thanks very very much cube's.
i bought the pump as it was advertised as a brand new vl turbo pump.
but when i got my old vlt one to compare,i found they are completely different internals.
wasnt happy.
but looks like the pump i got is an rb25det one.
anyone want to buy it?
hehe
Just trying to finalise a few parts for my conversion - sorry if these have been answered somewhere else, I did search!
- What is the difference between series 1 and series 2 rb25DET's ? I'm looking at buying a splitfire ignition system instead of coilpacks and they have a model for each - this is going in a VL with an aftermarket ECU, so is it even applicable? On a similar note, is the wiring loom the same for these series 1 and 2 engines?
- I'm going to be running a powerFC, are they able to be tuned without an AFM? Or does it still rely on that (as far as I can tell it does). If that's the case - what AFM will have enough scope to cover things (engine builder was suggesting a twin AFM arrangement, but that sounds more complicated than it needs to be IMO).
- Can someone explain exactly what has to happen to the block and/or head when fitting an RB25DET head onto the rb30 block, a detailed explaination would be great.
So far I'll be using the stock head, turbo/manifolds (will have the loom + coilpacks), a computer and obviously upgrading any old parts where needed. Is there any hidden items I've missed that I should be budgeting for (not accounting for things like piping, etc)?
Cheers guys - this thread is a life saver :P
1. What is the difference between series 1 and series 2 rb25DET's ?
2. this is going in a VL with an aftermarket ECU, so is it even applicable?
3. On a similar note, is the wiring loom the same for these series 1 and 2 engines?
4. I'm going to be running a powerFC, are they able to be tuned without an AFM? Or does it still rely on that (as far as I can tell it does).
5. If that's the case - what AFM will have enough scope to cover things (engine builder was suggesting a twin AFM arrangement, but that sounds more complicated than it needs to be IMO).
6. Can someone explain exactly what has to happen to the block and/or head when fitting an RB25DET head onto the rb30 block, a detailed explaination would be great.
7. So far I'll be using the stock head, turbo/manifolds (will have the loom + coilpacks), a computer and obviously upgrading any old parts where needed. Is there any hidden items I've missed that I should be budgeting for (not accounting for things like piping, etc)?
Much easier if you number you questions;
1. As Ben said S1 has a separate ignitor module, S2 has ignitors built int oeach coil.
2. Chassis is irrelevant, the only thing that matters is the wiring harness, use the coils that go with the wiring harness and the ECU.
3. No
4. No
5. You can use a single Q45 AFM (90 mm), so far good for 420+ rwkw
6. No way, read the thread there are so many choices, pick the one that you like. Read the How to Guide it's simpler/shorter.
7. The list (tick off what you already have). Intercooler, radiator, exhaust, intercooler pipework, power steering, air con, engine mounts, oil cooler, turbo/turbos, turbo water and oil fittings, air filter, AFM to turbo pipework, gaskets, decent sump (wings, one way doors and baffles are best), boost controller, Power FC, injectors, fuel pump, fuel pressure regulator, radiator hoses, belts, water pump, oil pump, clutch, gearbox, tailshaft, diff, brakes, suspension, wheels, tyres, gauges etc etc
Good luck:cheers:
Cheers :D
I thought the series1/2 differences may not have been related to the actual head itself. My point being, if I used a series 1 loom on a series two engine or vice versa would it work? :)
Ah great - I'll keep an eye out for one
hehe, I've got the how-to guide and it doesn't cover the actual nitty-gritty, just mentioned it has to be 'modified' and has a picture comparing the two blocks. I guess I'll leave that up to the engine builder.
lol cheers mate (definatly has wheels and suspension last I checked :P) ;) I think I can check off almost everything there, although I do need to replace the oil/water pumps :)
you sure? the coilpacks on a S1 have an external ignitor so the loom must be different......
sorry yes the externals are different like coil pack....I mean the actual heads themselves are interchangable. I put a S1 motor into an S2 car using the S2 ignition with no problems
yeah i was maybe hoping to get closer to 350 but ohwel. with ebc said should be around 315kw.
arias pisons
mild port & polished head (standard cams)
gt35 turbo
50mm ex gate
600cc injectors
wollf 3d
044 pump
custom plenum
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
