thanks Craved, is the other whole the VCT return and if so do i have to block it aswell and plumb a return in?
I will not be usibf VCT now and never will so i am looking for the simplest solution.
I think you have to put a grub screw or weld the oil return as it doesn't line up with rb30 block and then you have the external oil return plumbing back to the turbo oil return line.
I haven't found a suitable head yet but you can check this with a head gasket if you've got one. If the oil return on the head and the block lines up with the hole in gasket just leave it unplugged, if hole in the gasket doesn't line up with with block assuming you're using an rb25 gasket you'll have to block it.
Thanks BAMR33.
I have pretty much got it worked out. that photo shows turbo oil and water return and also another return from the front of the head that is tee'd into the turbo oil drain. but from what I can see no VCT :)
I have drilled and tapped the VCT feed to M8. and will be putting a grub screw in there. I have also drilled and tapped a new supply point in the VCT gallery on the front of the head about 50mm higher that it has been blocked off. I just need to get a few fittings and it will all be sorted.
I havent got my gaskets yet. but will take a lot of photos of the build for others.
I think an Apology is in order for Gary (Sydneykid). :thumbsup:
I doubted his suggestion that a 1.5mm restrictor up front and rear blocked off was perfecty fine for the R32 RB25DE head with no VCT.
So I went and did it anyway :) and it is 11ty billion percent fine.
Plenty of oil up top; top ends nice and quiet; no tapping when it comes off a rev; its all good. :D
So my apologies Buddy! :)
I do know of a RB30DET that ran with 2 x 1.1mm restrictors and that had the lifters tapping a tad after a high rev pull.
Not sure the flow dynamics of it all BUT is it possible the 2 x 1.1mm restrictors results in less oil pressure up top than a single 1.5mm?
Im running 2 x 0.75mm restrictors, but do have solid lifters in the NEO head.
So I went and did it anyway and it is 11ty billion percent fine.
Here are a few pics of the dummy assembly of my 26/30, have the follwing mods.
post-20864-1186309640_thumb.jpgpost-20864-1186309749_thumb.jpgpost-20864-1186309762_thumb.jpgpost-20864-1186309790_thumb.jpg
Arias 40 thou forgies (ceramic coated)
8.8-9:1 comp
25thou squish
eagle forged rods
knife edged, cryogeniced and balanced crank
N1 oil pump
crank collar(proengines)
8l sump
main studs
head studs
Cometic or HKS head gasket
Ported head with 1mm o/s valves
HKS valve springs
Toda 10.2mm 272deg cams
Adjustable camgears
720cc sards
HKS FPR
Nistune ecu(coming)
Modified "Sub-zero" inlet manifold
90mm throttle body
modified AFM
HKS low mount T45S turbo kit(ceramic coated)
50mm wastegate(ceramic coated)
probably WM injection
MSD dis-4
M&W coils
Home made Sump adapter
Hopin to make close to 450rwkw
PS does anyone know what valve clearances to run?
Pressure is a measure of restriction, not flow. It is a function of flow though.
Maybe it was just a bit loose up top....
And SK does now his stuff :thumbsup:
And SK does now his stuff :)
So saying that would it be possible for the larger 1.5mm to flow more of that 'thick' oil than 2 smaller 1.1's?
Imagine a thick gel pushing through 2 1.1mm holes, it may not flow through at all; then a single 2mm hole it may. If that makes sense. :S
In a way similiar as to selecting the correct viscosity oil for a given bearing clearance.
Gut feeling says no. Maybe its bottom end was on its way out as 6months later it did spin a bearing.
I should also say its getting NO blowby. Absolutely nothing and there's noticably more oil sitting in the sump with the motor running.
Prior with it idling around the oil level would suck to the Low mark. Now it sits 3/4 up. :thumbsup:
It should flow more through the 1.5 even though the 1.1s have a slightly larger cross sectional area, due to the surface roughness equations and the interaction of the sharp edge orifice/turbulent layer effect, but then there are journal clearances to consider. It's never exact.
If the bottom end was on its way out then likely the head rattling was an indication of lack of flow. It is a closely balanced equation for the distribution of flow and so tolerances need to be carefully guaged and the correct bearings ordered. The one area though that can end up with too much flow is the head so we restrict flow with the smaller restrictor.
That's why I would never recommend running in an RB30 on a standard ECU, the richness will stop the rings bedding in properly and in extreme cases lead to glazed bores. The retarded ignition results in incomplete combustion which fouls up everything from plugs to cats.
:P cheers :D
And indeed the cat light did come on once for about 3 seconds at the top of a long hill last time I drove it - and before seeing Sydneykid's posts. Haven't dropped the pipe yet to have a look at the cat, does anyone know for sure if I should expect dead / highly degraded / clogged cat? Of course if it's obviously shagged I'll get a new one but I've never shagged a cat before (go on laugh) so not sure if the temporary overheat would be catastrophic, would prefer to avoid the cost of a new one.
And I've loaned a PFC, dyno on Wed morning to sort this out.
Cheers
can i get some opinion of people's 2nd choice of pistons (apart from CP 9:1) for an rb25/30??
car will only run about 1bar of boost
im undecided but thinking about these Arias
p/n= AP332104
10.6cc dome top
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 9.2-9.4
I had no issues with Arias. Nice and quiet, did what they had to do.
Decent CR so you don't have to substitute with boost so great off boost response and can stick to a smaller turbo. Works for me.
Cheers
so...
checked plugs, no signs of over being rich
PFC tune yielded
264 rwkw @ 7000 (up from peak 220 @ 6500)
10psi
AFRs below 12 on boost
Inj Duty 71
much nicer to drive - as crisp and responsive as normal. :)
now for the run in...
Edited by Scooby
Hi guys.. My car is auto and i'm wanting to see 500rwhp...
1. After talking to my turbo guy he has me in two minds as to which turbo to use. I was happy to use the Garrett GT35R with the 0.86 rear but after talking to him today he has said he would reccommend the 1.06 rear as it will suit my 5000rpm stall converter. What would you use ??
2. I have the RB30e series 2 block (with the turbo fittings) and a R34 GTR head (20,000km). I havent seen mentioned weather this head is different to the R32/33 GTR heads. I have no experience with the specs of these cars and all i can find is they run different cams/valves. Do i just treat the R34 head as if it was an earlier model when building the motor ???
3. Please forgive me as the last cam I replaced was a Holden 308. I would like the "lumpy" "angry" idle as heard on some GTR's, what cams would you suggest for the R34 head or would you just get adj camgears ?? Not really willing to rev past 7500rpm if i don't have to.
Thanks for your feedback :huh:
Cheers
Steve
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
