The R32 RB25DE VRS kit is around $275.
It includes all top end gaskets consisting of inlet manifold gasket, plenum gasket, exhaust manifold gasket, rocker cover gaskets and valve stem seals. There may be more thats the most important one off the top of my head. :cheers:
If I was to buy JUST the valve stem seals from Nissan they wanted $330.. lol
i have a question for you guys i have an rb30 block and a rb26 head i want to put them together is it possible if it is how do i go about doing it and where do i source the parts to do it thanks alot.
dude... you've got 99 pages here which pretty much give you the ins and outs of exactly how to do it. There is also a guide floating around (i think Cubes did it). Infact there is a link in his post above this!
Andrew
I thought I'd update ppls..
Loading up say 4th gear at 1500rpm starts to see boost quickly then it goes flat and the turbo sounds strange, if I hold my foot in to it the turbo starts to make a really strange noise (almost a popping noise) then the car begins to jerk around. nasty pasty. :)
I have never actually held my foot in to it when it has that flat feeling so I haven't heard the popping or felt the jerking before. Never again will I do it. Sounds really bad.
Not to worry, its never really in that zone anyhow. :cheers:
A good excuse to pull the little terd off. :D
Welcome to the world of compressor surge:cheers:
Andrew
thanks alot for your help, wha tkind of power have you seen this conversion produce, i am living in the united states and there is not alot of people that do these kind of conversions so i jus wanted to try something new, again thanks alot for your help guys.
What, you guys had enough of buying every sr20 on the market and driving the price up for the rest of us? Want to move onto something else to overvalue do ya?
(not that i won't sell you a rb30 short motor...)
guys...
if i through a rod in my 25det could i just bolt on a rb30 bottom end?
would like to keep compression same maybe a bit lower...
im running 18psi through standard motor and i know it will fly apart soon, hahahaha
any help would be great
thanx
This would have to be one of the longest threads I've ever seen and by far the most useful.
Cubes and Sydneykid have been saying for quite some time that cams should become before upgrading the plenom, in particular TOMEI 256 cams. I have a Rb25 head with VVT that is ported and polished (mirror finish).
Has anyone used these cams in a 25/30 and has dyno results to show?, I'm interested at looking at the mid range Hp and Torque.
i am sorry if this has been asked but can you use SR20 pistons when building up a rb30det?
and does anyone know a good place to get rb30e pistons from.
thanks
I've read about using sr20 pistons in them before, Blue r33 with 26 head 30 bottom that was in nzpc a while ago was using them. I'm still not sure why anyone would do this in preference to using forged 30 ones, needing to buy two sets of sr pistons bumps the cost up a bit.
A bit of the topic, ive got a rb30det in my R32. Has a stock bottom end with a R32 RB25DE head. Ive got an old school t04 on it with a smaller exhaust housing. Its running out of puff around 300rwhp.
Just wanting to know what turbos u guys are running and the power your making, and how the driveability is with them? Im after something that will produce 450rwhp with a good power band?
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
    • Does this apply if you use an aftermarket ecu as it probably doesn't have that functionality built it? (Assuming it doesn't, in my case, apexi)
