i thought i saw in his nick/sig 35 at some point.... anyway wouldnt the 30 be a bit on the small side, whats it like to drive cubes? must spool quick
It feels perfect and doesn't ease up until the 7000rpm rev cut.
Its all in a shade over 3000rpm and making a good 7-8psi by ~2400rpm. Extremely responsive. Perfect roll-on acceleration turbo.
I found the GT35 .82 to lack the roll on response in second gear; it felt as if you would always hang level then click third and hammer away; with the gt30 its instant go.
The GT35 doesn't really make its peak boost much later in the rpm but the transient response in comparison is very very noticeable especially in the lower gears.
To drive it feels less laggy and with more torque everywhere than an rb25det with its std turbo.
And the interesting part is for under 300rwkw with the stock exhaust manifold they both make the same sort of power for the same boost. Which is why I don't recommend the GT35 unless your going a nice exhaust manifold and cams to really make use of the potential.
You really need to drive the two setups both on std exhaust manifolds with std bits everywhere to see where I'm coming from.
Was speaking to Tony Rigoli tonight at WSID and he said they make their own sump adaptors but use 10mm sump bolt holes (same as RB26) not the factory size. He said with the extra weight of the sump/diff the standard RB30 holes aren't adequate.
Thoughts?
10mm bolts on what side of the adapter
plate to block or sump to plate?
theres 17 M6 & 6 M8 bolts holding the plate to the block. then theres 8 M6, 7 M8 & 13 M10 bolts holding the sump to the plate. whice imo is more than adequate
Thoughts?
I used a RIPS plate before Pro Engines started making them, as far as I remember they use the standard holes and have been doing so for years. When I see an RB30 with the bottom torn off I'll believe they need bigger fasteners.
Cheers
I was only passing on info from a highly respected engine builder....
I took the sump of my rb30 this morning, was actually suprised how small the bolts were but then their were plenty of bolts.
Can anyone give me a fairly close estimate on the weight of and RB30DET for freight purposes Complete motor with clutch and GT3540
any recommendations of freight companies more than welcome too!
need to know asap
does anyone know if a RB30DET with low compression RB30ET ACL pistons with a 3 layer cometic head gasket be a interference engine ? or non intererance ?
Would the valves smash the pistons if the timing belt let go?
anyone know?
after getting my RB30E and my RB25DE, and taking the head off the RB30E....What is recommended to be done if im wanting to replace
i.e. measuring/checking etc etc
a)main bearings
b)welsch plugs
c)big end bearings
d)piston rings
anything else anyone recommend to replace bar rods and pistons...
Cheers David
a)main bearings
b)welsch plugs
c)big end bearings
d)piston rings
Cheers David
All the seals ie. sump, rear main, head gasket, oil pump etc...
Make sure u clear the oil feed gallery for the turbo in the block as every na Rb30 I've seen has been blocked with sludge.
Edited by Alf
anyone know?
dont mean to sound rube but what difference does it make? your going to all that effort just buy a decent timing belt and its not an issue
I think the whole thing is, he might want to build a non-interference motor incase the timing belt lets go...
With all the engine failures recorded below I've only seen a couple when the belt let go. Just heard of one this morning but no detail yet. Of the others I know it was either a poor quality bolt in the idler/adjuster and a cam cap galled and the belt jumped a bit (GTR cams into RB20) so I've yet to actually see where the belt has failed instantly and catastrophically. There is usually noise and time to inspect the problem.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
