I read the PDF and i can source an RB25DE head quite cheap. Been the time of day, no engine builders are open at the moment thats why i asked for a "rough estimate" how many thousand dollars will it cost was what i was wondering? Ive got a shopping list at the moment of stuff to buy etc tec, was going to make a phone call tomorow, but i wanted to know tonight.
Quoting a rough figure isnt brain surgery is it? :)
Sweet as!
Thanks for the guestimate! I was hoping it was around the 2 grand mark. Im budneting for around 3 grans just in case. Ive seen all your posts and dyno graphs and am very impressed!
Ill let you guys know how i go with quotes from engine builders etc etc.
Cheers!
just thought i'd post a vid of my 4door. 3rd gear burnout. bout 4000rpm
gotta love rb30det power. this is the arse end of a 2 minute burnout. turn up the volume!
http://kero.drifthost.com/videos/100_1381.mpg
http://kero.drifthost.com/videos/100_1381.wmv
http://www.kero.drifthost.com/videos/100_1381.AVI
cheers
As you can see in my previous post, my cheap head has now gone bye bye. :(
I rang around a few places to get some prices. Just Jap wanted 995 for an RB25DE head, SSSautomotive said they could supply me with the whole RB25DE motor for 1000. Is there something i am missing here? Or is just jap just got really high prices???
Also spoke to engine builder about rebuilding an RB30 bottom end, to get "the lot" rods, pistons, crank and block rebuilt 2200.
Please excuse my ignorance, this is my first time and i have pretty much NFI about prices on this stuff, when i get a chance over the weekend ill try to read all the posts in this thread.
thanks
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
