Only in the fact that it has to physically pump more oil around (extra oil in the lines etc) Personally I doubt an oil filter relocation kit would have enough effect to actually starve the head.
Edited by MintR33
also what sump would i have to use to run in a s15?
That would depend on where you have the motor sit in the bay, best to install the motor without the sump, fabricate the mounts to suit, then see clearances to the cross member and sway bar etc
or have a chat to Fatz regarding what they did in his S13
I haven't used SolidWorks as such, but I used to work for an automotive R&D company and there I used SolidEdge - pretty much just a leaner version of SW :) At the moment I use microstation to do all my drawings whether they be .dwg or .dgn.
</back on topic>
Waiting for my N1 oil pump and bearings to arrive then my RB30 will be running again.. after xmas will probably see a GT35R get bolted on :huh:
I'm just about to get the cams sorted from Tighe cams for mysetup.
I've been recommended by both my tuner and Tighe cams to go the 265/265 in/exh.
My only small concern is will the 265/265's lope over noticeably on idle? A mate has the 254/254 cams and the idle is baby smooth; the note did change slightly but there is no lope.
If the 265/265's do lope would the 254/265 setup smooth the idle?
I wouldn't mind a slight lope but I've been you tubing SR20's (same bore stroke) with 264 cams and they lope over like bridgy's. :S
All though the SR's do run a LOT more lift that I will be running (8.9mm).
The cams are hydraulic so no doubt slightly reduced ramp rate which may also smooth idle slightly compared to rb26 solid cams.
Any guesstimates based on sort of similiar experience? :S
Considering the cams you are running at the moment, either setup will be a vast improvement. Being that you aren't running a huge turbo, the power difference of the 264 inlet cam over the 254, i wouldnt expect to see an extra 20rwkw between the two. Its all up to you, but considering you are almost at the limit of streetable 2wd power, i would go the smaller inlet, to maintain the low rpm torque, and idle quality, but its all trial and error.
Cheers Adriano,
I do plan on dropping a GT35r .8 on it at a later date once I push the limit of the GT30.
As Uni is now all done with and I'm working I have a fair bit more $$ to throw at the car and have some fun with it down at Mallala. So it will be primarily a car I race down at the track. Similar to the Troymeister but I'd still like it to idle 'ok' so it doesn't attract too much attention. :(
I'm hoping some one has played with 265 cams in a hydraulic head and the RB30. ;)
this vid is of a 33 gtst i've help built this year. its a built rb25, solid lifter head, 260/9.15 cams, big port work both sides, os valves on the exhaust side. its just sounds pure porn at ilde (~900rpm), and u should hear it on full noise ;) *creams pants*
http://smg.photobucket.com/albums/v315/Tha...urrent=Idle.flv
Sounds very very nice. I've replayed it over and over and over. I could listen to it all day. lol.
All though partially due to the solid lifter setup. Hydraulic cams sound much smoother. :) A good thing for not being defected though. ;)
Cheers Shane. :(
All though partially due to the solid lifter setup. Hydraulic cams sound much smoother. :w00t: A good thing for not being defected though. ;)
Cheers Shane. :)
i know myself and the owner dont get sick of it hahaha
they can be turned so its not as 'raspy' on idle, but then there goes hp, and who wants to do that? :(
he's running a 35r with the .82 rear, and power tips over at 8000rpm (although 1 silicon joiner is sucking closed at high rpm so that could be playing a part in that) so i reckon something closer to 270deg would be ideal on an rb30 with the 35r
they can be turned so its not as 'raspy' on idle, but then there goes hp, and who wants to do that? ;)
[/quot
How many ponies did it produce?
................(although 1 silicon joiner is sucking closed at high rpm so that could be playing a part in that) ......................
How could that happen, unless the joiner is before the turbo (intake pipe)?
You could try sourcing a set of A'PEXi 270 degree cams, pretty sure these retain the hydraulic lifter setup... from memory they run 9.0mm lift.
The downside is they went out of production some time ago so Yahoo auctions may be the best bet...
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
    • Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
