R33 Rb30 Conversion
JNR24
So, are people actually going to answer the question, not give bullshit responses?
How exactly can you fit the RB25/30 into the R33 GTS-t WITH a strut brace fitted, and NO, I'm not putting on a new plenum.
Well if u actually were half smart, or even quarter smart, or had any brain at all, ud realise by now that all the info u need is in this thread, or in the pdf.
but because im not a c**t, ur only other option is to lower the engine by modifying the mounts
What Shane said. You will have to fab up lower mounts.
My setup still just touches at the front. So I'll be using the soft mallet to create clearance when some new engine covers go in. The primary reason I went 26/30 was to have the lower plenum as well as 6 throttle for the racetrack.
Also my machining including a head skim cost $1400 including full balance, fitting slugs, crank deplug and clean and full check then tapped and grub screwed. I used forged rods so no prep of those. It came cleaned ready to give a final wipe and assemble.
Hey man i went same setup as you, rb30/26, but my block cost me like $2300 had 2 re-line bore and all what u metioned, using Mahle forgies, spool rods, 7ltr sump, tomei oil pump h/v.
Any pointers about this setup, just finished block work...
its cost me 482 dollars to get my block preped still ahvent got it balanced as yet the preping of the block includes, acid diped/cleaned, crank machined, re-bored and honed and the edition of some new welsh plugs sending my stuff away now to get balanced and sending my head away for a rebuild cant wait till i can finally start it up :D
I think all this talk about a 1/2 in conversion is a bit of a concern. Firstly is is to M12, not 1/2 in. Secondly, you have to have a switched on engineer do the job on a mill, as its easy to stuff up. A lot of builders dont worry, as the ARP RB25 head studs are able to withstand a lot of cylinder pressure. I upgraded mine to rb26 arp head studs(M12 x 1.75), and am now regretting it. In hindsight, i think its really only necessary once you are looking at getting close to 1000hp
1/2 is just a general term, not sure you can buy imperial studs anymore anyway.
i work with a mill almost every day. i don't see why it's a big job? infact id go as far to say it's an easy job. although i am interested to why you regret doing it?
If you go through, and search for it, you'll find that it doesn't actually state HOW to lower it.
Everyone claims to "lower" the motor 15mm on the drivers side, 12mm on the passenger.
But, they don't say how or WHERE these measurements are from.
Is that nock 15mm off the bottom of the mount?
Is it make the engine physically sit 15mm lower (Which removing 15mm square off the bottom of the mount won't do)
How exactly is it meant to be done?
At the moment, after measuring a few things, I'm just going to remove the strut brace.
There are certainly more imperial stuff made than metric, I had a machine shop do mine with a mill, and the results are bloody ordinary. Unfortunately the size ifference between the two threads isnt a great deal, which can easily result in the thread not cutting cleanly. I just think for the ordinary person, the added expense, and the risk of damaged threads make it unnecessary when rb25 ARP studs do the job fine.
What would I have to change on the series 2 head for my rb20ecu to work?
Coil packs, resistor pack for injectors CAS?
Also what plenums are people using to get it to fit under an r32 bonnet?
There would also be things like water temp sensors etc which would need to be swapped for the RB20 items.
I'm using the standard intake manifold for now, am building a custom out of a GTR plenum. If you are using a 25DET head then you have the option of Greddy/copy plenums, I don't have that luxury :D
Bonnet currently rubs slightly on the very forward corner of the standard intake plenum and barely on the timing belt cover. No modified engine mounts or anything like that.
do these types of things interchange?
I am going to try and run R32 RB25DE head with my R33 Power FC im guessing I need to change these sensors too? the coil packs will be fine wont they?
so far I have worked out i will also need to change some ecu pins around as the R32 had a different firing order
Edited by dano4127
    • I want someone to make side skirt extensions. But by 'extensions' I mean running from one side of the car to the other, forming a flat undertray, maybe one that runs to the front and rear of the car too
    • Meh, maybe the JSAI ones are FG not CF. But, given that I'm not convinced any of these look any good, it hardly matters.
    • Got them in the other day. I can confirm the r33/r34 nozzles (B8K30-AA000) are the exact same. Hope this helps anyone else that comes looking for it
    • Yeah, I should state I have no overheating issues except when it's sitting idle, with AC on (and only then) and only on VERY VERY hot days. And it stops if I turn the AC off. But I put a lot of effort into making this thing run like a regular car, I want the AC to work when I want it to work. I need no excuses as to why I should make some other thing a daily! And tbf, the thing does heat soak pretty bad, not much I can do with the exhaust running under the driver's seat, you can feel it through your shoes/pants when you step out of the car, too. Point being, aircon inside the cabin is on pretty frequently. I did think about removing heater hoses to simplify the engine bay/back of engine because I cannot imagine a scenario where I ever need a heater. Except for defogging, but doesn't AC do that, not the heater? So in this very limited situation, raising the rear could work, purely to let hot air out. I've ran the car at the track on a 35C day with the aircon on, and it doesn't overheat in that scenario so that's why I thought it was due to heat soak/heat buildup and not just general overheating under load. I had previously tried shrouding the radiator, changing my balancer to a non-underdriven one to spin the water pump more at idle too, and installing two more thermo fans on the other side of the radiator/AC condenser. (So I have 4 now, 2 pushing, 2 pulling from the rad) neither really helped in this very limited scenario. I don't know if the vents will, but visually seeing the heat steaming out of them did give me hope, not to mention the temperature of the vents was MUCH hotter than other areas of the bonnet. Enough that one of the paint guys was unsure as to whether paint would stick to it long term. I'm sure that will be fine also.
    • JustJap sell CF underskirts like that.
