have done some serious searching on the XR6 turbo topic not "that" much out there but from what I can see it should be fairly suited to the 3L bottom end
anyone got anything to add regarding this turbo?
Hi Guys,
Ok well if all goes to plan I am buying a 25/30 in the near future the motor It is one of the RIPS ones from NZ
http://www.ripsltd.co.nz/performance/products.html
It has an R32 RB25DE head I am putting this into my series one R33 GTST motor is being supplied with loom and stock 32 computer, so heres the question:
What will be involved in hooking up my RB25DET PFC to this motor?
I was thinking for ease of conversion just fitting the motor up and getting it all going with the supplied computer later as I can have the car off the road for too long to start with then revisiting the computer side a little later on although if there is not much to it i would prefer to be running the show with the power FC
One thing I was also wondering about will my Splitfires fit this head?
Motor is being delivered with a new XR6 Turbo fitted up, is that basically a GT30? Should it make decent power with that?
Initial goals once I put injectors in would be 300kw (only stock injectors to begin with)
Cheers,
Dan
Why buy an exorbitantly priced RIPS engine when you can build you thats easily as good locally and for probably much cheaper? Spoolup can sell you half the parts here.
Its all in this thread.
I looked into the PFC for ages also and its probably much easier to change the computer. A link G3 computer with wasted spark is a great setup at half the power fc price, simply as you wont find a 32power fc computer, and modifying a 33 one is lots of unknowns
the xr6 turbo is a genuine garrett 35/40 and is a spot on turbo for the 3L bottom end in respect to topend power and response. Just look at some of the dyno results with the 35/40 and you can see how well it performs. The only difference i'ce noticed is the xr6 turbo has a slightly different front cover (doesnt effect anthing, just looks different), and is internally gated with a 1.06 rear housing. If you talk to different people some will recommend the .82 housing over the 1.06, but i think any difference would be minimal with spoolup time with the 3L bottom end anyway.
Good thing about the xr6 turbo is that they go pretty cheap (all the xr6 boys upgrade) so you can cash in on that. A mate of mine has 460rwhp on 19psi boost on his xr6turbo and another has just pumped over 550rwhp on the stock turbo (gets full boost by 2500rpm). Bloody great turbo imo
Has anyone else had problems getting the crank timing pulley off the RB30 crank?
It's supposed to slide on and off according to the service manual but mine is fairly wedged on. Blow torch and pry bar moved it far enough to ease the crank out of the block but I still need to get the old oil pump off :)
Also, while everyone is talking about turbos... am I being optimistic to think a Trust T78-33D with its smallest (14cm) housing would get close to full boost by 4.5k rpm? I know it all depends on cams, tune and all the rest. I'm just looking for a round about figure to estimate it's response. I don't really want to buy it if it comes on way too late and makes the car useless for anything but the drags.
Block is going off for a bore and hone tomorrow to suit the CP Pistons then I get to start assembling and hopefully I'll be running it in for the new year.
It's supposed to slide on and off according to the service manual but mine is fairly wedged on. Blow torch and pry bar moved it far enough to ease the crank out of the block but I still need to get the old oil pump off :domokun:
the harmonic balancer is on a key and is pressed on when the bolt is tighted up, so once the bolt is undone its still pressed on. You needed a harmonic balancer puller (supercheap sells them), and woolaa off it comes.
The balancer is off, its the sprocket between the balancer and the oil pump that the timing belt sits on. I've got a puller, its just got no holes to attach bolts to. I'll probably have to drill and tap some?
It 'should' just slide off, but its being a major pain in the ass
Cubes - they will be a stroker crank for the RB30 block - aiming for 3.4 litre.
Billet forged 4340 with wide oil pump drive.
interesting...
>GT42R or fail :domokun:
RB30 block
actually he dosnt. i asked him when i saw him. unless i misunderstood but he explained his using something else. he complained that a 3.0L was to much of a hassle. he used something smaller size wise. :domokun:
awesome news brad! Kyle was talking about doing a stroker conversion kit for the rb30's to bring it up to 3.3 or 3.4 litres also. But that was a little while ago. If youve got it going already thats great.'
I think we will be due to build a new race motor in the new year when we get back from the states. Depending on price, I could con my father into a stroked rb30 if its not too exxy.
Im buying a RIPS engine that someone else imported into australia that didnt end up fitting up in his 260z
$4500 gets me the RIPS RB30DET Motor+XR6 Turbo+Heavy-duty Clutch+RIPS Forward facing Plenum/Throttle body - nothing has been run yet all new
Tell me thats not a good deal?
I had not really thought of it but I guess I could swap the heads on the two motors and I could save myself a bunch of dramas aye only thing is how would that go in regard to the forward facing plenum? would the RB25DE be the same fit up as the RB25DET???
Basically I want the smoothest transition possible...
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
