I would also like to thank two people on these forums. At the start of the build, both took the time to answer all my PM's and help me decide on the right combination that would best achieve my goals.
Both were 100% on the money!!
THANKS CUBES AND R33_RACER !! All your help and advise were greatly appreciated :)
Al you gotta find some better workshops
they are absolutely shocking turn around times
Some things are out of your control.
For example: The sump
- Ordered a race baffled 7ltr sump through H.E.
- After 5 weeks sump hadn't been started. Around the same time i ordered my manifold with ETM. After speaking with Leigh i cancelled my H.E. order and ordered my sump with ETM.
- 6 weeks later sump arrives (was promised a 2 week turn around). Sump filled with metal filling (from grinding), rusty mesh was spayed with a $2 spay can which would have contaminated the oil, sworf(sp?) in various places, etc. As the mesh was welded in it would have been impossible to clean the sump properly.
- 1 week to determine whether Leigh was willing to do the job properly and split the sump to clean it out. He wasn't interested and refunded the money upon the return of the sump.
- Another 5 week wait after reordering the sump through H.E.
NOTE: ETM ext manifolds are awesome and a work of art. I am 100% happy with his manifold.
Now onto more depressing news :)
After less than 25km of driving the car i noticed a small puddle of engine oil. Was upset but thought "shit happens, something didn't seal properly or wasn't fastened properly". Wasn't leaking much, but opted not to drive it much till my mechanic checked it out, as it was coming from the turbo side.
After the long weekend (Melbourne-Labor day) i went past my mechanic's w/shop to check it out. After an hour under the car things went from bad to worst; not worse but WORST!
Even though the machinist was paid to crack test, x-ray and sonic test the block, he somehow missed a crack/pin-hole on the side of the block; or he just pocketed the money and didn't test it at all, as i find it hard to believe that any experienced person could miss an existing hole in a block :(
Any way even though i am obviously pissed, there is nothing much i can do. A new block has to be tested and machined (by a different w/shop) and all components transfered over. The bill WILL be paid by the machinist, as it was his fault that the crack wasn't picked up.
Due to taking the car home, to a detailer, mechanic, Melbourne F1GP, etc. The engine would have traveled about 200km.
I would like to know whether certain parts are not transferable. ie: bearings, rod bolts, piston rings, etc.
I have been assured that due to the low km's traveled that all parts will be safe to transfer, but i want an independent opinion. Not to be rude, but I really only want to hear from people in the trade, that really know if transferring all items to the new block will be ok and if any items need to be replaced or machined, etc.
Your help is greatly appreciated!
i know how you feel mate
i got burnt by my machine shop recently as well
charged me over 3k and there was still shit everywhere in the block and head
the previous place i used returned everything like brand new, i really dunno why i changed shops :(
Call my engine guy in my sig and tell him Steve with the Datsun 120y asked to help you with info. Don't talk too long tho as i will have to wait longer for mine to be finished then :(
Al, Im glad to hear that everything turned out the way you wanted. Except the block, that really kills the joy of doing it all. It really sucks when something like that is missed, your lucky that it hasnt caused any major dramas that could have made the whole situation worse.
Hopefully after everything is transferred to the new block things will work out good and well, and for a long time too :laugh: Then you can fully enjoy the effort and time that has gone into the whole project.
Al - for the small price I would definetly replace the rings - just for piece of mind.
Make sure the new block is machined to suit the pistons you have and have the crank mains and big ends are mount and measured - to make sure the bearing clearences are all the same.
Edited by Spoolup
Thanks, that is what i was thinking of. Any idea how much a set of rings are for a cp piston?
ie: How much would you sell them for, to a guy that has just had all the joy riped out of his build? :laugh:
Dude, if you put it like that :-) They are about $180
But seriously - get that crank checked in the new block just to be safe along with the rods. If all is ok then the bearings should be sweet.
Wont i just transfer the crank from this block into the new block?
yes - but you really need to check that the clearences are all good - your crank didnt come from the new block you are going to use, so just have the bearings all assembled in your new block and the girdle torqued down to spec ( no crank ) - then measure the main tunnel sizes with bearings fitted , then measure your crank mains journals and subtract the difference - this will give you the clearence on your crank to bearing. Then do the same with your rods with bearings fitted and then measure yourbig ends etc.
Make sense ?
Al, what Spoolup says is right.
When I worked in the industry the machinists always insisted on using the main caps/girdle that came with the engine and the crank if it wasn't stuffed.
It saves alot of time and $.
Al, seriously mate, talk to Rob at Creatd to get the number for his machinist. I had nothing but joy. Price was great too.
And massive commiserations mate.
Have no intension on spending more money, so unless he is willing to do it for free, i have no need to speak to him :laugh:
Spoke to two engine machinists and also an avionics engineer, that builds and repairs aircraft engines, all have stated that a pinhole in the block is almost impossible to see/find. A crack is different as it is bigger, etc., but a pin-hole would not show up on the x-rays or sonic tests.
