R33 Rb30 Conversion
JNR24
I would presume the stock rb30 pump should be ok with stock restrictors.
I remember some one on ct.com had issues with pressure bleeding off on idle with the rb30e pump. Unsure if it was a stuffed bottom end, pump etc.
Wouldn't use an idler. Use 2 x tensioners.
someone on here also had issues when they reused the stock RB30 oil pump, had to replace it with a twin cam one.
alright sweet..... hmmmm
should be okay to just use the stock rb30 tensioner and the tensioner off my rb20 aswell....
sweeet as chhheeeers for all the help
why not replace the old tensioners? you should be able to pickup two brand new ones for sub $100.
yeah i was just thinking that.. i remember hearing tensionsers are f**k all any ways..
when i order thermostat head gasket water pump and now two tensioners :banana:
was their somthing i red in this thread about series one rb25 oil pump works fine without the collar.. as its the same length on the series one rb25 crank???
any confirmation?
does anyone know max recomened boost and max rwkw on stock bottom end?? (new rings, bearings and a hone)
like with stock rods and pistons..??
heard of guys going over 300rwkw on stock na pistons and rods.....
:worship:
got qoute for $1800 for acl race series bearings, new rings, crank collar supplied and fitted and all new welch plugs and seals
is that the average kinda price range for that work to be done
cheers
tom
has anyone got the torque specs for stock rb25 head bolts? can these bolts be reused? how much is a new set if they cant?
this is a super budget build for abit of fun, i dont care if it doesnt last ages, i dont wanna spend money if i dont have to, limiting the power to 400hp anyway so shouldnt be too much stress. :whistling:
this is a super budget build for abit of fun, i dont care if it doesnt last ages, i dont wanna spend money if i dont have to, limiting the power to 400hp anyway so shouldnt be too much stress. :huh:
you can re-use them, but i dont know the torque specs off the top of my head, someone else will probably chime in :D
although ARP head studs arent all that expensive
Edited by R34GTFOUR
thanks guys great help, i got hold of some second hand rb25 bolts yesterday for $20 so ill see if they last, if not i dont care ill just get some new ones.
the motors coming together nicely now, its a basic setup using a stock rb30 bottom end that i bought from a mate for $50, pity it was a s1 block :P
The block has been recond as it has acl main bearings and NDC rod bearings, these are stamped with what i beleive to be the date they were made and it says 1998 so its still fairly old, hopefully they last a while. I had to tap the water feed for turbo, and drill out the oil feed line as well. I then got the machine shop to deck the block and wash it and tap the oil drain for turbo as well all for $100. I bought the front and rear crank seals for $16 for both, and a dayco timing belt for $31. I decided i didnt wanna tap the head bolt holes for rb26 bolts as the plan is to chuck in stock bottom ends if this blows up and i dont want to have to retap bolt holes everytime i buy a bottom end. So the plan is to use some stock rb25 headbolts as mentioned. I bought 2 mig welder tips for $1 each and used a 1.5mm one in one feed and the other one i welded the hole up and put in the other feed, worked perfect.
I bought a low comp rb26 complete a while ago, i removed the head for this project and had the head decked and valve seats recut as the motor had been detonating and the seats were shocking condition. I chucked in some new valve stem seals and the valve guides looked brand new and were within specs.
I am putting this into a 32 gtr running rwd (using the rb30 sump) and machined off front axles, plus either a gtr box with removed tf case or a rb25 box. I have bought a t3 flanged high mount manifold for $200 from a mate, its a steampipe design and looks great, definately got a bargain, it was used on a rb26 with gt3540 xr6 turbo internal gate turbo, so i need to add an external gate pipe on it or run an internal gate turbo.
I think a gt3076r is my number one turbo option, i have the injectors, ecu, fuel system all sorted from my current setup and hoping to push around 400rwhp, the gtr is stripped out and should be at 1250kg or just under with the 4wd stuff removed and totally stripped.
post-40430-1219243495_thumb.jpgpost-40430-1219243531_thumb.jpgpost-40430-1219243593_thumb.jpg
Why? :S
Finally got it tuned!!!! Feels really nice to drive
Unfortunately maxed out the Z32 for some unknown reason so couldnt go any further as i only had 2 hours of tuning available on the dyno with DrDrift
Just wondering if anyone can tell me what this works out to be in NM?
