Ive been runnin around in my RB30DET for about 9 months... 30,000km or so later and she it still going strong... Mods are
RB30DET 25 head
PFC
Exaust
AVO Stage 2 intercooler and 3" piping
Sard FPR withstock injectors
T4 turbo 60 ar with rx7 rear 300zx rear housing
Walbro 500hp pump
Taking it to UAS to give it a tune methinks.. any ideas on what power she should make ??? I would like 250rwkw :( thats the max for stock injectors ???
got the car to scott @ insight for a tune last night
its been running like shuit latekly
he started all over again. fixed mapping etc etc
11psi. he said roughly 320rwhp
i be happy. rb30det is the way to go i say.
torque monster. go the stock bottom end!!
Nice man.. what turbo specs??? stock injectors ????
nice one mark you bastard. pete told me he reckons it may chirp seconds now. is that true?
fix your clutch, and also I'm hanging for my turn. you've driven my sick 31, now it's time to swap!
quick question:
the RB30's in the VL's were used with LEADED petrol right?
and to use unleaded they needed some additive to protect the rings?(not sure if this part is right)
so do you need to buy different rings when rebuilding the stock bottom end for a det conversion?
Gary said stock rings, bearings...etc...
so can someone explain the reason why an additive is required for older cars to use Unleaded fuel?
cheers
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
