A question to those who have done the conversion with an RB25 head + Greddy Plenum with throttle body adaptor.
What have you used for the throttle cable? The factory one is too short even with the brackt supplied with the kit.
Edited by MintR33
Order a custom length cable. Will be doing it with my GReddy plenum and Q45 tb. But i have seen others with std tb and adaptor plate also need a custom cable.
Ok, guy just reviewing, the one idea i read about, shaving the head to lower the compression with the combination if a rb30et bottom end and a rb25det head, causing a low compression around 7:1
anyone have any take on this? im prepared to do it, id love to know of anyone who is certain this can work, any feedback is good, im trying to u the compression, i have a
huge enough turbo as it is, not happy to bog it down even more.
Wouldnt be much meat left in the head after you had milled 2mm off it.
Why not just buy some CP pistons :-)
You would need to take about 2mm off the head to get the comp up from 7:1, Why not use an rb30e bottom end, you start with a much better comp ratio.
the acl im using were designed for the hybrid conversion, the engine builder that im using had them from a previous build that didnt happen, ill have to see what the comp works out at, but they are practially flat top, so ill have to post it when i figure out the comp
ACL DONT MAKE THEM
Where can they be ordered from? Dropped the motor in thursday arvo and just need the throttle cable and i/c piping fabricated :D
Sorry no idea; i leave those details to my mechanic :D I probably wont see him till Friday, and by that time i'll probably forget to ask :)
Nice looking engine bay! :(
just responding about the comment about shaving my head 2mm to raise the compression ratio from 7:1 umm, what would that make my compression, i got this rb30et motor comlete for an absolute bargin runny rebuilt. which is why i want to try use this.
would it improve much in commpression?
its a waste to replace pistons on a motor that was just rebuilt for CP ones. and the cost of the money involved
id love sugestions
Sorry no idea; i leave those details to my mechanic :( I probably wont see him till Friday, and by that time i'll probably forget to ask :(
Well my memory didn't fail me this week :)
My mechanic gets his custom cables through Speedscrene, link below:
Speedscrene Homepage
hey guys wats up, my thread got closed cuz hey, theres this one. so here it is.
i just sent my car in to do the 3.0L but as far as i know little info is available with r34 motors.
was wondering if anyone could give me some tips as to wat to epect or prepare for.
the cars currently got a few things going as well as the motor being ripped out for inpecton
heres the list so far
gt35
plenum
throttle body
injectors
clutch
manifold
dump/front pipes
cams
rods
pistons
not sure im specs but its just to give u an idea. any thoughts on problems or hassles i might run into?
ash closed ur thread caus u didnt read THIS thread. as per his post all of the info u need is in this thread, dont be lazy and read it, like everyone else had to :)
:P ill get back to u in a few years then.
nah seriously, ill have a read thanks
You've got the plenum and all the bits so it will simply bolt together with a few small mods to powersteer brackets, dump pipe etc.
As for what to expect.. 'possibly' earlier spool and more power everywhere.
You've got some one else doing the job so expect to be broke by the end of it. :P
You sent your car in for a 3.0L conversion and you don't know what to expect? Are you made of money or something???
u wouldnt believe how good i am at my job :P
You've got some one else doing the job so expect to be broke by the end of it. :)
AHAHHAHA i didnt mean wat to expect as in power figures.
as in will i run into certain problems having the 3.0L
also i have been talkn with a friend about possibly getting rid of the 25 head and slammin in a 26 head, resulting in not buying a plenum(save 1k) and selling the motor as a whole to have some $$$ in my pockets.
does anyone see this workn?
Edited by R34NRG
Ahh so you don't have a plenum. I skim read. :P
Its difficult to find a decent 26head for a 'reasonable' price.
Stick with the R34 head, nothing wrong with it. It runs solid followers which is a big bonus.
But yeah depends if you can source a decent 26head without being too out of pocket.
There will be no problems. Its an easy conversion in the RWD.
Technically you shouldn't be charged a great deal more compared if you were going to swap another rb25 bottom end under it.
The only real mods off the top of my head for yourself will be the powersteer bracket, dump pipe, drill/tap of the upper tensioner, run the VCT oil supply, block off the block to head vct oil supply, run a front oil drain.
So not a great deal.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
