I would also like to thank two people on these forums. At the start of the build, both took the time to answer all my PM's and help me decide on the right combination that would best achieve my goals.
Both were 100% on the money!!
THANKS CUBES AND R33_RACER !! All your help and advise were greatly appreciated :)
Al you gotta find some better workshops
they are absolutely shocking turn around times
Some things are out of your control.
For example: The sump
- Ordered a race baffled 7ltr sump through H.E.
- After 5 weeks sump hadn't been started. Around the same time i ordered my manifold with ETM. After speaking with Leigh i cancelled my H.E. order and ordered my sump with ETM.
- 6 weeks later sump arrives (was promised a 2 week turn around). Sump filled with metal filling (from grinding), rusty mesh was spayed with a $2 spay can which would have contaminated the oil, sworf(sp?) in various places, etc. As the mesh was welded in it would have been impossible to clean the sump properly.
- 1 week to determine whether Leigh was willing to do the job properly and split the sump to clean it out. He wasn't interested and refunded the money upon the return of the sump.
- Another 5 week wait after reordering the sump through H.E.
NOTE: ETM ext manifolds are awesome and a work of art. I am 100% happy with his manifold.
Now onto more depressing news :)
After less than 25km of driving the car i noticed a small puddle of engine oil. Was upset but thought "shit happens, something didn't seal properly or wasn't fastened properly". Wasn't leaking much, but opted not to drive it much till my mechanic checked it out, as it was coming from the turbo side.
After the long weekend (Melbourne-Labor day) i went past my mechanic's w/shop to check it out. After an hour under the car things went from bad to worst; not worse but WORST!
Even though the machinist was paid to crack test, x-ray and sonic test the block, he somehow missed a crack/pin-hole on the side of the block; or he just pocketed the money and didn't test it at all, as i find it hard to believe that any experienced person could miss an existing hole in a block :(
Any way even though i am obviously pissed, there is nothing much i can do. A new block has to be tested and machined (by a different w/shop) and all components transfered over. The bill WILL be paid by the machinist, as it was his fault that the crack wasn't picked up.
Due to taking the car home, to a detailer, mechanic, Melbourne F1GP, etc. The engine would have traveled about 200km.
I would like to know whether certain parts are not transferable. ie: bearings, rod bolts, piston rings, etc.
I have been assured that due to the low km's traveled that all parts will be safe to transfer, but i want an independent opinion. Not to be rude, but I really only want to hear from people in the trade, that really know if transferring all items to the new block will be ok and if any items need to be replaced or machined, etc.
Your help is greatly appreciated!
i know how you feel mate
i got burnt by my machine shop recently as well
charged me over 3k and there was still shit everywhere in the block and head
the previous place i used returned everything like brand new, i really dunno why i changed shops :(
Al, Im glad to hear that everything turned out the way you wanted. Except the block, that really kills the joy of doing it all. It really sucks when something like that is missed, your lucky that it hasnt caused any major dramas that could have made the whole situation worse.
Hopefully after everything is transferred to the new block things will work out good and well, and for a long time too :laugh: Then you can fully enjoy the effort and time that has gone into the whole project.
Al - for the small price I would definetly replace the rings - just for piece of mind.
Make sure the new block is machined to suit the pistons you have and have the crank mains and big ends are mount and measured - to make sure the bearing clearences are all the same.
Edited by Spoolup
Thanks, that is what i was thinking of. Any idea how much a set of rings are for a cp piston?
ie: How much would you sell them for, to a guy that has just had all the joy riped out of his build? :laugh:
Dude, if you put it like that :-) They are about $180
But seriously - get that crank checked in the new block just to be safe along with the rods. If all is ok then the bearings should be sweet.
Wont i just transfer the crank from this block into the new block?
yes - but you really need to check that the clearences are all good - your crank didnt come from the new block you are going to use, so just have the bearings all assembled in your new block and the girdle torqued down to spec ( no crank ) - then measure the main tunnel sizes with bearings fitted , then measure your crank mains journals and subtract the difference - this will give you the clearence on your crank to bearing. Then do the same with your rods with bearings fitted and then measure yourbig ends etc.
Make sense ?
Al, seriously mate, talk to Rob at Creatd to get the number for his machinist. I had nothing but joy. Price was great too.
And massive commiserations mate.
Have no intension on spending more money, so unless he is willing to do it for free, i have no need to speak to him :laugh:
Spoke to two engine machinists and also an avionics engineer, that builds and repairs aircraft engines, all have stated that a pinhole in the block is almost impossible to see/find. A crack is different as it is bigger, etc., but a pin-hole would not show up on the x-rays or sonic tests.
Either way, i bought the block through my mechanic, so it is still being replaced, at no expense to me. But i will seriously consider buying the piston rings and passing the other info onto my mechanic, even though i am confident in his abilities.
hows it going guys, my projects comming to a finish soon so i thought id trot around the threads again.
i came across this and was very curious as to wat everyone else thought.
My new setup in My R32 GTS4, Made 382rwkw at only 17.5psi, had some boost issues wen trying to go over 17psi.
Stock RB30 bottom end
GTR head
GTR plenum
Custom exhaust manifold made by myself
GT35/40 turbo
Microtech ECU
i PMed Sky30 but has not gotten back to me in over a week. my question is what his done even possible on a gt3540??? even with race fuel i ddnt think he could get that amount of power out of a 3540, let alone 17.5psi.
anyone care to clarify?
Edited by R34NRG
nowhere near possible without racefuel/nitrous/massive headwork
Lots of lift is the key.
Most definitely possible on pump fuel.
As a comparison with the rb25de head and stock exhaust manifold he previously made 312rwkw on roughly the same boost.
And I believe it has since made 397rwkw on ~20psi but appeared to have hit a brick wall; most likely that .82 rear so at ~380rwkw it was at its sweet spot so to speak.
R33racer pulled similar numbers on pump fuel.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
