i think most are hoping for a little more driveable (and reliable!) 300-400rwkw out of an rb30det as opposed to 300rwkw rb25det.. well me anyhow :cool: why i sold my r33 - too much effort & dosh over a $20k car to begin with and few things i wanted to change anyhow..erg.. thought it was easier to start again..
as to what times are possible, depends really on the rest of the setup i guess and whether you really want just a nutty drag car or good all rounder. I want the latter.
in reference back to SK i have done a little more research today and i actually think that eagle are starting with a subaru rod of some discription... i couldnt tell you what particular engine it is from but that is the word i have been given by a man that has delt with alot of subaru's and used eagles many times!!!!
Again back to engine outputs and so forth, it is never a good idea to say "oh i have seen or my friend or insert mechanic here has seen rb30's do 350rwkw on stock prepped rods, goin ask a few vl people how many they have seen let go as well.... looking at a stock rod compared to the eagle there is no way i would trust them past 80-90 hp each especially considering they are a stud and nut arrangement!!! Personally my biggest moto ever and i use it applied to everything " IF ITS WORTH DOING IT WORTH DOIN ONCE DONE RIGHT"... However im not saying the stockies wont do the job but for me i like the added insurance.... Cheers, Daniel.
wouldnt 400rwhp be between 550 - 600hp @ flywheel? What i find hard to believe is that a standard rb30e bottom end with cast pistons with a proper tune can do that kind of power.
Anyway 400rwhp would be where I call it a day.... but then again.. i said that about 300rwhp lol this boost virus is very hard to shake
... goin ask a few vl people how many they have seen let go as well....
Thats my concern, you hear all the Nizpro guys producing great figures and doign great times, but are the engines hand grenades, are they durable etc. Ppl have a tendency to keep to themselves when they have a failure :Oops:
As for the Crower rods, do they make H-Beam rods...if im going to the expense of rods i would like H-beam rather then I beam rods...or is there no real difference?
From their website...
4340 Steel Billet Connecting Rods
Crower is the industry leader in high performance connecting rods. Choose from the largest selection of foreign makes available including BMW, Porsche, Ferrari, Nissan, Audi, Volkswagen and more. CNC machined from premium quality 4340 chromoly steel, Crower billet rods are the only choice when running nitrous oxide, high boost or high rpm in your vehicle. Contact Crower Tech for more information, including availability. 4340 steel billet rods run $167 per rod. Billet titanium rods run $459 per rod. Allow 12 weeks for delivery, 50% deposit required on all orders.
in reference back to SK i have done a little more research today and i actually think that eagle are starting with a subaru rod of some discription... i couldnt tell you what particular engine it is from but that is the word i have been given by a man that has delt with alot of subaru's and used eagles many times!!!! Cheers, Daniel.
Hi Daniel, I am not a Subaru expert but the longest Subaru (EJ20 and EJ25) rod I have seen is just over 5", nowhere near the 6" rod needed in an RB30. :(
You will get plenty of discussion over the "H" Beam versus "I" Beam rods on any V8 forum. There are pros and cons. I believe H beams are a bit more aerodynamic. For the same weight "I" beams are a little stronger in torsional bend, but "H" beams balance up more evenly. "I" beams will handle a bit of abuse, whereas just a little nick in a "H" beam will result in a stress fracture. etc etc My new RB31DET has "I" beams in it, they are rated at 200 bhp each. All my previous engines have had "H" beams and I have never had a problem.
Bottom line, I have no idea which is better :(
SK yeah i thought that as subaru rods are only 5.135" for ej20 and 5.162" for ej25...
but i really cant be sure as the part numbers corispond with so many other parts doesnt really matter to me as long as they fit...
checked some rough measurements today, they are actually 6"... they come with the bearings that look to be the standard chev ones machine to width by eagle geez they have done a nice job on them... also they are quiet a thicker bearing hence the crank grindind of 1.960 +- journal tolerences...
which gets me to my next question for a 700hp+ what crank journal clearances are you running... similar hp for a chev i know to run around 3-5thou but what about a nissan i really dont want to mess this up and stuff bearings constantly
lol, go work being decisive there, SK. ;)
I was just being honest, I really can't say for sure which is better. :D
Let me start off with, I am not a fan of grinding RB cranks, as they are very well nitrided standard. If it needs more than a linish, I simply don't use it. There are different thicknesses of Chevy bearings, I would prefer to use a thinner bearing than grind the crank. Alternatively, open up the big end. We run minimum 2 thou clearance, but it depends on horsepower, oil pressure and the oil you are using. ;)
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
