VCT question. Does anyone know where the hydraulic valve(ram) is on a R33det that controls the flow of oil to the camshaft phaser.
Need to know where to feed the oil to, as I believe I will be welding the vct oil gallery on the head
thanks
I must be a retard because I cant find what I am looking for even though I am sure its somwhere...
If I am going to put forged RB25 pistons (20 thou oversize) and eagle rods out of the same motor into an RB30 block, will comp ratio still be reasonable (8:1 or 8.5:1)? This combination will be fine I assume as in the .pdf its stated that bore is the same between 25/26/30. The rods are my concern but I am pretty sure they are interchangeable.
Sorry guys >_<
This is the wrong way to build the engine. The RB25 pistons have a lower compression height than the RB30 pistons, so they will be down the block about 0.5mm. The pistons have an 14cc dome on the top of them too. Assuming you deck the block to 0 thou you would have a cr of around 9.8:1, possibly higher if you have the head skimmed to make it dead flat.
Not machining the block to 0 thou deck would give you a little more chamber volume but this would also make the engine more prone to detonation as the sqush pads in the head are way too far away from the squish area on the pistons to make the combustion chamber efficent.
The ideal engine has a 0 deck height and a 0.040" (1mm) head gasket. Then set your desired CR using dished pistons after having your head cc'd. Using RB30 pistons gets you close to 8:1 depending on your head cc.
You should read the PDF file, it covers the options for piston choice.
how have people fixed their throttle cable issues. i have a q45 TB on a greddy plenum and using the stock throttle cable bracket i can hook up the cable but there is too much slack in the cable itself.
i heard you can get replacement disks that the throttle cable hooks onto on the throttle body so you can rotate it further to take up the slack. does anyone know where to get these? or am i better off getting the cable modified?
Edited by TiTAN
  • 3 weeks later...
car is running and has an initial tune on it.
Arias 9.2:1 comp pistons
Stock RB25 cams & springs with slightly cleaned up ports (completely stripped and rebuilt head)
VCT enabled
Greddy intake with Q45 TB
GT3582R 0.82 on an ETM manifold with 4" dump pipe, 50mm external wastegate
The engine is so much nicer off boost than the RB25 ever was and once its on boost the thing flys (making ~5psi by 2300 in 4th)
290kw @ the rear wheels 18 psi and bugger all ignition timing, 11:1 AFR up top and not making use of the WMI as something is leaking into the intake and fouling up the plugs/ deploying a smoke screen (to put it lightly) on the over run (PCV leaking oil, valve guide/s leaking oil, brake master cyl faulty and leaking fluid) any or all of the above. so we cant lean on it till thats fixed, should have an easy extra 70 or so kw left in it.
  • 4 weeks later...
does anyone know the nissan part number for the bolts that hold the crank girdle to the block?
i have asked Nissan but the say they can't find it in thier system.
what bolts do other people use?
thanks
I have the same TB with a CPC plenum where the rb20 and rb25 accel cables wouldnt reach. I found an Aussie R31 Rb30 cable that requires no mods to fit.
when i bougt mine 2 months ago
ATI917752 $1035 + GST/nil stock. (RB26, direct bolt on,-R32 for cars making 600-1000HP)
ATI917753 $1035 + GST/in stock. (RB26, direct bolt on,-R33-R34 for cars making 600-1000HP
form rocket industry's
Make sure the one your getting has serpentine belt drive unless it's a race car
But u can get them at perfomancewholesale.com.au for around 1000
cheers
can somebody tell me the difference between those 2 items.
just looking on the ATI website now, and they have an "r32 model" and the newer..
shouldnt be the same?
Not sure if this has been mentioned...
I recently got my RB25/30 running (last Tuesday). I did the mod for the VCT, however, all I did was grub screw the hole in the head, with no other modification. My VCT works perfect. No oil control/lack of oil issues or anything (this was mod was done on the advice of my engine builder).
Discuss.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