Posted up the full setup and other graphs in the dyno thread: http://www.skylinesaustralia.com/forums/in...t&p=4082856
Edited by dano4127
Strange you max'd it out at 255rwkw. Mines pushing ~5volts at 302rwkw.
Boost leak?
Thats what im hoping! Couldn't find an odious one but i will do some detective work next weekend
A mate of mine has a bung and compressor so I will pressurize and see what we can come up with...
Nice work Brad and Dan! hopefully I have some big number to post soon :)
:thumbsup:
Finally fired the new machine into life with a slightly strange situation, Im running N1 pump, 26 head with 2 x 1mm restrictors. The strange part is I have fitted a mechanical autometer oil pressure gauge off the main gallery where the original RB30 oil pressure sender screw into & it gradually goes off the chart to 100psi at idle..... Im running 15/40 shell helix mineral oil, the std oil pressure gauge on the dash reads about 3/4. Not sure if I have an issue with the oil thickness or a bodgy gauge....
Anyone else had this?
I havnt fully warmed it up yet as still fitting the wideband sensor & want to make sure all is good
Cheers, Matt
Why? :S
because i can :( nah its because i want a cheap setup for drifting and then i have the 560hp at wheels rb26 engine for proper track work and a ppg dogbox, i will swap between the 2 setups in the gtr :P im trying to save weight with the 30 setup as its gonna be limited to 400hp and it will pretty much be like a gtst setup drivetrain wise with this engine.
because i can :) nah its because i want a cheap setup for drifting and then i have the 560hp at wheels rb26 engine for proper track work and a ppg dogbox, i will swap between the 2 setups in the gtr :( im trying to save weight with the 30 setup as its gonna be limited to 400hp and it will pretty much be like a gtst setup drivetrain wise with this engine.
thats cool but fark your a gluten for punishment!
    • The offset of the wheel is usually stamped on the inside of the rim. So just pull the wheel off and see if it's marked as such.
    • It's very possible my measurements are wrong as I did measure with the wheel and tire still on the car. It's possible I didn't judge inner gap correctly and ended up adding width. I'm eager to buy new wheels, but I think I might be putting the cart before the horse. The best thing to do this right. I can take off the wheels off, I might even just have the tires taken off and do some proper measurements. It won't cost me much, if anything, and will save me a whole bunch of headache in the long run.
    • You are right, there are 2 ways to approach it, you can go for wheels known to fit well on the car, or measure from what you have. If you jack up the car and check the distance from the inner side of the tyre to the first obstruction (generally the control arm, or a shock) and then do the same from the outside of the tyre to the guard, that tells you how much wider you can go or what offset you can use. I'd note that 9.5 is huge on the front of a 33 gtst, if they are not scrubbing anywhere including fuil lock then don't change anything about the front width and offset.
    • have done smoke test and there is no leak. I found the problem and got it fixed. It was the second hose under the Plenum who had also a restrictor in place. I also changed all vacuum hoses so i had this restrictor no more. Just fished the old hoses out of my trashcan to check the diameter and realized the green marked hose and checked it with my camera. Put this restrictor in my new silicone hose and got 1.0 with 1.1 - 1.2 overboost back. cheers
    • Ok, maybe I'm approaching this the wrong way. I'm trying to buy new wheels, and I was having trouble finding the exact offset needed for my r33 GTST Spec 2. I figured trying to reverse engineer the wheels already on the car was a good method, but maybe I'm over complicating tings. I tried using this thread, but I was unsure how to translate what others had and their set-ups versus my own. I know the wheels I have right now are 18 x 9.5, front and rear, so it's just the offset that's really throwing me for a loop. I'm not sure if stock GTST offset would be the correct answer because again, I have GTR calipers and 370Z rotors. I've replaced the rotors recently and taken the wheels on and off enough times to know I don't have any spacers.
