
Ensure the ECU you select supports the following features:
• Close loop – fuel economy
• Knock Sensor – Safety
• Sequential Injection – Fuel Economy & higher average power
• 6 ignition drivers – Doesn’t overwork your coils
The R33 & R32 ECU’s will run the RB30DET with no problems for the run-in period.
Now if you had some common courtesy, you would have taken my advice and atleast read the PDF, yet you couldn’t even be bothered doing that. How farking stupid are you?
I've read the PDF about 10 times so far just to get a good understanding of the general conversion. I stress "general" as the PDF does not go into details. I've read well over 3/4 of this thread too (very draining but informative) but I still have these questions:
1) How much of the "extra" bits n bobs do you transfer over to the RB30? (Alternator, P/S Pump, thing behind oil filter, hoses brackets etc)
2) Does the RB30 block have the same mounting holes for all these brackets (in roughly the same places) ?
3) The stands which go onto the engine mounts - did people re-use the RB30 ones of the ones from their original motor?
4) When blanking off the rear oil gallery (instead of putting in restrictor); where does one get the part to block this up or is it simply weld n smooth?
Thanks guys!
S
Thanks guys!
S
The best way i found to understand it all, is to grab the block and start playing with it as to what fits etc.
1) Keep all ur ancilleries, double check the brackets fit on the RB30. For the oil filter housing, this is what i did; Have an oil cooler with relocator, so just screw the sandwich plate from the relocator to the block, mounted the pressure sender & oil temp sensor a different way (have a look on the block and you'll easily see what u have to do).
2) All the same holes except for the engine mount brackets
3) Have to re-use ur old ones, RB30 ones are on different angle/length.
4) Not sure about this one, my engine builder took care of that >_<
Hope that helps :(
Thanks a bunch shanef!
Final question; promise... what is the more popular way of running the new timing belt? Re-using the tensioner on the RB30 or tapping a new one into that flat machined surface?
I've seen a few hybrid setups now and they differ in this a lot - seems that some think it's OK to re-use the old position whilst others don't. I mean; on the RB25s and 26s i've seen; the belts come fairly close anyway - the only difference on the 30 is that the belt comes a few mm closer (but at tension I don't see this being a problem).
for peace of mind get the new one machined in, it's a pretty simple task >_<
Cool... thanks guys!
Cubes - page 90 or so (40ppp) you said to use the harmonic balancer suited to your car; but then someone said that all the balancers are interchangeable... to keep the original motor as "intact" as possible; is the RB30 one useable or is this NOT reccomended?
use the one for ur head. some have different teeth on the belts so itd be easier to just use the one for ur head and ancillaries
If you want to retain the skylines alternator, power steer and aircon you must use the skylines balancer. >_<
All your essentially doing is dropping an rb30 bottom end under the DOHC head and bolting on all the skyline bits.
Its definitely not difficult and shouldn't be over complicated as apart from the powersteer bracket everything simply bolts up.
The guide pretty much has everything in it you need. If it doesn't mention it you don't need to worry about it. :(
It could do with a bit of editing regarding the oil restrictors. It would be good if some of you could share what you have done and what oil pump you are running. :)
I do have SK's list but its always good to see what others are doing and how its working. :)
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah...but NA Mercedes V12.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
