I am currently using one on my rb25/30 setup.
I had to do 2 modifications to make it all fit nicely.
1/ Move the Power Steering pulley about 5mm forward on the shaft. My mechanic also welded the shaft to the pulley to add strength. The pulley had to be moved forward as the GTR belts are thicker (4 ribbed) than the GTST belts (3 ribbed). Thus the ATI pulley has the p/steering belt a little more forward than the gtst. I am still using the GTST belts; haven't had an issue.
2/ Lathed up a spacer/hub for the engine fan. A 10mm spacer was made for the fan to move it further away from the ATI pulley, as without the spacer there was only a 0.5-1.0mm clearance between the fan blades and the front of the pulley.
10mm was a fraction too big as it clipped the shroud when loaded at 5000rpm, i just simply trimmed the shroud to clear the fan, but i think a 5mm spacer would have no issues.
Note: Mod 2/ would not be necessary if you are going to use Thermo Fans to replace the clutch fan. My mechanic has a thing that he doesn't like using thermo fans on Skylines as he has found the cars to overheat in the past. His build his rules; that way he's the only one i could blame if something goes wrong :blink:
thanks alot for the help!!! appreciate it! but yeah I am in canada so taking weather into things i think i will be fine using electric fans
I love mechanics Al. They are so afraid of trying anything new. 7 lap sessions of Lakeside in the GTR, which only has 320rwkw with the twin ducted setup never saw over 92 deg on a nice 29deg day. With a 50mm core that would drop right to the 85deg sweet spot.
Great thread, I've read through 160 pages and learnt a few things and thought I'd post here and asks some questions, as I don't really want to read the next 160 pages just to find out lol.
Basically the comment was made that if you have a gts4 or gtr it is best to either get a gtr head to do the conversion? or get a 26 instead?(in the case of a gts4? I currently have a 25 in the car) As mounting the rb30 in the bay without a greddy or plazmaman (sp) IM was a PITA? Is this still the case?
Chris, I think it was more along the lines of making life easier for 32GTSts/GTS4s so the bonnet doesn't need to be reworked. The inlet and manifold on a 20 and 25 engine sit above the head, so they then contact the bonnet, or even the strut brace. In these cases it is better to go with a side inlet system instead of an overhead inlet.
My preference was for the GTR manifold and throttles in the race car so the 26 head was the perfect solution.
BTW I've costed the 26/30 out several times and not including the turbos and Y pipe I keep getting the figure of $6500 cost doing the labour myself and including outsourcing the machining (naturally as no-one has all the machining tools in there backyard). That includes the Spool rod/CP piston package from Spoolup (Brad). Add extra for a harmonic balancer, turbos, special exhaust manifolds and dumps, Y pipe (and yes, the GTS25t exhaust will bolt straight up to twins; very convenient) and any other cool stuff you really desperately need. The trick is to get the head and inlet system at a decent price. If you can get a complete head with all bits bolted to it then half the grief is gone.
Then again there is absolutely nothing wrong (IMO) with going 25/30 for a sensational budget build.
Am................ who said he never tried :D
............... he doesn't like using thermo fans on Skylines as he has found the cars to overheat in the past.
Now i do realize that is a very debatable topic, but i chose to go with what he felt was best.
S'alright Al, just winding you up mate. I know how protective you are of your favourite mechanics :D
Nice looking engine Steve. Which balancer is that on the front?
It's an Atomic brand. Exceeds Andra requirements which is all i am concerned about. It will be in the car by the end of the week. Damn full time work :P
This has been covered - you can not just bolt the RB25DET R33 VCT head straight on without modifying the water gallery and blocking off the oil feed hole - going with no VCT
What needs modifying on the water gallery? And you didn't mention anything about an oil feed to VCT to lube up the cam. I've heard/read too many sides on this. What are you risking by not running oil to it? Why do the 25de non-vct heads not require an oil feed for it? Where do they get their oil?
Cheers, Jack
Cheers, Jack
http://www.skylinesaustralia.com/forums/se....html&f=184
Yeah heaps helpful. I've been looking into and reading about this for months, if I knew the answers I wouldn't have bothered asking...
Where exactly in the rb30 guide does it state how/why to modify the water gallery, or why the rb25de head doesnt require an oil feed? Or if it does, how it is done?
I apologise if I have missed something obvious, but I am only aware of the mods required to the VCT on the det head.
:P
Page 1.
The R32 RB25DE head bolts straight up to the RB30E bottom end. All water/oil galleys line up.
N/A valve springs have less tension which may cause issues when running big boost.
Cams and springs are interchangeable with RB20DET items. Valve springs identical, cams are slightly different.
The R33 RB25DE/T has variable cam timing (VCT/NVCS); this requires welding of the heads VCT oil feed.
The head still requires oil to its VCT, you will have to tap in to the oil galley and run an oil feed to it. The most common
used feed is T’ing into the oil pressure sender feed.
Compare the pictures below to gain an understanding of how the head needs to be modified.
Nothing states exactly thats you to yourself to look at the headgasket look at your head + the pics in the guide and think ok.. this needs to be done.
I disappeared for a few months, come back and people are still asking the same questions about the same things....dang i was hoping there would be new topics and problems people have come across by now :P
same ole same ole.... someone needs to do something really different and interesting!
lol lol lol
I have complete understanding of the oil side of things. Someone refered to modifying the 'water' gallery. Or is blocking the vct oil feed and running an external line what they refered to as 'modding the water gallery'
If it is then I've obviously had a mis-understanding of what was said, if not then I'm still very lost with the 'water' gallery thing
Thanks, Jack
I disappeared for a few months, come back and people are still asking the same questions about the same things....dang i was hoping there would be new topics and problems people have come across by now :rolleyes:
so u missed my girdles and brads stroker cranks then...:)
i remember reading somewhere about what bluegts is asking - someone welded steel onto the Block arounda water gallery then had it decked - apparantly there was only a small amount of overlap between the water gallery and the edge of the block..
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
