hey al yeah i bought a new rb25det stock balancer tho i didnt see the point going for an aftermarket version cause i wont be revving it past 7 thou revs anyhow, so will the N1 oil pump fit without modification and do u guys suggest going for an N1 water pump aswell?
It will fit but if you're removing the crank fit a crank collar for peace of mind.
Personally I wouldnt bother with the N1 water pump especially if its a street driven car.
Agreed..
N1 oil pump - good
N1 water pump - don't bother for a street car
can anybody tell me if there is a thead on here that explains how to run the vct/vvt
in an 30/26,and wat else to do to the block so i can boltit together.. and wat page? cant seem to find it and i realy need to get my head and block to the machinests
nz forums suck
cheers :)
I remembered seeing something about how to run the VCT/VVT setup with the RB26 head.
When I first saw your post, I could not find it becuase I did not search for NVCS.
http://forums.hybridz.org/showthread.php?t...;highlight=nvcs
Just wondering if anyone has run a Garrett GT3082R with 1.06 A/R non an RB30DET with an ext wastegate? As far as I can tell these should be somewhere in between a 3076 and a GT35R meaning a good trade off between faster spool-up and less boost dropping off in the high end.
http://www.gcg.com.au/Catalogue_Menus/Garr...ttbb_gt3040.htm
Rotorua Import Pro Shop (RIPS) - Crate motor,
RIPS Plenum,
Boost Worx Stainless Highmount,
Just Jap GTR Style 100mm Cooler
XR6 Turbo - GT3540 IW with the 1.06 rear
POWER FC
HKS Cam Gears
Tial 50mm BOV
Stock injectors for run in then changing to 800cc Sards
Bosch 044 and ARE Surge setup
It has come down to piston choice time. I am currently looking at the arias 9.2:1 and 9.5:1 CR pistons and i am trying to decide which set of pistons to go for. Aiming for around 350-370RWKW (mainly street use occasional track use) using a GT35R turbo. Which compression ratio would best suit my application?
After ppl's thoughts on running a 4 inch dump pipe (using a 4-3.5 reducer at the turbo) reduced to 3.5" later for a GT3582R on a 25/30, is it worth the effort?
Looks like a weapon mate, id be interested to see how your boost responce goes as ive heard some very mixed stories re plumbing it off the housing, some are great, others very average.
Engine looks like a weapon though!
Go the CP 9.0:1, the Arias might be a tad high for the power you are aiming for on pump fuel.
I second that.
I'm using the arias 9.2 comp pistons, after cc'ing the head, the bowls were smaller than standard (the head had been faced more than once before it was in my hands).
With a std thickness head gasket comp would be close to 9.4 so I've got to stuff around finding a thicker head gasket to get it down to 9.0ish.
I only intend using 1 bar on pump fuel and winding it up on race fuel.
While on the topic, what brand is the best bang for $ race fuel?
well my head is away getting rebuilt rang the guy up and he said that there isnt much wrong with the head so that all good and my stuff is away getting balanced, engine is about 40 percent complete just waiting to get my stuff back then we can build it up so far just spent over 7 grand with about 9 or 10 grand to go the only thing i wont be touching is the head besides the rebuild cant wait to get it going it will be exciting :wave:
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
