mine is in the lower 8:1's as well, probly 8.1:1 with the 25 head, i am starting to think its a clearance engine.
my motor is a clearance motor and has a static comp ratio of about 8.3:1
As R33-Racer said u would have to have really low comp to make it "free running"
You would need serious bowl pistons or a lower top dead centre.
To give you an idea, a stock RB30ET is in the 7s and is still an interference motor.
To test it: remove your timing belt and crank the motor over by hand if it hits a valve you know the answer. keep trying this with turning the cams a few degrees and cranking it by hand, ull get the idea.
Out of all the interference motors with broken belts that have come in through work only 1% have escaped the carnage. There is a very small chance that when the timing belt snaps that the cam/s will be in the right position so all the valves will be shut/ clear the pistons.
Edited by Alf
Alrighty guys,
Just went through the RB30DET faq again.
And I need to know HOW to lower the motor the 12 and 15 mm each side as required when running the stock 25 inlet mani.
Is it a matter of pulling the mounts out, and shaving 15mm off the bottom of each, or what?
took my car out for its first track day on the weekend and after my first session i found quite a bit of oil in the engine bay from my catch can. i have a stock built rb30 with rb25de head (non vvt) with rb20 oil pump and no restrictors. My catch can had a filter on top and 4 1/4" holes so i thought it was building pressure causing the oil to shoot out so i added 4 more holes and made them all bigger which helped but i was still getting probably close to 200ml of oil in the catch can after every 15 min session. Is there any way of fixing this without chucking the restrictors in the block? also incase it makes a difference the catch can is running off the two outlets on the cam covers.
Cheers!
picking up an rb30 this weekend and 25 head. just reading through the pdf file for the conversion it mentions that i need to make sure the block has provision for the oil/water return and that both lower tensioner locations are machined flat. this engine is coming out of an R31 GXE i believe. any know if this engine will have the above? don't wanna buy something i can't use.
Hey all,
Just chucking this out there could it be possible using the rb20det head getting it ported and putting bigger valves in it just reading the pdf and could it be possible putting in the 25 valves and make it work?
Because i have a rb20det head out of a wreck and a rb30e out of another one.
Just chucking it out there to see if it possible?
Regards
plazmaman plenum still hits the bonnet.
That sucks, GReddy FTW!
The factory plenum shouldn't hit the std 33 bonnet only hits the strut brace. Since i use my car for track/motorkahna days i wanted to keep the strut brace and went for a GReddy plenum.
What are people paying to get their bottom ends built up?
I was quoted for the following,
$220 to balance rods and crank, extra $55 for flexplate
$375 to change from 11mm head studs to 1/2"
$75.90 to crack test the crank and check grind
$82.50 to linish the crank if needed
$400 for tunnel bore and check main bearings
$190 for a rebore
Anything else?
So, are people actually going to answer the question, not give bullshit responses?
How exactly can you fit the RB25/30 into the R33 GTS-t WITH a strut brace fitted, and NO, I'm not putting on a new plenum.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