Either way, i bought the block through my mechanic, so it is still being replaced, at no expense to me. But i will seriously consider buying the piston rings and passing the other info onto my mechanic, even though i am confident in his abilities.
hows it going guys, my projects comming to a finish soon so i thought id trot around the threads again.
i came across this and was very curious as to wat everyone else thought.
My new setup in My R32 GTS4, Made 382rwkw at only 17.5psi, had some boost issues wen trying to go over 17psi.
Stock RB30 bottom end
GTR head
GTR plenum
Custom exhaust manifold made by myself
GT35/40 turbo
Microtech ECU
i PMed Sky30 but has not gotten back to me in over a week. my question is what his done even possible on a gt3540??? even with race fuel i ddnt think he could get that amount of power out of a 3540, let alone 17.5psi.
anyone care to clarify?
Edited by R34NRG
nowhere near possible without racefuel/nitrous/massive headwork
Lots of lift is the key.
Most definitely possible on pump fuel.
As a comparison with the rb25de head and stock exhaust manifold he previously made 312rwkw on roughly the same boost.
And I believe it has since made 397rwkw on ~20psi but appeared to have hit a brick wall; most likely that .82 rear so at ~380rwkw it was at its sweet spot so to speak.
R33racer pulled similar numbers on pump fuel.
    • Quick update team on the build Things done. Installed Diff Brace ( TMR Performance ) Removed Steering Rack and replaced bushings with GK Tech bushings Remove Manifold and replaced Rocker Cover Gaskets and the Spark Seal Tubes Installed 1000CC Bosch Fuel Injectors Installed R35 Spark Plugs ( Pre-gapped to 0.28"  Installed Z1 Coilpacks Removed Fuel Sender unit and modified OEM pump to fit the 350lph Fuel Pump Installed Fuel Sender unit back with a Fuel Return system ( TMR Performance Fuel Return V2 )  Setup Fuel Lines that were AN lines and used P-Clamps to secure them to body ( This is needed to make this road legal in NZ ) Setup Fuel regulator Setup Vacuum lines from Wastegate to boost controller ( 3 port mac valve ) Wired boost solenoid to the EVAP sensor ( Behind manifold of car ) - Polarity of cables doesn't matter Setup BOV and Fuel Regulator lines Installed both aftermarket Aero Fenders ( Sourced from Japan ) Received Impul 280km/h Speedo ( Sourced from Japan ) Installed Carbon shift console Drive down the road untuned without creating boost pressure to test for leaks ( Video attached ) Setup JRP Racing 14in1 Gauge with Boost pressure being monitored Buttoned car back up and Tow to tuning shop in the mighty DE ( Nissan Elgrand E51 ) - VQ35DE Tuning platform is EcuTek and am hoping to 550WHP ( Dyno day is 9th and 10th of October )  Had Shop weld in a new Exhaust piece to connect Downpipe > Motordyne Resonator and to add x2 02 Sensor bungs for an AFR Gauge that will hook into the JRP Multi-Gauge    20240927_181518.mp4 20240927_181618.mp4 20240928_192844.mp4
    • It's in the bloody domain name twice! Yes...the GTR boxen have, for some reason, been cheaper than the RWD boxen for a long time. 10 years ago the GTST box was available here for <AU$3k. 5 years ago the GTT box was available for ~AU$3300. Both retail through 3rd party. Now the GTT box is >4k locally and only available for less if you're willing to jump through some hoops. Apparently they can be ordered from Nissan dealers for $3-3.5k at trade pricing. A friend of mine has a new GTT box sitting on his showroom floor that I keep wanting to hit him up for but I'd somewhat rather he sold it to someone else at his asking price than to me for a mate's rates discount.
    • lol I didn’t even notice the bird
    • I like the 'Beatles album cover, but with bird' element of this photo as well, haha
    • Hi Gents, Someone I know (experienced engine builder) built an engine. It had some chinesium rods that came with ARP 2000 bolts. One failed on the dyno, destroyed the whole thing. The only possibilities are: Installation error. Possible, but we should discount it almost 100% because he knows what he's doing. He doesn't discount it that much, because he's being hard on himself. QC/QA problems with ARP products. I'd like to discount this, but I have heard a number of stories about similar failures, and stories of some builders buying 2 sets of everything, x-raying everything, and picking only those bolts that they are completely happy with. This behaviour coming from anecdotal stories of ~1% failure rates. 1% of all rod bolts failing would be about 1000x higher than I would expect to be anywhere near tolerable. If I were ARP I certainly wouldn't even be selling the product if they were dying at that rate (for non-installation error reasons). So, I would prefer to discount that possibility too. Fakes. Specifically, fakes being sold bundled with cheap rods sets from CCP factory B in Shenzen, or wherever the stuff is being made this week. So the question here is, does anyone else have some horror stories that would point to fakes being circulated in this manner?
