  • 1 year later...
Hey everyone, am nearing completion of my RB25/30 build, but I seem to be stuck on setting up the timing.
I have drilled and tapped the block above the water pump for the timing belt tensioner, am using a RB25 idler below the water pump, crank is at TDC, but am unsure on where my cams are supposed to be at. I also have adjustable cam gears to go onto the cams, once the motor in full is set to TDC correctly. To make it easier, the block is a standard A6 VL N/A block, and the head is standard aswell, valves, cams, with the exception of the VVL being blocked off in the head.
If someone could help me out with this it'd be muchly appreciated. Have tried searching in this thread alone and also the whole of SAU, but cant find a definite answer. With 359 pages worth of thread here, I tried looking, but it seems a lot of people like to talk shit in here too which makes it all that much harder..
Install the adjustable cam gears straight off and use the markers as per Ben's comment.  Then pay someone competent to degree your cams.  Hint: this is far easier and less time consuming to do on the bench/engine stand.
  • 1 year later...
Hey team.
Massive thanks for this thread. It's amazeballs.
Just wondering if a factory 25DE ecu could be used to get a 30DET running. Just temporarily so I can check everything for leaks and I'm eating myself noises before it goes for dyno tune.
Not sure what ecu I'm going to use yet will speak to the tuner before to see what brands they are familiar with.
Once again cheers guys
  • 1 year later...
I know....Rb25/30 boredom (not build ) question...but opinions will be cool
Need to know some real Hp/Kw figures for my build...just your guesstimation possibly.
Build
25neo head.+1mm over int/exh..rear head drain
Stainless valves ..performance springs
Tomei cams (poncam)
Ati balancer ...prp collar..n1oil pump..forged gears..prp billet crank sprocket washers...billet backing plate to n1 pump..7L sump.. Stock crank acl bearings...87mm rb30 block..CP flat top pistons...Max peening H beam rods.
Fuel cell...1000hp fuel supply..1400cc injectors.
6boost exh...45mm hypergate.
Haltech elite2000....flex fuel.
Real reason is so i know if my gearbox is going flying...
Build
Tomei cams (poncam)
Expand
No turbo so approx 180kw
Expand
Assume you have a R33? If so, then the torque of the RB30 will most def kill your box(Depends how much power you are actually shooting for).
  • 4 weeks later...
  • 1 year later...
  On 19/10/2021 at 12:15 AM, jaychen said:
Is this still the thread to read with regards to high hp sohc rb30 applications?
Expand
Most stuff on here will relate to DOHC heads.
What info specifically are you chasing?
  • 2 years later...
Just thought I would bump this 20 year old thread because the Skid Factory have just posted up a video summarising a lot of the content, format might be more familiar for newer members
  • Like 2
    • Hi guys my 94 r33 gtst fuel pump has gone out. I have a walbro 525 ready to go in but am unsure if I need to upgrade the fuel tank bulk heads? Ive heard that others have issues with the stock wiring melting... Ive seen alot of people recommend this: https://frenchysperformancegarage.com/products/fpg-nissan-skyline-r33-r34-silvia-s14-s15-billet-fuel-tank-bulkhead-hat-top-an6-with-high-current-connector-apex-2-8-delphi-fpg-100?variant=42873255198898 My current pump that stopped working is aftermarket but I had no relay mod or upgraded connectors. Need some advice please. TIA
    • It’s new. It’s the cd009. I did take the transmission apart to mill down the bellhousing and had both housings come off the gears so wondering is something isn’t in right. I am running redline. I can get it in gear running too but it’s just not easier and it’s almost like 2, 4, 6, and reverse all the back gears aren’t happy going in
    • I’ll remember that as a last choice. It’s brand new
    • Got keys and did a walk around the yard planning the landscaping works with the family that I will be doing Main effort: remove all the woodchip in the gardens that are around (attached) to the outside of the house and replace with 10mm blue metal, having woodchip close to the house is a recipe for inviting white ants, currently there are no white ants within the block and I would like to keep it that way I'll be buying some large raised garden beds to grow veggies and stuff, and the woodchip will be mulched with everything else that gets dug up, pulled out, or cut down during works Next will some minor drainage and landscaping maintenance up one side of the house, where the fuse box, AC, and solar stuff will go, about 12 mtrs long by 2 meters wide, I'll break up the soil, add gypsum and then I'll dig in a French drains about 300mm deep x 300mm wide and fill it with agg pipe and blue metal, then level out the whole area with a 50mm layer of blue metal, the soil, whilst currently pretty compacted, will break up well with the gypsum to aid in drainage, I'll then cover the area with a 50mm layer of more blue metal In saying this, the drainage issue is minor, but that little hidden away area down the side is untidy and weedy, and as all of the main elec stuff is there I want it neat and tidy to appease my OCD Again, the material excavated from the French drains with be added to the garden bed mulch, as will some rose bushes and some other crap looking garden plants, and a old apricot tree that is looking worse for wear The apricot tree is currently in a little roundish garden bed that is in the middle of the back yard with few other crappy looking plants around it, that will all be removed, levelled, re-turfed, and is a perfect spot for a hills hoist There is also a area about 3m x 2m between the rear fence and shed that will get some attention, it looks like some stuff was stored there and the grass is dead, that will also get broken up and mulched, and is a prime spot for a pumpkin patch I've guestimated that I'll need: 3 tonnes of blue metal, 12 meters of agg pipe, 5kg of Gypsum, and a hills hoist, so a few bags of concrete as well to set it in place (the house currently has one of those pull out 4 line jobs, whilst it works, I want a retro old school hills hoist), I am also going to run some chickens, there's a great spot for a coop, so a chicken coop to suit 4 of those lovely egg laying bitches will also be on the job card That should keep me busy for a while, and will finish off the back yard ready for a early spring planting of some veggies and berries  Once the main effort is done I'll start out the front, there's a large rock garden that could use some TLC, but that is only minor works Should be fully moved in within 2 weeks, the landscaping works will start then Fun times, retirement is good
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
