A question to those who have done the conversion with an RB25 head + Greddy Plenum with throttle body adaptor.
What have you used for the throttle cable? The factory one is too short even with the brackt supplied with the kit.
Edited by MintR33
Ok, guy just reviewing, the one idea i read about, shaving the head to lower the compression with the combination if a rb30et bottom end and a rb25det head, causing a low compression around 7:1
anyone have any take on this? im prepared to do it, id love to know of anyone who is certain this can work, any feedback is good, im trying to u the compression, i have a
huge enough turbo as it is, not happy to bog it down even more.
Wouldnt be much meat left in the head after you had milled 2mm off it.
Why not just buy some CP pistons :-)
You would need to take about 2mm off the head to get the comp up from 7:1, Why not use an rb30e bottom end, you start with a much better comp ratio.
the acl im using were designed for the hybrid conversion, the engine builder that im using had them from a previous build that didnt happen, ill have to see what the comp works out at, but they are practially flat top, so ill have to post it when i figure out the comp
ACL DONT MAKE THEM
as far as i know acl dont make them...however they do make custom pistons i think...so unless that engine builder got them made to suit the conversion especially for that job? That is possible.
Where can they be ordered from? Dropped the motor in thursday arvo and just need the throttle cable and i/c piping fabricated :D
Sorry no idea; i leave those details to my mechanic :D I probably wont see him till Friday, and by that time i'll probably forget to ask :)
Nice looking engine bay! :(
just responding about the comment about shaving my head 2mm to raise the compression ratio from 7:1 umm, what would that make my compression, i got this rb30et motor comlete for an absolute bargin runny rebuilt. which is why i want to try use this.
would it improve much in commpression?
its a waste to replace pistons on a motor that was just rebuilt for CP ones. and the cost of the money involved
id love sugestions
Sorry no idea; i leave those details to my mechanic :( I probably wont see him till Friday, and by that time i'll probably forget to ask :(
Well my memory didn't fail me this week :)
My mechanic gets his custom cables through Speedscrene, link below:
Speedscrene Homepage
hey guys wats up, my thread got closed cuz hey, theres this one. so here it is.
i just sent my car in to do the 3.0L but as far as i know little info is available with r34 motors.
was wondering if anyone could give me some tips as to wat to epect or prepare for.
the cars currently got a few things going as well as the motor being ripped out for inpecton
heres the list so far
gt35
plenum
throttle body
injectors
clutch
manifold
dump/front pipes
cams
rods
pistons
not sure im specs but its just to give u an idea. any thoughts on problems or hassles i might run into?
ash closed ur thread caus u didnt read THIS thread. as per his post all of the info u need is in this thread, dont be lazy and read it, like everyone else had to :)
:P ill get back to u in a few years then.
nah seriously, ill have a read thanks
You've got the plenum and all the bits so it will simply bolt together with a few small mods to powersteer brackets, dump pipe etc.
As for what to expect.. 'possibly' earlier spool and more power everywhere.
You've got some one else doing the job so expect to be broke by the end of it. :P
You sent your car in for a 3.0L conversion and you don't know what to expect? Are you made of money or something???
u wouldnt believe how good i am at my job :P
You've got some one else doing the job so expect to be broke by the end of it. :)
AHAHHAHA i didnt mean wat to expect as in power figures.
as in will i run into certain problems having the 3.0L
also i have been talkn with a friend about possibly getting rid of the 25 head and slammin in a 26 head, resulting in not buying a plenum(save 1k) and selling the motor as a whole to have some $$$ in my pockets.
does anyone see this workn?
Edited by R34NRG
Ahh so you don't have a plenum. I skim read. :P
Its difficult to find a decent 26head for a 'reasonable' price.
Stick with the R34 head, nothing wrong with it. It runs solid followers which is a big bonus.
But yeah depends if you can source a decent 26head without being too out of pocket.
There will be no problems. Its an easy conversion in the RWD.
Technically you shouldn't be charged a great deal more compared if you were going to swap another rb25 bottom end under it.
The only real mods off the top of my head for yourself will be the powersteer bracket, dump pipe, drill/tap of the upper tensioner, run the VCT oil supply, block off the block to head vct oil supply, run a front oil drain.
So not a great deal.
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
