Wrong.
The best choice is the one that suits your car (unless you have a 19th century technology R31 or earlier). Then you work around that. I have the 26/30 in the GTS25t with 26 plenum and throttles and TT's and run it all with the 25t PFC, and the only sensor changes were the z32 and the water temp sensor since the 26 sensor maxes the temp signal. Even as a TT I have it set up for single AFM. I also have a single O2 sensor at the split pipe join.
If you have to use twin AFM's then you can wire it to supply an average input from the sensors.
Cummon geoff, how is an s15 PFC going to run an rb30, just cut two cylinders off?
Good point, but I thought we were talking about cars and not silvias and the like..... :wave:
Could be a bit of a pig to splice in, but that's the fun of it.
admit it geoff, u farked up
typical victorian :D
it was tight as shit to get on
but once it was on and we loosened the tensioners it sat nicely
tightened everything up and shes perfect
As stated earlier the head is on, cams are in, water pump, oil pump and tensioners are in. I ended up buying new RB30 tensioner studs from nissan. the guy asked me why I needed 2 and the conversation ended up with the dude being very confused :0 till I said think 3 litre RB25
Same results here with the RB25DE R33 head. it was a bastard to get on but now it is on the tension seems fine. you can just twist the belt 90deg.
I also read back something on cam journals seeming really loose. I have tightened mine up to 13.8nm. that is as low as my torque wrench goes. the specs say 9 to 12nm. is this going to be too tight? the cams will turn with some resistance. not much more than if there was 2nm holding the journals down.
Also fitted new rear main seal tonight. that was a bastard to get out. the old one was caked in there pretty good and its a tight press fit to get the new one it. but its all done.
The head I bought was a complete head that had been dissasembled and now I am getting down to the last few things I am starting to find little bolts here and there are missing. no biggie but i now have to find a few difficult parts.
1 cam journal bolt and washer
2 VCT cam wheel cover bolts (tiny m4? bolts)
1 exhaust cam wheel bolt
thats about it. soon as I have those bits she will be a complete engine.
I would really like to start it out of the car but I don't have a spare loom. Can't wait to get it in there.
Bastardized R32 GTS FTW!!!
If any of you guys have any of the bolts i need lying around please let me know
on topic FTW!!!
I am in a bit of a dilemma with my turbo and would like some advice. I am going to use my sliding performance RB25 hiflow with my 30det and am well aware the exhaust housing is WAAAAY to small. it makes 240rwkw on my RB20 and I would expect it will make 250 to 260rwkw on my RB30det.
that figure is pretty close to my power target but i imagine it will come on way to quickly and choke around 5000rpm. so I have been thinking about getting a bigger exhaust housing. something around .80
I have no idea on the internal specifications of the turbo as it is a hiflow. if I could get 260~280rwkw from this turbo with good response and not choking untill 7000rpm that would be fantastic.
The reason I want to stay with this turbo is that it is new and looks standard. the whole car is built to look standard and i want to keep it that way. so an aftermarket turbo is out of the question.
What sort of housings can fit standard RB turbochargers.
Thanks!
hey CEF11E
i should have spares, not 100% but ill check
pm me with wat u need (just in case i forget) and ill take a look
on topic FTW!!!
Thanks!
AVO do a .86 ex housing to suit a stock rb turbo, but i think they are about $800
I just found those :D and after a bit more looking I spoke to precision turbochargers. the guy was a champ. he told me he could adapt a garrett internal gate .86 housing to my turbo for about $700. that sounds pretty good.
either that or sell my hiflow for $800 and put another $800ish towards a newie. bit it will not look stock.
I know I am living in dream land but I want a responsive 400hp pop the bonnet stock looking R32 :P
I think for now I am going to put the hiflow on as is and see how it goes.
You could always have the GT3076r fitted up to the .86 garrett IW and have the RB25det comp cover machined to suit. Be sure to grab the .6 comp cover and spend an extra $250-300 on machining the std comp cover.
At a later date when you get hungry for more strap on the .6 comp cover.
I'm almost certain the .6 comp cover would cost more than $250-300 so often when the turbo shop offers a 'deal' to machine your comp cover in return to keep the garrett comp cover its not really a deal that is good for yourself. :rofl:
That would look stock and push 450hp.
Aim for 450-500hp; I find mines starting to feel a little slow. Which had me briefly thinking; I wonder if its lost power. lol
I really do think the GT3076 .82 IW feels perfect for the street; instant off idle response in first gear; no lag just a strong off idle pull.
The dyno sheet really doesn't do it justice how it drives in the lower gears at part throttle on the street.
who's using an ATI RB26 balancer? question I have is weather you can get away with using the std RB25 power steering pump/pulley which is only 3 grove belt with the RB26 harmonic balancer using 4 grove pulley. I know the std pump needs to be spaced forward roughly 6mm, anyone had success with this or do you have to have a 4 grove pulley?? anyone made up a pulley for the RB25 pump?
I have used a balancer with 4 ribs for power steering and only 3 ribs on the p/s pump. it does work fine but took a while to get it right (3 power steering belts) It does not come off even at extended 7000rpm use
hope this helps :)
hope this helps :P
Sweet, Thanks! I was thinkin it would be as long as it lined up spot on, thought id see what other people had done/doing. Guess I can only F@#k it up!!!!!
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
