Interesting, my 25DE head has Tomei poncams for a RB25
It's the stud pattern on the plenum side which is different, it is the same as RB20 - 25 greddy plenums don't bolt up which is why I'm getting a RIPS item. Cams are the same as my mate had poncams in this head before I got it.
So I started the car for the first time just before... Unfortunately I cant get an oil pressure reading on the dash... I pulled the oil filter off and it's full of oil. The only thing I can think it could be is that the RB25DET water/oil cooler which houses the sender is not compatable with the RB30 Block... Is this right?
Edit, I took the sender out and a heap of oil drained out from the hole. I guess this means the sender is getting plenty of oil supply. How else can I check to make sure the motor is getting Oil pressure? I've pulled off the oil fill cap and had a bit of a look down there, a few drops flew off the cam but nothing excessive. What should that look like?
Edited by MintR33
You know there is a wait lasting months dont u? I hope you do!
Sounds silly but its plugged in correctly?
Were the head oil restrictors replaced after cleaning up the block?
If there's very little oil pressure you will hear the hydraulic lifters tapping. All though if you have had the head reco'd and lifters bled you will be none the wiser as the lifters tick after they have been bled anyway. :rofl:
Grab a cheap aftermarket mechanical oil pressure gauge to check for oil pressure. Its not worth the damage that can be done if there is a problem with oil pressure.
I've lined up a 2nd hand one :banana:
And yeah, get a mechanical oil pressure gauge. I use an Autometer one and it's fine, I always thought the stock gauge was fkd as it the needle barely moved off 0 but now with the N1 pump it actually reads pressure! (guess the oil pump on the 20 was getting VERY old and tired..
Edited by bubba
ok, I've pulled all the plugs out, fuel pump fuse, and sprayed the sender with a heap of crc to try and dislodge and possible crap. I then filled the sump with an extra 5L of oil to help get the oil level higher than the pump and ensure the pump primes properly. Ive cranked it over and pretty confident oil is reaching the head as the cam bearings seem to be well lubricated. And so does the cam area in general. Looks like the sender could be stuffed, but I better get that mechanical gauge just to be sure...
Looks like after Xmas now :-( my local exhaust shop wont be open until 7th Jan, also waiting on a throttle cable too :-)
Will be spending a while driving her around the hilly area's around here to run it in, won't be able to keep the smile off my face though, the car hasnt moved from my shed in almost 3months :happy:
Edited by MintR33
My cars been sitting on a farm for the last 2/3 years and things are now only getting somewhere now!
The guy whos tuning my engine (he tunes the rips ones) runs the thing on the dyno. By the time the car is finished (1 day) its producing full power. Interesting take on things i thought
Sure you can run the engine in on the dyno, as long as you run it though the various load cycles, it's no different to running it in on the road. That's what we do on the engine dyno with a new engine, we don't want to put it in the car (to run it in) then take it out (to tune it) then put it back in the car (to race). That's a lot of workshop expense, so it is cheaper to use the engine dyno time. Plus the engine dyno has a "running in" program, you just kick it off and then go and work on something else. There are the usual safeguards that shut the engine down in a controlled fashion if soemthing happens, like high temps or low pressures.
But for a chassis dyno it is much cheaper to run the car in on the road, having the dyno tied up for a whole day running in, with the operator sitting in the car varying the loads, is expensive. Plus you have issues with the gearbox and diff overheating because there simply isn't the same amount of airflow that you get driving along the road. We run 2 dyno fans and it still isn't enough airflow. So you have to stop for an hour or so every 20 to 30 minutes to let things cool down. In summary it works, but it's expensive and not good for the drivetrain.
Happy New Year
Gary
My 25/30 is almost ready to crank over for the first time.
I'm using:
rb25 pfc
33 rb25det head with std cams with vvt
Gt35R 0.86
Q45 maf and tb
std injectors
greddy plenum
9.2 comp (arias forgies)
After some feedback on what changes were made in your setups/ pfc's so it was safe enough to run the engine in for the first time or drive to a tuner.
Edited by Alf
Deposit Payed organising freight and full payment at the moment of the RIPS motor - WOOHOO!
Ok so I'm still trying to work out the best way to get the new motor happening in my car (R32 RB25DET head on 3L -> R33 with R33 PFC)
have been thinking swapping the heads around putting my existing 33 head onto the new bottom end but it seems such a shame to tamper with a freshly built and setup motor also this way i get to keep that snazzy RIPS plenum!
I have been doing as much searching as possible and along the way found this:
http://www.skylinesaustralia.com/forums/Rb...;hl=RB25DE+Head
ok so I would need to do this? yes / no
now as I have been informed the R32 25 head utilises top feed low impedance injectors like the gtr that was one of the problems but if I was just to order top feed high impedance injectors (Greenline has 650cc Sards at a great price) I wouldn't need to run any form or resistor as the impedance would match my R33 PFC
Anything else I have missed? That seems to easy?
Pull old motor out bolt new one in
Plug everything in hopfully everything reaches? Little worried about throttle cable?
Fab new intercooler pipes to match forward plenum
New Intake pipe for new turbo
New dump to match new turbo
Tow to tuner
run in new motor
tune
WILLOWBANK!
One of the reasons i am stressing is a mate of mine is at the tale end of a 8month RB26 -> GTST conversion and nothing ever is as it seems, so I want to get it all clear in my mind what goes where and what im in for as to not have the car off the road for too long. (read: hopefully no more than a week!)
Cheers!
Dan
Everything will reach, one thing you'll notice with the forward facing plenum's is that there will be no mounting points to support the loom. As for Throttle cable you can buy a R31 cable and shorten it to suit, or an S13 one (I should hav an S13 one soon to trial) It should be very straight forward. Nothing really needs to be modified except for the power stering mount.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
