It appears that the Wolf actually has a lot more features than the pfc.
Here's a quick run down on the features of Wolf v4 plug in for the R33/R32.
Map/Maf Use.
Closed Loop.
Air temp - Fuel/Ign/Boost compensation
Engine - Fuel/Ign/Boost compensation
Boost can be set per 500rpm to what ever value you like, it can also be trimmed to according to tps/air temp, engine temp.
Rotational Idle can be setup by Steve from SST.
Map Switching
Its a good ecu.
Check out the couple of threads that compare the PowerFC to the Wolf3D.
cool about time there was another good cheap plugin ecu. The older wolfs were a little shit, but i've heard the v4's are good. Dunno how they go with fuel economy, heard the microtech uses more, and can't remember if i've heard the same about the newer wolf's
i plugged my PFC in.
BANG. New car.
Wheel spinnage.
awesome power increase.
and after the tune ?? well the tune got me 285bhp
I so love the drivability of the PFC and the hand controller graph views are just totally awesome.
Id suggest the PFC to anyone.
Microtech uses more fuel because it doesn't have closed loop.
i.e as GTST VSpec told me that in closed loop mode it runs up to around 18:1 where as the best you can get from a non closed loop car is what ever the base map is which won't be 18:1.. :D
The dipstick assembly is just an iterference fit in the block hole. If you genty twist it you can lossen it and carefully keep turning back and forth until it comes out. Alternatively you could use the correct size drift and tap it out of the block from below.
OK so how do i get the Crank timing pulley off then. NOT the Crank pulley, the one behind them, in front of the oil pump which the timing belt goes around. Does it come off with the oil pump, cos it seems that the pump is free from the block, but the timing pulley is stopping it and i dunno how to get that off.
Your help is appreciated.
same way you got the oil pump off... tap it off with a hammer. You'll need to take the little key out (the little metal bit that stops the gear spinning on the crank shaft). But have some wood between the hammer and the crank gear cos you don't want to damage the teeth.
My timing gear was seized on the crank as well, and i got a local engine builder to remove it for me, they just drilled small holes in the timing gear from the front, extending from the center of the gear out to the edge, and then just used a cold chisel to create a radial split in the gear, and off it came. obviously a new gear was required.
Have any of you bolted the RB26DETT head on the RB30E?
Im about to do that, I was just wondering if anyone knew the difference in compression ratio?
If the RB30E/RB25DE is 8.3:1, what is the RB30E/RB26DETT?
Apart from tapping the holes in the block is there anything alse that needs doing?
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
