VCT question. Does anyone know where the hydraulic valve(ram) is on a R33det that controls the flow of oil to the camshaft phaser.
Need to know where to feed the oil to, as I believe I will be welding the vct oil gallery on the head
thanks
I must be a retard because I cant find what I am looking for even though I am sure its somwhere...
If I am going to put forged RB25 pistons (20 thou oversize) and eagle rods out of the same motor into an RB30 block, will comp ratio still be reasonable (8:1 or 8.5:1)? This combination will be fine I assume as in the .pdf its stated that bore is the same between 25/26/30. The rods are my concern but I am pretty sure they are interchangeable.
Sorry guys >_<
This is the wrong way to build the engine. The RB25 pistons have a lower compression height than the RB30 pistons, so they will be down the block about 0.5mm. The pistons have an 14cc dome on the top of them too. Assuming you deck the block to 0 thou you would have a cr of around 9.8:1, possibly higher if you have the head skimmed to make it dead flat.
Not machining the block to 0 thou deck would give you a little more chamber volume but this would also make the engine more prone to detonation as the sqush pads in the head are way too far away from the squish area on the pistons to make the combustion chamber efficent.
The ideal engine has a 0 deck height and a 0.040" (1mm) head gasket. Then set your desired CR using dished pistons after having your head cc'd. Using RB30 pistons gets you close to 8:1 depending on your head cc.
You should read the PDF file, it covers the options for piston choice.
how have people fixed their throttle cable issues. i have a q45 TB on a greddy plenum and using the stock throttle cable bracket i can hook up the cable but there is too much slack in the cable itself.
i heard you can get replacement disks that the throttle cable hooks onto on the throttle body so you can rotate it further to take up the slack. does anyone know where to get these? or am i better off getting the cable modified?
Edited by TiTAN
  • 3 weeks later...
car is running and has an initial tune on it.
Arias 9.2:1 comp pistons
Stock RB25 cams & springs with slightly cleaned up ports (completely stripped and rebuilt head)
VCT enabled
Greddy intake with Q45 TB
GT3582R 0.82 on an ETM manifold with 4" dump pipe, 50mm external wastegate
The engine is so much nicer off boost than the RB25 ever was and once its on boost the thing flys (making ~5psi by 2300 in 4th)
290kw @ the rear wheels 18 psi and bugger all ignition timing, 11:1 AFR up top and not making use of the WMI as something is leaking into the intake and fouling up the plugs/ deploying a smoke screen (to put it lightly) on the over run (PCV leaking oil, valve guide/s leaking oil, brake master cyl faulty and leaking fluid) any or all of the above. so we cant lean on it till thats fixed, should have an easy extra 70 or so kw left in it.
  • 4 weeks later...
does anyone know the nissan part number for the bolts that hold the crank girdle to the block?
i have asked Nissan but the say they can't find it in thier system.
what bolts do other people use?
thanks
I have the same TB with a CPC plenum where the rb20 and rb25 accel cables wouldnt reach. I found an Aussie R31 Rb30 cable that requires no mods to fit.
when i bougt mine 2 months ago
ATI917752 $1035 + GST/nil stock. (RB26, direct bolt on,-R32 for cars making 600-1000HP)
ATI917753 $1035 + GST/in stock. (RB26, direct bolt on,-R33-R34 for cars making 600-1000HP
form rocket industry's
Make sure the one your getting has serpentine belt drive unless it's a race car
But u can get them at perfomancewholesale.com.au for around 1000
cheers
can somebody tell me the difference between those 2 items.
just looking on the ATI website now, and they have an "r32 model" and the newer..
shouldnt be the same?
Not sure if this has been mentioned...
I recently got my RB25/30 running (last Tuesday). I did the mod for the VCT, however, all I did was grub screw the hole in the head, with no other modification. My VCT works perfect. No oil control/lack of oil issues or anything (this was mod was done on the advice of my engine builder).
Discuss.
    • Drilled the rubber out on a slow speed and it didn't catch much at all. Probably only half a dozen holes was enough to shred the rubber and it dropped off easily leaving the inner sleeve behind. Will tackle that later
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
